Ratatouille 14 Posted December 5, 2019 Posted December 5, 2019 192 kbts 48 6 channel aac Advanced Audio Codec Low Complexity Sound not decoded but are decoded on Samung TV Emby app No problem with 384 kbs 48 6 channel AC3 dolby640 kbs 6 channel ac3 dolby
Luke 42246 Posted December 5, 2019 Posted December 5, 2019 Hi there, can you describe the problem a little bit more? I don't quite understand the issue. Thanks !
Ratatouille 14 Posted December 5, 2019 Author Posted December 5, 2019 When I say not decoded I mean my amplifier instead to go to digital sounds 5.1 or 6.1 goes to two channels sound (stereo) Sent from my PH-1 using Tapatalk
ebr 16338 Posted December 5, 2019 Posted December 5, 2019 Hi. How are the devices connected? Some connections wouldn't support multi-channel AAC/PCM.
Ratatouille 14 Posted December 5, 2019 Author Posted December 5, 2019 Well not sure about it shield connected directly to tv hdmi1 witch is directly connected to amplifier by hdmi audio return arc In this configuration 5.1 on shield Netflix, Plex are working even emby app from Samsung tv Sent from my PH-1 using Tapatalk
Luke 42246 Posted December 5, 2019 Posted December 5, 2019 Hi there, can we look at an example of what you're playing? How to report a media playback issue. thanks.
ebr 16338 Posted December 5, 2019 Posted December 5, 2019 Yes, I would like to see an example as well but I don't think standard ARC supports multi-channel PCM. Have you thought about connecting the Shield to the AVR and then take the video out from there to the TV?
Guest asrequested Posted December 6, 2019 Posted December 6, 2019 You really should have an option to transcode non bitstreamed audio with 3 channels or more, to AC3 384Kb/s.
Ratatouille 14 Posted December 7, 2019 Author Posted December 7, 2019 You really should have an option to transcode non bitstreamed audio with 3 channels or more, to AC3 384Kb/s. Is this option in emby app for shield? By the way I connected the shield directly does not make any difference exept neflix on the receiver says" Digital Plus" instead of "Digital"
Guest asrequested Posted December 8, 2019 Posted December 8, 2019 Is this option in emby app for shield? There isn't an option for that anywhere, that's why I'm suggesting it. Have you thought about connecting the Shield to the AVR and then take the video out from there to the TV? By the way I connected the shield directly does not make any difference exept neflix on the receiver says" Digital Plus" instead of "Digital" So you connected the shield to your receiver and your 6 channel AAC came out in stereo?
