mikkelmcl 3 Posted December 5, 2019 Posted December 5, 2019 (edited) hi i am having problems with the sound on the player of some of my stuff on chromecast and in the browser-chrome sound running fine on my pc Complete name : \\EMBY\Dansk Tv\Dansktoppen 50 År Format : Matroska Format version : Version 4 File size : 2,29 GiB Duration : 1 t 44 min Overall bit rate : 3.136 kb/s Encoded date : UTC 2018-12-08 23:25:55 Writing application : mkvmerge v29.0.0 ('Like It Or Not') 64-bit Writing library : libebml v1.3.6 + libmatroska v1.4.9 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Ja Format settings, Reference frames : 5 billeder Codec ID : V_MPEG4/ISO/AVC Duration : 1 t 44 min Bit rate : 2.942 kb/s Width : 1.280 billedpunkter Height : 720 billedpunkter Display aspect ratio : 16:9 Frame rate mode : Konstant Frame rate : 25,000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressiv Bits/(Pixel*Frame) : 0.128 Stream size : 2,15 GiB (94%) Writing library : x264 core 157 r2935 545de2f Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : Dansk Default : Ja Forced : Nej Lyd ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : A_MPEG/L2 Codec ID/Hint : MP2 Duration : 1 t 44 min Bit rate mode : Konstant Bit rate : 192 kb/s Channel(s) : 2 kanaler Sampling rate : 48,0 kHz Frame rate : 41,667 FPS (1152 SPF) Compression mode : Lossy Stream size : 143 MiB (6%) Language : Dansk Default : Ja Forced : Nej log.txt Edited December 5, 2019 by mikkelmcl
Luke 42216 Posted December 5, 2019 Posted December 5, 2019 Hi there, can you please describe he problem that you're having? Thanks.
mikkelmcl 3 Posted December 5, 2019 Author Posted December 5, 2019 when i play a movie on chromecast there is no sound with the fun, not all movies happen by it is only a few, and on my pc there is no problem at all with the sound
Luke 42216 Posted December 5, 2019 Posted December 5, 2019 Please attach an ffmpeg log example. thanks.
mikkelmcl 3 Posted December 6, 2019 Author Posted December 6, 2019 no ffmpeg came out when i had restarted the emby and start the movie but a hardware came up and ffmpeg is from tonight log.txt log 2.txt
Luke 42216 Posted December 7, 2019 Posted December 7, 2019 Is this only with files that have mp2 audio?
mikkelmcl 3 Posted December 7, 2019 Author Posted December 7, 2019 it may well fit here is an info more to look at. just found out they can play with audio on iphone xr Format : Matroska Format version : Version 4 File size : 1.37 GiB Duration : 58 min 19 s Overall bit rate : 3 361 kb/s Encoded date : UTC 2014-12-23 21:36:12 Writing application : mkvmerge v6.9.1 ('Blue Panther') 64bit built on Apr 18 2014 18:23:38 Writing library : libebml v1.3.0 + libmatroska v1.4.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 58 min 19 s Bit rate : 3 039 kb/s Width : 1 280 pixels Height : 718 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.132 Stream size : 1.24 GiB (90%) Writing library : x264 core 142 r2491 24e4fed Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : Danish Default : Yes Forced : No Audio ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : A_MPEG/L2 Codec ID/Hint : MP2 Duration : 58 min 19 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Compression mode : Lossy Stream size : 107 MiB (8%) Language : Danish Default : Yes Forced : No
Luke 42216 Posted December 7, 2019 Posted December 7, 2019 Thanks. I think it's an issue with mp2 where we are direct playing the audio and we need to transcode it.
Solution mikkelmcl 3 Posted December 19, 2019 Author Solution Posted December 19, 2019 (edited) then there is audio again with version 4.3.1.0 update 1000 thanks for the help Edited December 19, 2019 by mikkelmcl 1
