osak00006 12 Posted December 8, 2019 Posted December 8, 2019 What's the correct way to do this? I'd like to gut my existing database, including Collections logic etc, and then start fresh... however, I'd like to keep all my other settings (scrapers etc etc)
Luke 42217 Posted December 8, 2019 Posted December 8, 2019 You could just delete your library.db file, although that also contains watch data.
osak00006 12 Posted December 8, 2019 Author Posted December 8, 2019 You could just delete your library.db file, although that also contains watch data. My Collections history is a bit of a mess, too. Would deleting that remove the Collections history? IE, paths for collections, names of collections that i manually created? Also, assume safety backup is as simple as copying that db file someone safe, prior to blowing things up?
Luke 42217 Posted December 8, 2019 Posted December 8, 2019 No there is a folder under the server's data folder that holds your collections and playlists. And yes for the other things, you can back up the file.
