denethor 90 Posted December 4, 2019 Posted December 4, 2019 Hi there, long time no see! Hoping everyone doing great. After jurialmunkey released Arctic Zephyr 2 skin I' ve started to use my Kodi+Emby setup again. I am running on 18.5 Leia/Windows 10 and 4.1.16 version of the Kodi Add-on. Emby backend is on 4.3.0.30 stable version. When I manually try to update thememedia (for using Tvtunes both script and newly introduced service version.) I got below errors on Kodi log. Both Kodi client and Emby server is on the same LAN. Emby server is accessible via Web browser without any problems. (looks like I don't have firewall issue on server) 2019-12-04 00:46:39.612 T:23528 NOTICE: Emby.emby.core.connection_manager -> testing connection mode 2 with server ServerName 2019-12-04 00:46:39.616 T:23528 NOTICE: Emby.emby.core.connection_manager -> tryConnect url: http://{emby-server}/emby/system/info/public 2019-12-04 00:46:39.679 T:23528 NOTICE: Emby.emby.core.connection_manager -> calling onSuccessfulConnection with connection mode 2 with server ServerName 2019-12-04 00:46:39.741 T:23528 NOTICE: Emby.emby.client -> User is authenticated. 2019-12-04 00:46:39.914 T:1116 NOTICE: Emby.emby.core.ws_client -> Websocket url: ws://{emby-server}/embywebsocket?api_key={emby-token}&device_id=AC262A228CBC4A0E84E0B8691Cxxxxxxx 2019-12-04 00:46:39.921 T:11020 NOTICE: EMBY.hooks.monitor -> -->[ q:monitor/LoadServer ] 2019-12-04 00:46:39.923 T:11020 NOTICE: EMBY.hooks.monitor -> --[ post capabilities/ab830a458c254fc2b52e67dxxxxxxxxx ] 2019-12-04 00:46:39.943 T:23528 NOTICE: EMBY.setup -> ---<[ setup ] 2019-12-04 00:46:39.971 T:18592 NOTICE: EMBY.library -> --->[ library ] 2019-12-04 00:46:39.978 T:1116 NOTICE: Emby.emby.core.ws_client -> --->[ websocket ] 2019-12-04 00:46:40.263 T:21376 NOTICE: EMBY.entrypoint.service -> [ onNotification/plugin.video.emby/ServerOnline ] 2019-12-04 00:46:40.667 T:20600 ERROR: Window Translator: Can't find window videolibrary 2019-12-04 00:46:41.671 T:12908 NOTICE: script.tv.show.next.aired --> Update complete 2019-12-04 00:46:42.241 T:18592 NOTICE: EMBY.database -> [emby] 1 rows updated. 2019-12-04 00:46:43.837 T:20600 NOTICE: Previous line repeats 11 times. 2019-12-04 00:46:43.837 T:20600 ERROR: Window Translator: Can't find window videolibrary 2019-12-04 00:46:44.168 T:18592 NOTICE: EMBY.helper.wrapper -> Processing None 2019-12-04 00:46:44.174 T:18592 NOTICE: EMBY.library -> --[ retrieve changes ] 2019-12-03T21:14:17z 2019-12-04 00:47:33.699 T:20600 ERROR: Window Translator: Can't find window videolibrary 2019-12-04 00:47:38.474 T:10384 WARNING: Unable to determine channel type. Defaulting to TV. 2019-12-04 00:47:59.877 T:20200 WARNING: Previous line repeats 2 times. 2019-12-04 00:47:59.877 T:20200 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 2019-12-04 00:47:59.935 T:20200 NOTICE: EMBY.entrypoint.default -> path: params: {} 2019-12-04 00:47:59.971 T:20200 NOTICE: EMBY.default -> ---<[ default ] 2019-12-04 00:48:06.135 T:8948 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 2019-12-04 00:48:06.192 T:8948 NOTICE: EMBY.entrypoint.default -> path: ?mode=managelibs params: { "mode": "managelibs" } 2019-12-04 00:48:06.215 T:8948 NOTICE: EMBY.default -> ---<[ default ] 2019-12-04 00:48:08.733 T:15968 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 2019-12-04 00:48:08.791 T:15968 NOTICE: EMBY.entrypoint.default -> path: ?mode=thememedia params: { "mode": "thememedia" } 2019-12-04 00:48:08.828 T:15968 NOTICE: EMBY.entrypoint.default -> TV Tunes custom path is enabled and set. 2019-12-04 00:48:38.552 T:10384 WARNING: Unable to determine channel type. Defaulting to TV. 2019-12-04 00:51:14.060 T:15968 WARNING: Previous line repeats 8 times. 2019-12-04 00:51:14.060 T:15968 NOTICE: Emby.emby.core.http -> ERROR:: HTTPConnectionPool(host='192.168.1.10', port=8096): Read timed out. (read timeout=30) 2019-12-04 00:51:14.061 T:15968 NOTICE: EMBY.default -> ERROR:: Traceback (most recent call last): File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 41, in <module> Events() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\entrypoint\default.py", line 176, in __init__ get_themes() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\entrypoint\default.py", line 977, in get_themes result = EMBY['api'].get_items_theme_video(view) File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 249, in get_items_theme_video 'Recursive': True File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 86, in users return self._get("Users/{UserId}%s" % handler, params) File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 53, in _get return self._http("GET", handler, {'params': params}) File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\api.py", line 50, in _http return self.client.request(request) File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\libraries\emby\core\http.py", line 129, in request raise HTTPException("ReadTimeout", error) HTTPException 2019-12-04 00:51:14.061 T:15968 NOTICE: EMBY.default -> ---<[ default ] 2019-12-04 00:51:38.741 T:10384 WARNING: Unable to determine channel type. Defaulting to TV. Any idea about what is wrong with the sync?
Angelblue05 4132 Posted December 5, 2019 Posted December 5, 2019 What is your server version? How many themes do you have?
denethor 90 Posted December 5, 2019 Author Posted December 5, 2019 What is your server version? How many themes do you have? 1198 theme.mp4 video files 2180 theme.mp3 audio files. Server version 4.3.0.30. I saw 50000-60000ms response times for Kodi addon HTTP Requests in Emby server log but no timeouts in server side. I cant access my server logs right now. I will try to provide those logs in 4-6hrs. 1
Angelblue05 4132 Posted December 5, 2019 Posted December 5, 2019 Ok, that is a lot. I will fix this for the next update. Thanks for your patience. 1
denethor 90 Posted December 5, 2019 Author Posted December 5, 2019 (edited) I have seen the Github issue entry that marks this post as a bug. Below are the examples from my server log. This may help you see what sort of times required to get that data: 2019-12-05 19:11:07.553 Info HttpServer: HTTP Response 200 to 192.168.1.135. Time: 760578ms. http://192.168.1.10:8096/emby/Users/3eff8a317d0ecf2ca5650xxxxxxxxxxx/Items?HasThemeVideo=True&Recursive=True&ParentId=f45cf9dbb754812dcedc518e20xxxxx 2019-12-05 19:11:29.862 Info HttpServer: HTTP Response 200 to 192.168.1.135. Time: 751845ms. http://192.168.1.10:8096/emby/Users/3eff8a317d0ecf2ca5650xxxxxxxxxxx/Items?HasThemeVideo=True&Recursive=True&ParentId=f45cf9dbb754812dcedc518e20xxxxx2019-12-05 19:11:37.949 Info HttpServer: HTTP Response 200 to 192.168.1.135. Time: 728886ms. http://192.168.1.10:8096/emby/Users/3eff8a317d0ecf2ca5650xxxxxxxxxxx/Items?HasThemeVideo=True&Recursive=True&ParentId=f45cf9dbb754812dcedc518e20xxxxx Edited December 7, 2019 by denethor 1
Angelblue05 4132 Posted December 6, 2019 Posted December 6, 2019 Can you try this build and let me know if it lets you get further? Thanks. plugin.video.emby-4.1.18b.zip 1
denethor 90 Posted December 6, 2019 Author Posted December 6, 2019 (edited) Can you try this build and let me know if it lets you get further? Thanks. Looks like you nailed it! Here is the stats for the process: First entry in kodi.log: 2019-12-06 10:07:33.932 T:8792 NOTICE: EMBY.entrypoint.default -> TV Tunes custom path is enabled and set. First folder created in "..\userdata\addon_data\plugin.video.emby\library\" Looks like it took 23min to complete: Friday, December 6, 2019, 10:30:48 AM Number of folders created in above library folder: 3215 (some library items have both theme song and theme video) Only thing I can complain about there was no log entry in kodi.log during the whole process therefore I couldn't monitor what was going on during the sync. I was curious about "should I wait more or cancel it and re-try" I will try the sync on my Nvidia Shield on evening and let you know about the results. This test was done on Windows box. Thank you very much for the quick response and fix Edit: Same process took only 3 minutes in Nvidia Shield. I don't know if you did some kind of caching on server side or my network was slow during the sync in Windows. Edited December 6, 2019 by denethor 1
