bi0h4zard 3 Posted December 11, 2019 Posted December 11, 2019 (edited) Computer AZW Gemini X55 Betriebssystem Microsoft Windows 10 Pro (64-Bit) Prozessor Intel® Pentium® Silver J5005 CPU @ 1.50GHz Grafikprodukte Microsoft Remote Display Adapter Intel® UHD Graphics 605 Audio High Definition Audio Device Intel® Display-Audio Netzwerktechnik und I/O Intel® Dual Band Wireless-AC 3165 Realtek PCIe GbE Family Controller Intel® Wireless Bluetooth® Speicher 8 GB Massenspeicher AZW-256G HGST USB Device Seagate Backup+ Hub BK SCSI Disk Device igfx_win10_100.7463 MediaSDK2019R1 intel_sdk_for_opencl_applications_2019.5.345 last windows update 11.12.2019 Emby PremiumBevorzugte Hardware-Decoder MPEG-2 QuickSync Intel® UHD Graphics 605 - MPEG-2 QuickSync Intel® UHD Graphics 605 - D3D11 - MPEG-2 DX11VA Intel® UHD Graphics 605 - MPEG-2 VC-1 QuickSync Intel® UHD Graphics 605 - VC-1 QuickSync Intel® UHD Graphics 605 - D3D11 - VC-1 DX11VA Intel® UHD Graphics 605 - VC-1 H.264 (AVC) QuickSync Intel® UHD Graphics 605 - H.264 (AVC) QuickSync Intel® UHD Graphics 605 - D3D11 - H.264 (AVC) DX11VA Intel® UHD Graphics 605 - H.264 (AVC) H.265 (HEVC) QuickSync Intel® UHD Graphics 605 - H.265 (HEVC) QuickSync Intel® UHD Graphics 605 - D3D11 - H.265 (HEVC) DX11VA Intel® UHD Graphics 605 - H.265 (HEVC) VP8 QuickSync Intel® UHD Graphics 605 - D3D11 - VP8 VP9 DX11VA Intel® UHD Graphics 605 - VP9 Bevorzugte Hardware-Encoder H.264 (AVC) QuickSync Intel® UHD Graphics 605 - H.264 (AVC) QuickSync Intel® UHD Graphics 605 - D3D11 - H.264 (AVC) all checked quick sync works on system but not on emby User policy for Administrator: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: TrueAffected codecs:>>>>>> QuickSync Intel® UHD Graphics 605 - H.265 (HEVC)Adapter #0: 'Intel® UHD Graphics 605' Id:12676 (Driver: 1703956.6561063, Vendor: 32902)Frame Sizes: 16x16...16384x16384 - Width Alignment: 2 - Height Alignment: 2Color Formats: NV12, P010, NV16>>>>>> QuickSync Intel® UHD Graphics 605 - H.264 (AVC)Adapter #0: 'Intel® UHD Graphics 605' Id:12676 (Driver: 1703956.6561063, Vendor: 32902)Frame Sizes: 32x32...8192x8192 - Width Alignment: 2 - Height Alignment: 2Color Formats: NV12, P010, QSVProfiles: Baseline Profile (Level 5.2), Main Profile (Level 5.2), High Profile (Level 5.2), Constrained Baseline Profile (Level 5.2), Constrained High Profile (Level 5.2), Progressive High Profile (Level 5.2)>>>>>> FindVideoDecoder - MediaType: hevc, Mode: CustomInfo FindVideoDecoder - Checking: 'QuickSync Intel® UHD Graphics 605 - H.265 (HEVC)' (Priority: 100)Info FindVideoDecoder - Check successful - selecting 'QuickSync Intel® UHD Graphics 605 - H.265 (HEVC)'>>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: CustomInfo FindVideoEncoder - Checking: 'QuickSync Intel® UHD Graphics 605 - H.264 (AVC)' (Priority: 100)Info Encoder supports input streamInfo FindVideoEncoder - Check successful - selecting 'QuickSync Intel® UHD Graphics 605 - H.264 (AVC)'C:\Users\Administrator\AppData\Roaming\Emby-Server\system\ffmpeg.exe -loglevel +timing -hwaccel qsv -hwaccel_device hw -qsv_device 0 -c:v hevc_qsv -load_plugin hevc_hw -f matroska -i file:"X:\1234.mkv" -threads 0 -map 0:0 -map 0:1 -sn -c:v:0 h264_qsv -b:v:0 4829002 -maxrate 4829002 -bufsize 9658004 -preset veryfast -profile:v:0 high -level:v:0 4.0 -g:v:0 72 -keyint_min:v:0 72 -sc_threshold:v:0 0 -copyts -vsync -1 -codec:a:0 libmp3lame -metadata:s:a:0 language=ger -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Embytemp\transcoding-temp\5c3523680e4a8d2eb58d620a494274b4.m3u8" -y "C:\Embytemp\transcoding-temp\5c3523680e4a8d2eb58d620a494274b4%d.ts"20:40:09.946 ffmpeg version 4.3.0-emby_2019_11_25-g5abbb1430d+3686 Copyright © 2000-2019 the FFmpeg developers and softworkz for Emby LLC20:40:09.946 built with gcc 9.2.0 (Rev2, Built by MSYS2 project)20:40:09.946 Execution Date: 2019-12-11 20:40:0920:40:10.071 Input #0, matroska,webm, from 'file:X:\1234.mkv':20:40:10.071 Metadata:20:40:10.071 ENCODER : Lavf58.30.10020:40:10.071 Duration: 01:20:45.31, start: 0.000000, bitrate: 2414 kb/s20:40:10.071 Stream #0:0: Video: hevc (Main), yuv420p(tv, bt709), 1920x958 [sAR 1:1 DAR 960:479], Level 120, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc, Start-Time 0.005s (default)20:40:10.071 Metadata:20:40:10.071 BPS-eng : 202728720:40:10.071 DURATION-eng : 01:20:45.29900000020:40:10.071 NUMBER_OF_FRAMES-eng: 11617120:40:10.071 NUMBER_OF_BYTES-eng: 122785189520:40:10.071 DURATION : 01:20:45.30300000020:40:10.071 Stream #0:1(ger): Audio: ac3, 48000 Hz, stereo, fltp, 384 kb/s (default)20:40:10.071 Metadata:20:40:10.071 title : Stereo20:40:10.071 BPS-eng : 38400020:40:10.071 DURATION-eng : 01:20:45.31200000020:40:10.071 NUMBER_OF_FRAMES-eng: 15141620:40:10.071 NUMBER_OF_BYTES-eng: 23257497620:40:10.071 DURATION : 01:20:45.31200000020:40:10.071 Stream mapping:20:40:10.071 Stream #0:0 -> #0:0 (hevc (hevc_qsv) -> h264 (h264_qsv))20:40:10.071 Stream #0:1 -> #0:1 (ac3 (native) -> mp3 (libmp3lame))20:40:10.071 Press [q] to stop, [?] for help20:40:10.227 [AVHWDeviceContext @ 0000020bca2c45c0] Error initializing an MFX session: -3.20:40:10.243 Error creating a QSV device20:40:10.243 qsv hwaccel requested for input stream #0:0, but cannot be initialized.20:40:10.243 Error while decoding stream #0:0: Operation not permitted20:40:10.368 [AVHWDeviceContext @ 0000020bca2c3bc0] Error initializing an MFX session: -3.20:40:10.383 Error creating a QSV device20:40:10.383 qsv hwaccel requested for input stream #0:0, but cannot be initialized.20:40:10.383 Error while decoding stream #0:0: Operation not permitted20:40:10.508 [AVHWDeviceContext @ 0000020bca2c40c0] Error initializing an MFX session: -3.20:40:10.524 Error creating a QSV device20:40:10.524 qsv hwaccel requested for input stream #0:0, but cannot be initialized.20:40:10.524 Error while decoding stream #0:0: Operation not permitted20:40:10.633 [AVHWDeviceContext @ 0000020bca32e000] Error initializing an MFX session: -3.20:40:10.649 Error creating a QSV device20:40:10.649 qsv hwaccel requested for input stream #0:0, but cannot be initialized.20:40:10.649 Error while decoding stream #0:0: Operation not permitted20:40:10.649 frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbits/s throttle=off speed=N/A20:40:10.774 [AVHWDeviceContext @ 0000020bca32c980] Error initializing an MFX session: -3.20:40:10.774 Error creating a QSV device20:40:10.774 qsv hwaccel requested for input stream #0:0, but cannot be initialized.20:40:10.774 Error while decoding stream #0:0: Operation not permitted20:40:10.914 [AVHWDeviceContext @ 0000020bca32d780] Error initializing an MFX session: -3.20:40:10.914 Error creating a QSV device CPU: 100% GPU 5% Edited December 11, 2019 by bi0h4zard
Luke 42216 Posted December 11, 2019 Posted December 11, 2019 Hi there, please attach the information requested in how to report a problem. thanks.
bi0h4zard 3 Posted December 11, 2019 Author Posted December 11, 2019 quick sync works on system but not on emby Computer AZW Gemini X55 Betriebssystem Microsoft Windows 10 Pro (64-Bit) Prozessor Intel® Pentium® Silver J5005 CPU @ 1.50GHz Grafikprodukte Microsoft Remote Display Adapter Intel® UHD Graphics 605 Audio High Definition Audio Device Intel® Display-Audio Netzwerktechnik und I/O Intel® Dual Band Wireless-AC 3165 Realtek PCIe GbE Family Controller Intel® Wireless Bluetooth® Speicher 8 GB Massenspeicher AZW-256G HGST USB Device Seagate Backup+ Hub BK SCSI Disk Device igfx_win10_100.7463 MediaSDK2019R1 intel_sdk_for_opencl_applications_2019.5.345 last windows update 11.12.2019 Emby PremiumBevorzugte Hardware-Decoder MPEG-2 QuickSync Intel® UHD Graphics 605 - MPEG-2 QuickSync Intel® UHD Graphics 605 - D3D11 - MPEG-2 DX11VA Intel® UHD Graphics 605 - MPEG-2 VC-1 QuickSync Intel® UHD Graphics 605 - VC-1 QuickSync Intel® UHD Graphics 605 - D3D11 - VC-1 DX11VA Intel® UHD Graphics 605 - VC-1 H.264 (AVC) QuickSync Intel® UHD Graphics 605 - H.264 (AVC) QuickSync Intel® UHD Graphics 605 - D3D11 - H.264 (AVC) DX11VA Intel® UHD Graphics 605 - H.264 (AVC) H.265 (HEVC) QuickSync Intel® UHD Graphics 605 - H.265 (HEVC) QuickSync Intel® UHD Graphics 605 - D3D11 - H.265 (HEVC) DX11VA Intel® UHD Graphics 605 - H.265 (HEVC) VP8 QuickSync Intel® UHD Graphics 605 - D3D11 - VP8 VP9 DX11VA Intel® UHD Graphics 605 - VP9 Bevorzugte Hardware-Encoder H.264 (AVC) QuickSync Intel® UHD Graphics 605 - H.264 (AVC) QuickSync Intel® UHD Graphics 605 - D3D11 - H.264 (AVC) all checked embyserver.txt ffmpeg-transcode-e3628d22-3f62-4bb9-bc2e-7ac59148985c_1.txt hardware_detection-63711682129.txt
Luke 42216 Posted December 11, 2019 Posted December 11, 2019 Hi there, did you make sure to follow our hardware acceleration setup guide? https://github.com/MediaBrowser/Wiki/wiki/Hardware-Acceleration-Overview
bi0h4zard 3 Posted December 11, 2019 Author Posted December 11, 2019 yes checked it 3 times. the only thing confusing me is Emby currently does not support headless operation with Intel QuickSync You will either need to connect a physical monitor to the video output or you can acquire a "dummy monitor plug" to make the GPU think that a monitor is connected i also read on an other site it was supported now .....if this is the problem...how can i fix this? i only use remoute desktop, no monitor.
Luke 42216 Posted December 11, 2019 Posted December 11, 2019 @@softworkz will clarify and update the wiki if needed. Thanks.
Happy2Play 9806 Posted December 11, 2019 Posted December 11, 2019 I can assume you RDP into the box hosting Emby, as you should not see all of those option. Or at least that is what I see on my system when I RDP. If I have not remote connected to my server I only see D3D11 and DX11VA options. So I guess a question would be does this situation create confusion within Emby or does Emby try all three methods when displayed? Or should the user manually disable options via advanced. Also this would appear to be only a decoding issue. Error while decoding stream #0:0: Operation not permitted
bi0h4zard 3 Posted December 11, 2019 Author Posted December 11, 2019 i only checked with rdp if the quicksync was running on the system.(because no monitor)...i run emby via web browser. i disabled some decoder/encoder and used only one decoder/encoder . same problem.
bi0h4zard 3 Posted December 12, 2019 Author Posted December 12, 2019 today i only can choose (i did not do anything since yesterday) Bevorzugte Hardware-Encoder H.264 (AVC)QuickSync Intel® UHD Graphics 605 - D3D11 - H.264 (AVC) and transcoding works with h.264 h.265 do not work
bi0h4zard 3 Posted December 12, 2019 Author Posted December 12, 2019 (edited) now i see what´s happen if i start my emby with rdp i see but only software is working if i start emby without rdp i see nothing in the hardware acc. only software is working. if i put a monitor on only h.264 is working with quicksync i try to get a hdmi dummy and keep trying some other testing stuff too Edited December 12, 2019 by bi0h4zard
Happy2Play 9806 Posted December 12, 2019 Posted December 12, 2019 now i see what´s happen if i start my emby with rdp i see rdp.png but only software is working if i start emby without rdp i see nothing in the hardware acc. only software is working. if i put a monitor on only h.264 is working with quicksync i try to get a hdmi dummy and keep trying some other testing stuff too I would assume Emby is not trying all the displayed enabled methods then. You need to re-sort the available decoders and encoders to have the options at the top as when you have not rdp'd into your machine, or disable all the option that do not appear when you have not rdp'd into the system.
softworkz 5130 Posted December 12, 2019 Posted December 12, 2019 yes checked it 3 times. the only thing confusing me is i also read on an other site it was supported now .....if this is the problem...how can i fix this? i only use remoute desktop, no monitor. Yes, it's supported now. But you need to move codecs having both 'QuickSync' and 'D3D11' in their name. Only the D3D11 variants are working without a connected monitor. Without a connected monitor, the non-D3D11 QuickSync variants shouldn't even be visible, but I guess that there has been a monitor connection at the time when Emby was started? @@softworkz will clarify and update the wiki if needed. Thanks. Oh right, the wiki is outdated...
bi0h4zard 3 Posted December 13, 2019 Author Posted December 13, 2019 (edited) if i start my emby server without monitor and without rdp i got this nothing shows up but it works more confused if i see the encoders / decoders nothing works if i can not see them, all works fine Edited December 13, 2019 by bi0h4zard
bi0h4zard 3 Posted December 13, 2019 Author Posted December 13, 2019 (edited) every time i connect via rdp to the machine where emby is running the HARDWARE qicksync changes automaticly to SOFTWARE there is always a new "hardware_detection_log" is there a way to disable this? Edited December 13, 2019 by bi0h4zard
softworkz 5130 Posted December 14, 2019 Posted December 14, 2019 @@bi0h4zard - The list of hw acceleration codecs takes a while to be populated after starting the server. You need to wait 1-2 min before looking at it. Have you tried moving the D3D11 variants to the top of the list as I have suggested?
bi0h4zard 3 Posted December 14, 2019 Author Posted December 14, 2019 settings: with rdp h264 software h265 hardware
bi0h4zard 3 Posted December 18, 2019 Author Posted December 18, 2019 The list of hw acceleration codecs takes a while to be populated after starting the server. You need to wait 1-2 min before looking at it. yes this works very fine.but if i connect via rdp again it does a new hardware detection and the next file transcodes in software again ...if i disconnect the rdp the next file uses quicksync. so can i disable this hardware_detection or can i set some defaults?
softworkz 5130 Posted December 19, 2019 Posted December 19, 2019 The hardware detection accesses QuickSync in the exact same way as ffmpeg does. That means that when the detection cannot access QuickSync, ffmpeg won't be able as well. So it's not a problem with the detection. I think you're seeing this because you're RDP'ing into the same user session in which Emby is running. There are two ways to solve this: Either run Emby as service(information about this can be found in the Wiki). Or run Emby in a different sessionThere are several ways to do this:Login locally under a different user account and start Emby thereThen use 'fast-user-switching' and log on like you do usually. Login from remote, using a different user accountStart Emby in this sessionDisconnect (don't log off)Connect via RDP normally. It is also possible to create a new session with the same user account(This is the default behavior with Windows server)But you need to look up the RDP command line arguments to do that (look for "console session", you don't want to connect to it)I would not recommend this for regular use because you can loose user profile settings because the last session logging off "wins"
Happy2Play 9806 Posted December 19, 2019 Posted December 19, 2019 Wouldn't the easiest fix be the user disable the options that are enabled by accident do to RDP session? So HWA continues to work no matter if you RDP or not. I know this works for me.
softworkz 5130 Posted December 19, 2019 Posted December 19, 2019 @@Happy2Play - That's was my first suggestion. But it appears that in his case, logging in via RDP even disables DirectX11 access to the hardware in his user session. We could spend a lot of time now, finding out why it is different in his case - but orchestrating an investigation remotely, that's a bit off limit for our support. You are welcome to check up with the user directly, what both of your setups have in common and what is different. Even when you'd find out, it doesn't necessarily mean that it's something that he can change.
Solution softworkz 5130 Posted February 1, 2020 Solution Posted February 1, 2020 There's finally a solution for QuickSync (plus all other Direct3D based hw accelerations) in combination with RDP! Please read here: https://emby.media/community/index.php?/topic/82035-im-not-getting-hw-transcoding-with-my-j4105-nuc/?p=838313
