danergo 40 Posted January 11, 2021 Posted January 11, 2021 On 5/14/2020 at 2:05 AM, ebr said: Hi. Upon what are you basing that assumption? Have you tried adjusting the "buffer" setting in the app? Hello, this issue just keep happening all the time. (I haven't used FireTV for some time, but now started using it again). The problem is that my upload where Emby server sits has a marginal upload speed (compared to my videos). But still, even when FireTV keeps freezing, Emby for LG app and Emby Theatre (on Windows) plays nice and smoothly (same media, same server, same internet, and quite-same circumstances). Here is a small presentation of the network bandwidth usage, first with LG TV's native Emby app (green), then FireTV (black). There is a very nice difference between those two: LG's Emby first tries to 'prebuffer', and then keeps playing it, whereas FireTV does not do any buffering. Please note, I was using "Large" buffer size on FireTV Stick while doing this test. And because of this bandwidth usage, and FireTV's behaviour (of skipping buffering), media often stops on FireTV Stick (while keeps perfectly playing on other platforms). As I think there is ExoPlayer who plays media on FireTV Stick, there must be some finetuning option for using heavier buffering especially at startup. (Both cases - green and black - were done with a clean media playback from the beginning). Let me know your thoughts guys, I'm a premier user, and really want to solve this. Cheers, thank you!
ebr 16338 Posted January 11, 2021 Posted January 11, 2021 So these items are transcoding to a lower bitrate than the original?
danergo 40 Posted January 12, 2021 Posted January 12, 2021 8 hours ago, ebr said: So these items are transcoding to a lower bitrate than the original? Forgot to mention - sorry for that. No transcoding in either case at all. Everything is in "Direct Play" mode. If you wish I can post the "Nerd infos" from both players.
danergo 40 Posted January 18, 2021 Posted January 18, 2021 Yes, Luke, nothing has changed: FireTV constantly pauses and continues, while Emby for LG TV (Native app for LG TV) and Theatre on Windows both play fine.
danergo 40 Posted February 20, 2021 Posted February 20, 2021 Luke, do we have some updates on this? Thanks!
Luke 42246 Posted February 20, 2021 Posted February 20, 2021 44 minutes ago, danergo said: Luke, do we have some updates on this? Thanks! Hi, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
danergo 40 Posted February 20, 2021 Posted February 20, 2021 I'm on holiday now, but I will do that, thanks, Luke. Btw, let me ask a bit offtopic here (which is somehow related to here): 1.) Run an Emby Server in PlaceA 2.) Try playing content from PlaceB which is failing due to slow network connection between PlaceA-->PlaceB. 3.) Having something on my computer which is in PlaceB which acts as a proxy: I select in the morning what I want to watch in the evening My computer buffers/downloads this file(s) during the day (as the connection is slow but stable) Emby client plays the files at the evening from the proxy on my computer (assuming Emby Client and my computer are located on the same LAN) Or the proxy can also be the Emby client, that would also help. Do we have anything similar to this functionality? Ps: downgrading to lower bitrate is not helping, as the connection is really slow, so I'd have to really downgrade. If Emby has something like I described, it can easily beat Netflix for me. Thanks!
Luke 42246 Posted February 21, 2021 Posted February 21, 2021 On 2/20/2021 at 7:49 AM, danergo said: I'm on holiday now, but I will do that, thanks, Luke. Btw, let me ask a bit offtopic here (which is somehow related to here): 1.) Run an Emby Server in PlaceA 2.) Try playing content from PlaceB which is failing due to slow network connection between PlaceA-->PlaceB. 3.) Having something on my computer which is in PlaceB which acts as a proxy: I select in the morning what I want to watch in the evening My computer buffers/downloads this file(s) during the day (as the connection is slow but stable) Emby client plays the files at the evening from the proxy on my computer (assuming Emby Client and my computer are located on the same LAN) Or the proxy can also be the Emby client, that would also help. Do we have anything similar to this functionality? Ps: downgrading to lower bitrate is not helping, as the connection is really slow, so I'd have to really downgrade. If Emby has something like I described, it can easily beat Netflix for me. Thanks! Hi, sounds like you want to use either our Windows store app, android app, or iOS app and use the download feature that they have.
danergo 40 Posted February 22, 2021 Posted February 22, 2021 Yes thanks I'm aware of those and can download the file with Windows, but then Emby on FireTV has nothing to do with it unless I install a 2nd Emby Server on my computer too and point the FireTV onto that.
