lowe1739 3 Posted April 20, 2021 Posted April 20, 2021 Camera Upload, Multiple Libraries - General/Windows - Emby Community i see i'm not the first...you can ignore this unless you have a fix now?
gioluca2 0 Posted May 19, 2021 Posted May 19, 2021 Are there any news? I'm looking for a google photo alternative...
Micael456 45 Posted May 21, 2021 Posted May 21, 2021 (edited) +1 here as well. Happy to provide any logs to help as I've probably got an odd underlying structure (Ubuntu Emby Server -> Windows NAS). Multiple Camera Uploads libraries (they re-appear like weeds). Underlying folder structure is fine though. One directory per device under the root "EMBY" directory. Edited May 21, 2021 by Micael456 EDIT: Added linux /mnt/apollo/z/ screenshot
diyhouse 0 Posted May 30, 2021 Posted May 30, 2021 I have just started running the latest 4.6.1.0 release,.. on a small Raspberry Pi 4,.. and emby with premiere subscription,.. works a treat, allowing me to access media remotely as well as save my Android Camera Photo media,.. I love it,.. this app is great. However as per this thread I to have multiple camera upload references,.. 16 in total,... but as shown else where the actual folder directories are correct as they only appear once,... I appreciate these things take time to fix with the resources available,.. but my question from a Neebie is what is the outlook for the fix for this issue, ...and is there a way to split uploads from different users phones,.. as although I don't care the wife sees all my pictures,.. but I don't want her picture gallery shown to me mixed with my photos.. ( yes I can see they are in separate folders on my storage device ) is there a way of splitting them when displayed in emby? Many tx guys
skynet600 33 Posted June 14, 2021 Posted June 14, 2021 (edited) I had three CameraUploads in my library. Not sure if it is the same issue as most in this thread since many had a lot more but I tried deleting one anyway. All three disappeared! Checking devices I see two iOS on v2.0.7. Checking their settings one was enabled and one was not which is fine so only expect one in the library. Server settings are standard with no defined path and "create a subfolder" is checked. Server log is riddled with errors but I see CameraUploads is still being watched. Checking folder structure I can see camerauploads/Camera Roll and camerauploads/iphone/Camera Roll exist and both contain images. I now see four CameraUploads libraries all with the same content! Could this be anything to do with the recent rtm issues? 2021-06-14 09:10:02.720 Error App: Image Provider - Error reading image tag for /volume1/Emby/data/camerauploads/Camera Roll/IMG_4053.jpg *** Error Report *** Version: 4.6.2.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25556 SMP PREEMPT Thu Mar 4 18:03:46 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system TagLib.CorruptFileException: TagLib.CorruptFileException: Expected SOI marker at the start of the file. at TagLib.Jpeg.File.ValidateHeader() at TagLib.Jpeg.File.Read(ReadStyle propertiesStyle) at TagLib.File.Create(IFileAbstraction abstraction, String mimetype, ReadStyle propertiesStyle) at Emby.Photos.PhotoProvider.FetchAsync(MetadataResult`1 itemResult, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) Source: Emby.Photos TargetSite: TagLib.File Create(IFileAbstraction, System.String, TagLib.ReadStyle) 2021-06-14 09:07:09.409 Error BaseItem: Error deserializing /volume1/Emby/root/default/Camera Uploads/options.xml *** Error Report *** Version: 4.6.2.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25556 SMP PREEMPT Thu Mar 4 18:03:46 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system System.InvalidOperationException: System.InvalidOperationException: There is an error in XML document (0, 0). ---> System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderLibraryOptions.Read7_LibraryOptions() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader) at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromStream(Type type, Stream stream) at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromFile(Type type, String file) at MediaBrowser.Controller.IO.FileData.GetPathsFromOptionsFile(String path, ILogger logger) Source: System.Private.Xml TargetSite: System.Object Deserialize(System.Xml.XmlReader, System.String, System.Xml.Serialization.XmlDeserializationEvents) InnerException: System.Xml.XmlException: Root element is missing. Source: System.Private.Xml TargetSite: Void Throw(System.Exception) at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderLibraryOptions.Read7_LibraryOptions() Additionally the db is completely screwed. If I click on one image it opens a completely different one. mbyserver.txt Edited June 14, 2021 by skynet600
Luke 42262 Posted June 21, 2021 Posted June 21, 2021 On 6/14/2021 at 4:36 AM, skynet600 said: I had three CameraUploads in my library. Not sure if it is the same issue as most in this thread since many had a lot more but I tried deleting one anyway. All three disappeared! Checking devices I see two iOS on v2.0.7. Checking their settings one was enabled and one was not which is fine so only expect one in the library. Server settings are standard with no defined path and "create a subfolder" is checked. Server log is riddled with errors but I see CameraUploads is still being watched. Checking folder structure I can see camerauploads/Camera Roll and camerauploads/iphone/Camera Roll exist and both contain images. I now see four CameraUploads libraries all with the same content! Could this be anything to do with the recent rtm issues? 2021-06-14 09:10:02.720 Error App: Image Provider - Error reading image tag for /volume1/Emby/data/camerauploads/Camera Roll/IMG_4053.jpg *** Error Report *** Version: 4.6.2.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25556 SMP PREEMPT Thu Mar 4 18:03:46 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system TagLib.CorruptFileException: TagLib.CorruptFileException: Expected SOI marker at the start of the file. at TagLib.Jpeg.File.ValidateHeader() at TagLib.Jpeg.File.Read(ReadStyle propertiesStyle) at TagLib.File.Create(IFileAbstraction abstraction, String mimetype, ReadStyle propertiesStyle) at Emby.Photos.PhotoProvider.FetchAsync(MetadataResult`1 itemResult, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) Source: Emby.Photos TargetSite: TagLib.File Create(IFileAbstraction, System.String, TagLib.ReadStyle) 2021-06-14 09:07:09.409 Error BaseItem: Error deserializing /volume1/Emby/root/default/Camera Uploads/options.xml *** Error Report *** Version: 4.6.2.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25556 SMP PREEMPT Thu Mar 4 18:03:46 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system System.InvalidOperationException: System.InvalidOperationException: There is an error in XML document (0, 0). ---> System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderLibraryOptions.Read7_LibraryOptions() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader) at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromStream(Type type, Stream stream) at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromFile(Type type, String file) at MediaBrowser.Controller.IO.FileData.GetPathsFromOptionsFile(String path, ILogger logger) Source: System.Private.Xml TargetSite: System.Object Deserialize(System.Xml.XmlReader, System.String, System.Xml.Serialization.XmlDeserializationEvents) InnerException: System.Xml.XmlException: Root element is missing. Source: System.Private.Xml TargetSite: Void Throw(System.Exception) at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderLibraryOptions.Read7_LibraryOptions() Additionally the db is completely screwed. If I click on one image it opens a completely different one. mbyserver.txt 1.07 MB · 1 download Try deleting that xml file that it's complaining about and then restarting the server.
skynet600 33 Posted June 22, 2021 Posted June 22, 2021 (edited) Thanks Luke. It has been running for some time now but I restarted the server today and ran all the rescans again for a fresh log. I see multiple new image downloads in alerts so it seems to be working but for the duplicate cameraupload folders. I have two iOS devices listed in the server device list with one not configured to upload so I would expect only one folder. I see the follow in the log now: 2021-06-22 09:01:32.340 Error ImageProcessor: Error encoding image *** Error Report *** Version: 4.6.3.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /volume1/Emby/EmbyServer.pid -updatepackage emby-server-synology_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25556 SMP PREEMPT Thu Mar 4 18:03:46 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system System.Exception: System.Exception: SKCodec had an error reading /volume1/Emby/data/camerauploads/Camera Roll/IMG_0003.jpg at Emby.Drawing.Skia.SkiaEncoder.EncodeImage(String inputPath, String outputPath, Boolean autoOrient, Nullable`1 orientation, Int32 quality, ImageProcessingOptions options, ImageFormat selectedOutputFormat) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) Source: Emby.Drawing.Skia TargetSite: System.String EncodeImage(System.String, System.String, Boolean, System.Nullable`1[MediaBrowser.Model.Drawing.ImageOrientation], Int32, MediaBrowser.Controller.Drawing.ImageProcessingOptions, MediaBrowser.Model.Drawing.ImageFormat) I can't open these files in explorer either. There are plenty of similar sized and formatted files so I guess this is unrelated corruption of some sort. Edited June 22, 2021 by skynet600
Luke 42262 Posted July 2, 2021 Posted July 2, 2021 Yes it looks like we're going to have to update our server image processing libraries to be able to handle newer iOS formats.
SuperNic 4 Posted July 10, 2021 Posted July 10, 2021 Dear @Luke, any news about the issue? When will be possible to use the camera upload feature? At the moment, it's not usable. Thanks a lot!
Luke 42262 Posted July 25, 2021 Posted July 25, 2021 On 7/10/2021 at 10:11 AM, SuperNic said: Dear @Luke, any news about the issue? When will be possible to use the camera upload feature? At the moment, it's not usable. Thanks a lot! Are you still running into multiple camera upload libraries with Emby Server 4.6.4?
Micael456 45 Posted July 25, 2021 Posted July 25, 2021 4 hours ago, Luke said: Are you still running into multiple camera upload libraries with Emby Server 4.6.4? @Luke, mine is still displaying multiples running 4.6.4.0. (screenshots below show the multiples are just the same two over and over). I haven't tried deleting the duplicates to see if they don't come back in 4.6.4 though. I'll give that a try later when I'm at a PC and report back if nobody else has by then.
Luke 42262 Posted July 25, 2021 Posted July 25, 2021 Have multiple libraries been created by 4.6.4 or were they already there?
skynet600 33 Posted July 25, 2021 Posted July 25, 2021 Already there when I went to 4.6.4 and still there.
MEB 27 Posted July 25, 2021 Posted July 25, 2021 2 hours ago, Luke said: Have multiple libraries been created by 4.6.4 or were they already there? Not happening so far anymore on 4.6.4 but I am having a weird issue where it takes many attempts to upload very large videos (5+ gigs) it shows finished then a few seconds later it's started over. I wonder if that's a symptom of the same issue like the app can't tell it finished and tries again. Next time I have some videos upload I'll grab the logs and submit a new issue for it.
GurraG 0 Posted August 15, 2021 Posted August 15, 2021 Still happens with 4.6.4.0 every time one of our mobiles upload a picture or a video. We have camera upload set to /media/Camera/Upload but with subfolder per device checked and with libraries for each device folder. Every time something is uploaded, Emby decides to create a huge amount of libraries for the root upload folder, /media/Camera/Upload, and then indexing of the libraries are broken. I then have to remove several of these automatically created libraries. Every time I remove one, several of them disappears. Finally they are all gone and indexing works again. Since we want separate subfolders and libraries for each device, we have to check that option. The text on the pays says that it should be possible to specify the upload directory per device instead, but it is not. This bug is getting really old now. It should be very easy to reproduce, we do it almost every day! The effect of this bug is IMO that Emby doesn't really have a camera upload function, just an early access preview that looks promising and I hope will be completed in the near future.
masterdot 0 Posted August 23, 2021 Posted August 23, 2021 Same issue here. Tons of librarys created on uploads... So its still a problem I'm a bit surprised its a issue that is so old. Im pretty new to emby and dont know the project very well. How active is the development on emby? Plex seem to have a long time for realizing features (like versions of movies etc). Same on emby?
Luke 42262 Posted August 24, 2021 Posted August 24, 2021 I've made a change for the next release that I'm hoping will help with this. Thanks guys. 2
Carlo 4561 Posted August 24, 2021 Posted August 24, 2021 Can you add the ability to turn off camera upload as well for the server?
Micael456 45 Posted August 26, 2021 Posted August 26, 2021 Just came across something else today when removing permissions which may (or may not) help. It looks like Emby is treating my duplicates as only two different libraries somewhere beneath the hood (as far as permissions are concerned at least), so it might mostly be a visual thing. I've attached a video, you'll see what I mean. 20210826_110006.mp4
skynet600 33 Posted January 5, 2022 Posted January 5, 2022 Any news here please? I am now running 4.6.7 and still have duplicate camera uploads.
Luke 42262 Posted January 5, 2022 Posted January 5, 2022 3 hours ago, skynet600 said: Any news here please? I am now running 4.6.7 and still have duplicate camera uploads. Try removing the extra libraries and then see if it happens again. Thanks.
skynet600 33 Posted January 5, 2022 Posted January 5, 2022 1 hour ago, Luke said: Try removing the extra libraries and then see if it happens again. Thanks. Had four, removed one and three disappeared. Deleted the other one and opened the app on my phone. I can see it syncing but I now also see six camera uploads on the home screen.
skynet600 33 Posted January 14, 2022 Posted January 14, 2022 I did this again Luke and now have one folder so for now all good. Seems a little unpredictable but doesn’t bother me in terms of functionality. Love Emby! 1
bandit8623 230 Posted February 6, 2022 Posted February 6, 2022 (edited) enabled cam upload a few days ago and i have the same problem a ton of folders as the others have posted. 4.6.7.0 Edited February 6, 2022 by bandit8623
