bandit8623 230 Posted February 6, 2022 Posted February 6, 2022 (edited) if im correct i think its making a new library for any vid files that were uploaded. i noticed a poster being created for each vid that was on my phone uploaded. -edit removed all folders and now after a rescan there is just 1 folder is there. annoying bug on first setup for sure Edited February 6, 2022 by bandit8623
Luke 42262 Posted February 15, 2022 Posted February 15, 2022 Hi, yes we're looking into the cause of this. Thanks.
julianb 39 Posted June 1, 2022 Posted June 1, 2022 This is still happening on 4.7.1.0, just tried it and created 150 libraries. I have disabled uploads until this if fixed. 1
quickbeam 0 Posted July 11, 2022 Posted July 11, 2022 I've just purchased a Lifetime Premiere Subscription for the primary purpose of using this as my mobile photo/video backup option and discovered this is an issue, and found this thread. A disappointing turn of events, given it's otherwise a fantastic product so far. This is still happening and needs to be fixed ASAP. Happening with Emby 4.7.5.0 Ubuntu Linux 64 (installed using emby-server-deb_4.7.5.0_amd64.deb on 11th July 2022) and Emby for Android app v 3.2.52 (Updated on 23 June 2022) according to Google Play.
MEB 27 Posted July 11, 2022 Posted July 11, 2022 I have given up on this ever working correctly and switched to Resilio Sync.
Carlo 4561 Posted July 12, 2022 Posted July 12, 2022 IMHO, except for the admin and his/her immediate family there probably isn't a big use for this feature. I use Synology's app on our family phones which works well as it has good photo software. Any family member can move their photos from one folder to another in the home space. One is private and the other is EmbyPublic which is part of a photo library. This way I don't get 5 or 6 of the same pic or with different filters or slight changes but one the camera op submitted. A lot of apps could be used this way including OwnCloud and NextCloud.
bandit8623 230 Posted July 12, 2022 Posted July 12, 2022 4 minutes ago, cayars said: IMHO, except for the admin and his/her immediate family there probably isn't a big use for this feature. I use Synology's app on our family phones which works well as it has good photo software. Any family member can move their photos from one folder to another in the home space. One is private and the other is EmbyPublic which is part of a photo library. This way I don't get 5 or 6 of the same pic or with different filters or slight changes but one the camera op submitted. A lot of apps could be used this way including OwnCloud and NextCloud. i think the point though is dont have a feature that is half assed and broken. if its not going to be updated/ fixed it should be just removed. i personally have a file server running on windows, so im not going to go out and buy a nas. the photo upload works kinda once initial setup and all the garbage is removed. but organization is pretty bad. was looking for an alternative to google photos as they are pushing people to pay for data over 15 gig now. 1
Carlo 4561 Posted July 13, 2022 Posted July 13, 2022 I was just throwing out a couple ideas that likely would have worked very elegantly and probably enjoyed more by your users as well as provide additional features. I don't disagree with anything you said except the "half assed and broken" part as you might be giving it too much credit. Trying to say this in a positive, vs negative manner, I'd say it's the least useful feature available in Emby Server. I've brought this up internally asking if we could give some TLC to it. That's all I can do is ask. Honestly, I would setup and use a sync program as they are simple to use and just work. GoodSync, Resilio Sync come to mind. I use Resilio for many things including pics but also to make sure certain documents are synced to my phone as well as son, daughter and X-Wife. Having always updated info on emergency contacts, prescriptions taken (as well as a parent), Health Insurance info, Car Insurance info, etc is really nice to always have with you or making sure other loved ones have the info in case of need. The above is a trivial example as it's just copying a few small files or scans but shows how useful something like that can be working in reverse keeping info updated on your phone. They can all of course pull info to a PC. So there is no server or NAS needed to achieve similar results of what I mentioned. I can say about 5 minutes after installing and setting up a sync program on your PC and phone will have you forgetting all about Camera Upload feature.
Guest DylanDane Posted January 8, 2023 Posted January 8, 2023 (edited) On 7/12/2022 at 11:10 AM, cayars said: IMHO, except for the admin and his/her immediate family there probably isn't a big use for this feature. I use Synology's app on our family phones which works well as it has good photo software. Any family member can move their photos from one folder to another in the home space. One is private and the other is EmbyPublic which is part of a photo library. This way I don't get 5 or 6 of the same pic or with different filters or slight changes but one the camera op submitted. A lot of apps could be used this way including OwnCloud and NextCloud. This started happening again. Every upload creates a new iPhone Upload library. You’re basically saying the feature isn’t important to you therefore no one really uses it, then telling the FOUR PAGES of people having the same problem to download a different app. An app that requires a separate $200 piece of equipment to work. If people are having issues with emby’s library management, they already have a server where they’re storing files. They don’t need to buy another one to make the software function as advertised. There’s nothing I love more than support staff dismissing valid issues of paying customers as “not important” and then telling them if they want their emby subscription to work they need buy more hardware and use those apps instead. I have worked in tech for over a decade. I’m AWS and Azure certified. Emby’s development and support staff are the most dismissive and unhelpful I have ever come across. If you have a problem it’s either something you’ve set up wrong, you’re not using it the right way, or they don’t use it so they’re not going to fix it. Just a thought - maybe you guys should have developed your own media platform instead of stealing other people’s hard work. You didn’t create Emby. You slapped a poorly designed UI on an actively developed open source project and encrypted the installer so you could charge customers subscription fees. if you helped build the open source project maybe it wouldn’t take years to fix issues, eventually telling customers you won’t fix it because you don’t personally use it. Edited January 8, 2023 by DylanDane Explaining
pwhodges 2037 Posted January 8, 2023 Posted January 8, 2023 6 hours ago, DylanDane said: Emby’s development and support staff are the most dismissive and unhelpful I have ever come across. Then you've had a charmed life indeed! Paul 1 1
Carlo 4561 Posted January 9, 2023 Posted January 9, 2023 21 hours ago, DylanDane said: 0This started happening again. Every upload creates a new iPhone Upload library. You’re basically saying the feature isn’t important to you therefore no one really uses it, then telling the FOUR PAGES of people having the same problem to download a different app. An app that requires a separate $200 piece of equipment to work. If people are having issues with emby’s library management, they already have a server where they’re storing files. They don’t need to buy another one to make the software function as advertised. There’s nothing I love more than support staff dismissing valid issues of paying customers as “not important” and then telling them if they want their emby subscription to work they need buy more hardware and use those apps instead. I have worked in tech for over a decade. I’m AWS and Azure certified. Emby’s development and support staff are the most dismissive and unhelpful I have ever come across. If you have a problem it’s either something you’ve set up wrong, you’re not using it the right way, or they don’t use it so they’re not going to fix it. Just a thought - maybe you guys should have developed your own media platform instead of stealing other people’s hard work. You didn’t create Emby. You slapped a poorly designed UI on an actively developed open source project and encrypted the installer so you could charge customers subscription fees. if you helped build the open source project maybe it wouldn’t take years to fix issues, eventually telling customers you won’t fix it because you don’t personally use it. Did you read what I actually wrote? I was not being dismissive in any way. On 7/13/2022 at 7:04 PM, cayars said: I don't disagree with anything you said except the "half assed and broken" part as you might be giving it too much credit. Trying to say this in a positive, vs negative manner, I'd say it's the least useful feature available in Emby Server. I've brought this up internally asking if we could give some TLC to it. That's all I can do is ask. All I did was agree and say it's probably the worst feature presently in Emby and needs some TLC. I also said you might be better off using a different set of programs to sync pictures if a photo library is important to you. That's not dismissive, but my personal opinion and probably a lot of other peoples as well. Not sure what you're talking about in reference to us not creating Emby. You might be thinking of JellyFin which started and still is mostly an earlier version of Emby. Emby is an original piece of work that does make use of some open source projects (ie ffmpeg) and libraries but that's a good thing to do and we help support those projects as well with $ and code. Your last comment makes no sense at all as Emby was open source for a long time under it was taken advantage of. Now it's pseudo open source with parts closed to protect our work. No one said this wouldn't get fixed at some point but it's not one of the main features which gets the most dev time. We're constantly upgrading different parts of the program usually based on what has the biggest impact for most users.
grantsunny 8 Posted January 19, 2024 Posted January 19, 2024 I tried this feature today on latest version of server (4.7.14.0) and hit this problem. Several searches lead me to this thread. If this is eventually be fixed in coming release I will feel great of course. With completely understanding that this can be a less priority of a video server, just leave a message to subscribe it. Perhaps this shall be open sourced as maintained as a separated plug-in or simply a separated project in parallel with Emby? I liked this feature partially because It was actually share the exact same idea based on which I were trying to run a startup project with some dude 10 years before, and we did not continue it due to failure on getting investments.
richlee91 0 Posted January 24, 2024 Posted January 24, 2024 This just happened to me, very frustrating. It created 24 "camera upload" libraries. This is like a time bomb in the program waiting for you to turn it on.
Luke 42262 Posted January 25, 2024 Posted January 25, 2024 The upcoming 4.8 server release has added a new user permission that will allow you to control what users can upload photos.
pwhodges 2037 Posted October 22, 2024 Posted October 22, 2024 3 hours ago, User81 said: Emby Premium. The issue is still not fixed. Since this is your first visit here, you might like to explain what your issue is... Paul
User81 0 Posted October 22, 2024 Posted October 22, 2024 11 hours ago, pwhodges said: Since this is your first visit here, you might like to explain what your issue is... Paul Hi Paul, I think it is obvious what is the issue is, as I posted my comment to the 'Multiple Camera Uploads in the Library' thread. The Issue: Multiple Camera Uplads folders in Library. They can't be deleted neither in Emby environment nor in the system folder.
Luke 42262 Posted October 22, 2024 Posted October 22, 2024 3 hours ago, User81 said: Hi Paul, I think it is obvious what is the issue is, as I posted my comment to the 'Multiple Camera Uploads in the Library' thread. The Issue: Multiple Camera Uplads folders in Library. They can't be deleted neither in Emby environment nor in the system folder. Hi, what version of Emby Server are you running?
User81 0 Posted October 23, 2024 Posted October 23, 2024 12 hours ago, Luke said: Hi, what version of Emby Server are you running? Hi, Please see attached.
Luke 42262 Posted October 23, 2024 Posted October 23, 2024 2 hours ago, User81 said: Hi, Please see attached. Ok if you can delete the duplicate libraries then in the 4.8 server it should not happen again going forward.
User81 0 Posted October 25, 2024 Posted October 25, 2024 On 10/23/2024 at 3:12 PM, Luke said: Ok if you can delete the duplicate libraries then in the 4.8 server it should not happen again going forward. Currently I am not able to get rid of the duplicate folders.
Luke 42262 Posted October 26, 2024 Posted October 26, 2024 4 hours ago, User81 said: Currently I am not able to get rid of the duplicate folders. Hi, what exactly happens when you try?
oldbaytuna 0 Posted November 8, 2024 Posted November 8, 2024 (edited) On 10/25/2024 at 7:06 PM, Luke said: Hi, what exactly happens when you try? Hi Luke. Thanks for your help with this. I also have the same problem and I get the blue circle spinning indefinitely when I try removing any of the Camera Uploads sources. I'm also on Version 4.8.10.0 Edited November 8, 2024 by oldbaytuna
Happy2Play 9814 Posted November 8, 2024 Posted November 8, 2024 12 minutes ago, oldbaytuna said: Hi Luke. Thanks for your help with this. I also have the same problem and I get the blue circle spinning indefinitely when I try removing any of the Camera Uploads sources. I'm also on Version 4.8.10.0 May need to see the corresponding server log as I would expect to see some sort of errors removing the libraries. Thought it was fixed overhear.
