ebr 16331 Posted December 18, 2019 Posted December 18, 2019 Sorry, I missed your question. My guess is maybe you didn't install the XML plug-in?
tp546 41 Posted December 18, 2019 Author Posted December 18, 2019 Yeah i think that's probably true. I'll check tonight if I have a chance.
tp546 41 Posted December 20, 2019 Author Posted December 20, 2019 Okay I didn't have the xml plugin installed so I just installed it and restarted the server. There are no settings for the plugin - how do I get it to import my xml data?
Luke 42237 Posted December 21, 2019 Posted December 21, 2019 Okay I didn't have the xml plugin installed so I just installed it and restarted the server. There are no settings for the plugin - how do I get it to import my xml data? There are none needed. Now all you have to do is add new content into Emby Server with pre-existing xml files and then it will be used. Since you've already imported content this is a little tricky and we don't have a great way for you to do this. You might want to remove the library, run a full scan to flush out the database, then add it back. Consider switching to nfo files as this is the format built into Emby Server and this is what gets the majority of testing.
tp546 41 Posted December 21, 2019 Author Posted December 21, 2019 If I delete everything, won't I lose all my viewing history and favorites? When did the transition happen from xml to nfo and how was it handled at the time?
Luke 42237 Posted December 21, 2019 Posted December 21, 2019 When did the transition happen from xml to nfo and how was it handled at the time? 4-5 years ago. It's been a long time. If I delete everything, won't I lose all my viewing history and favorites? Most likely not.
tp546 41 Posted December 21, 2019 Author Posted December 21, 2019 Gotcha. Obviously I haven't been paying close attention for a while. How did you originally transition people over?
ebr 16331 Posted December 21, 2019 Posted December 21, 2019 Gotcha. Obviously I haven't been paying close attention for a while. How did you originally transition people over? Back then, the server still contained more logic to handle xml. Over the years, we have weaned it out.
