spidermunky 1 Posted December 10, 2019 Posted December 10, 2019 Hi, Wasn't sure where to post this. Issue relates to Live TV recording and playback via synology installation of Emby Server - I need some help Server version 4.3.0.30 Issue description: DVR set to record a live tv program between 8:30pm and 9:30pm GMT (electoral debate) At around 9pm I select to watch the program, choosing to watch from the beginning. So, channel is continuing to record while I watch the already recorded portion of the show. Everything is fine for around 16 mins, then the stream begins to freeze regularly about every 10 seconds, each freeze lasts about 5-10 seconds. I try backing out the stream, then when i go back in via the guide it just sits at the start of the program and is frozen. I try accessing the show as a recording, same problem Time passes, it's now 9:30pm so the recording has about finished. I try accessing the recording. This time it plays. I forward to the 16min mark, but after a short while the recording is all messed up. Voices out of sync with the images, clipping in the sound, bad screen artifacts all over the place. Basically unwatchable. This has happened before - hence why i'd like help in understanding whats going on. I can see errors in the log file around 9pm, but not sure what they indicate. Any help appreciated. Log attached. embyserver-63711320551.txt
rikiwi 32 Posted December 12, 2019 Posted December 12, 2019 I experienced similar behaviour a few days ago. My scenario yestoday was as follows: Started recording a show at 8.30pm Started to watch it at 8.50pm - the recording length showed 20 minutes As each ad segment was encountered I was able skip over it On reaching the 20 minute position it was impossible to continue. After waiting until the show had finished it was only possible to wath the 20 minute segment Looking at the file in Windows it was shown as 1 hour and 3 minutes (1 hour show + 3 minutes padding) The next day I started watching the recording and it showed only 20 minute recording When I got to the 20 minute mark the remaining time suddenly changed to - 1:59:59 I was able to continue watching to the end. This is happening in the Android Mobile app and Emby Theater for Windows. Using the Emby Web App I get the same scenario as posted above and when it gets to the 20 minute mark playback just stops. Basically now I just wait till the next day to watch any recorded TV. Hope this helps. I can provide clean logs doing another test recording if needed.
spidermunky 1 Posted December 15, 2019 Author Posted December 15, 2019 Hi - thanks for adding to the discussion. The issue sounds quite similar to mine then - with the exception that my recording was corrupted by sound and visual artefacts. Is anyone from the development community available to comment? It would be good to identify the issue and log it as something to be addressed in a later code release - assuming it is not something already under review. 1
Luke 42244 Posted January 24, 2020 Posted January 24, 2020 @@spidermunky are you still having an issue with this with the latest release of Emby Server?
rikiwi 32 Posted February 11, 2020 Posted February 11, 2020 Sorry for the slow respnse. I've just tested my scenario again since todays server update to version 13. The only app that successfully allows playing of in progress recordings is Emby Theater. On the sever itself and android app and android tv playing stops as soon as It reaches the current time of the recording from the firts app to attempt playing.
rikiwi 32 Posted February 21, 2020 Posted February 21, 2020 Just checking in again: I'm still experiencing this problem even with the latest Beta. Still working OK using Emby Theater (3.0.6)
Luke 42244 Posted February 21, 2020 Posted February 21, 2020 Just checking in again: I'm still experiencing this problem even with the latest Beta. Still working OK using Emby Theater (3.0.6) But don't you use next pvr for recording? So that means what you're saying has no relation to this topic, right?
rikiwi 32 Posted February 21, 2020 Posted February 21, 2020 Sorry Luke if I've been posting in the wrong forum. There are several similar posts relating to watching in progress recordings but I just couldn't see them today. Please remove or move my posts to a more appropriate forum. Yes I am using NextPVR.
byusinger84 1 Posted February 29, 2020 Posted February 29, 2020 I have this happening with my set up too (ServerWMC and latest stable of Emby). If I pause the stream (direct streaming, btw...no transcoding) for about 30 seconds and then hit play, it's as smooth as butter. I wonder if the client or the server isn't buffering enough. That said, the work around by just pausing for about 30 seconds make it usable, at least.
reneboulard 35 Posted March 20, 2020 Posted March 20, 2020 I have exactly the same problem. Using emby 4.4.028 beta on a windows system with a I5 and SSD. and HDHomerunQuatro Playing a tv show while it is recording is fine until you reach the time in the recording you started to watch, then the recording is corrupted at about 3 min interval thereafter and seeking become more unstable and eventualy fail. I have had this problem since at least version 4.4.0.0 and moved to the beta to see if it was fixed. Been watching more TV at home in the last week, considering the quarantine. So it would be nice to be able to use this feature. Thank you for your help.
Luke 42244 Posted March 25, 2020 Posted March 25, 2020 I have exactly the same problem. Using emby 4.4.028 beta on a windows system with a I5 and SSD. and HDHomerunQuatro Playing a tv show while it is recording is fine until you reach the time in the recording you started to watch, then the recording is corrupted at about 3 min interval thereafter and seeking become more unstable and eventualy fail. I have had this problem since at least version 4.4.0.0 and moved to the beta to see if it was fixed. Been watching more TV at home in the last week, considering the quarantine. So it would be nice to be able to use this feature. Thank you for your help. We'll help you in your topic: https://emby.media/community/index.php?/topic/83977-live-tv-viewing-while-recording-pixelation-every-3-min Thanks.
