Aealo666 0 Posted December 9, 2019 Posted December 9, 2019 (edited) Hello, I was trying to watch movie that has flac audio but Emby only played it without any sound. I have also tried to play it from USB with TVs default player and Plex and both played it without problems. Here is mediainfo of that file General Unique ID : 228520371793701357616766778572085466674 (0xABEB6C35AC878440B74EDEADFD491632) Format : Matroska Format version : Version 4 File size : 10.7 GiB Duration : 1 h 48 min Overall bit rate mode : Variable Overall bit rate : 14.1 Mb/s Encoded date : UTC 2013-03-12 08:56:55 Writing application : mkvmerge v6.1.0 ('Old Devil') built on Mar 2 2013 14:32:37 Writing library : libebml v1.3.0 + libmatroska v1.4.0 Cover : Yes Attachments : cover.jpg / xlog.txt Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 48 min Width : 1 920 pixels Height : 816 pixels Display aspect ratio : 2.35:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 130 r2273kMod b3065e6 Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.10:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=0 / crf=16.5000 / qcomp=0.75 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=50000 / vbv_bufsize=62500 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70 Language : English Default : Yes Forced : No Color range : Limited Matrix coefficients : BT.709 Audio ID : 2 Format : FLAC Format/Info : Free Lossless Audio Codec Codec ID : A_FLAC Duration : 1 h 48 min Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Bit depth : 24 bits Compression mode : Lossless Writing library : libFLAC 1.2.1 (UTC 2007-09-17) Language : English Default : Yes Forced : No Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Default : No Forced : No Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Default : No Forced : No Text #3 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Russian Default : No Forced : No Text #4 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Spanish Default : No Forced : No Menu 00:00:00.000 : en:Opening Credits 00:06:23.800 : en:The New Girl 00:10:22.038 : en:Enduring Ailments 00:14:01.423 : en:Playful Girls 00:21:33.083 : en:Saints of the Fourth World 00:28:10.647 : en:"Finding the Key" 00:34:52.256 : en:Letters to Pass the Days 00:44:26.747 : en:"John Has Fallen In Love With Me" 00:54:10.205 : en:An Unhealthy Friendship? 01:02:17.150 : en:New Resolutions 01:08:06.332 : en:"Poor Father" 01:14:17.744 : en:"Sink Or Swim Together" 01:19:54.122 : en:"Stark Raving Mad" 01:25:35.505 : en:"In Pursuit of Happiness" 01:31:37.283 : en:"The Happy Event" 01:38:23.063 : en:Honora's End Edited December 9, 2019 by Aealo666
Aealo666 0 Posted December 9, 2019 Author Posted December 9, 2019 Hi, audio is played via Sonos Beam using HDMI Arc
ebr 16338 Posted December 10, 2019 Posted December 10, 2019 What happens if you set the audio option in the app to "Downmix to stereo"?
Aealo666 0 Posted December 16, 2019 Author Posted December 16, 2019 I am using "Downmix to stereo" as default but changing to Auto does not make any difference either.
ebr 16338 Posted December 16, 2019 Posted December 16, 2019 Can you please play the item for a few seconds and then send a log from the app? Thanks.
Aealo666 0 Posted December 30, 2019 Author Posted December 30, 2019 Hello, sorry for the delay. I have sent you logs now at 11:48 CET (5:48 AM Eastern Time). Emby user ser was Aealo. First I have tried to play file that I mentioned in my first post and then I played file with DTS audio that I had no audio while playing yesterday but it played fine with Plex. General Format : Matroska Format version : Version 1 File size : 6.54 GiB Duration : 2 h 12 min Overall bit rate mode : Variable Overall bit rate : 7 064 kb/s Encoded date : UTC 2008-12-05 06:03:20 Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 7 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 7 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2 h 12 min Bit rate : 5 462 kb/s Width : 1 280 pixels Height : 688 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.259 Stream size : 4.94 GiB (76%) Writing library : x264 core 65 r1040M 1591275 Encoding settings : cabac=1 / ref=7 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=1 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=5462 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Language : English Default : Yes Forced : No Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 2 h 12 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.40 GiB (21%) Default : Yes Forced : No Audio #2 ID : 3 Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 2 h 12 min Bit rate mode : Variable Bit rate : 80.0 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Compression mode : Lossy Stream size : 75.8 MiB (1%) Writing library : aoTuV Beta 3 (UTC 2004-11-20) Default : No Forced : No
ebr 16338 Posted December 30, 2019 Posted December 30, 2019 I believe you have two different issues here. On the FLAC audio - the player does not see any compatible audio track in that stream. Can you get it to me for testing? Your second issue has to do with the specific encoding of that file which is not supported by the player: ParserException: Lacing only supported in SimpleBlocks.
Aealo666 0 Posted December 31, 2019 Author Posted December 31, 2019 I have PMed you link to that file
