MrSmile 0 Posted December 3, 2019 Posted December 3, 2019 Hi thanks for your nice apps. android app have problem with Persian subtitle. this font is bad and some alphabets doesn't show correctly (like what you see in the attached photo) we have bad font in the web and TV too. but they can show all alphabets Please change this fonts, I suggest to use "B Koodak" font for Persian subtitles as default. it's most popular font for subtitles in the Persian.
Luke 42244 Posted December 3, 2019 Posted December 3, 2019 Hi, is the only problem the missing characters?
MrSmile 0 Posted December 3, 2019 Author Posted December 3, 2019 Hi, is the only problem the missing characters? Major problem is this. but minor problem is this font isn't a Persian font (maybe Arabic, I'm not sure) and it's hard to read.
Luke 42244 Posted December 3, 2019 Posted December 3, 2019 Can you zip up the subtitle file and attach it here? we can add the missing characters to our font. Thanks.
MrSmile 0 Posted December 3, 2019 Author Posted December 3, 2019 I attached a subtitle what I screened before. and "B koodak" font also attached a subtitle with coded "B Koodak" font. it works on Emby android very well. (not in web player and didn't test on LG TV) maybe these make better help. but as I saw before it's not problem with an alphabet! I saw it with another characters too, but don't remember which. Subtitle.zip
MrSmile 0 Posted December 4, 2019 Author Posted December 4, 2019 Android Mobile I haven't Android TV to check it there.
Luke 42244 Posted December 4, 2019 Posted December 4, 2019 Hmm, well that's strange because the web app and android mobile are using the same font file. Can you try the online web app: http://app.emby.media Please let me know how that compares. Thanks.
MrSmile 0 Posted December 4, 2019 Author Posted December 4, 2019 same frame in web player I checked android mobile font problem in different phones and it's same(Nokia 6.1 plus and Samsung A70)
MrSmile 0 Posted December 4, 2019 Author Posted December 4, 2019 (edited) In the web player? Yes In android phones(app)? No Edited December 4, 2019 by MrSmile
Luke 42244 Posted December 4, 2019 Posted December 4, 2019 In the phones? No Web player on the phone, or android app on the phone?
MrSmile 0 Posted December 4, 2019 Author Posted December 4, 2019 (edited) Edited December 4, 2019 by MrSmile
Luke 42244 Posted April 22, 2020 Posted April 22, 2020 Did you guys fixed the problem ?? Hi there, are you having an issue?
ayoubmst7 0 Posted April 22, 2020 Posted April 22, 2020 yeah, i have the same issue on emby app on android. i already ask about it but no answer https://emby.media/community/index.php?/topic/84774-change-subtitle-font/
MrSmile 0 Posted December 7, 2020 Author Posted December 7, 2020 it's got well, but still not fine! some characters still don't fix (attached photo). the font is barely readable!!! the major problem (as the first post in this topic) not changed a little while playing with DLNA and seeing too many box characters in subtitles! (I would send a photo about it later)
Luke 42244 Posted December 7, 2020 Posted December 7, 2020 3 minutes ago, MrSmile said: it's got well, but still not fine! some characters still don't fix (attached photo). the font is barely readable!!! the major problem (as the first post in this topic) not changed a little while playing with DLNA and seeing too many box characters in subtitles! (I would send a photo about it later) Dlna? This topic is about the android app. What about playing inside the android app?
MrSmile 0 Posted December 7, 2020 Author Posted December 7, 2020 (edited) 5 minutes ago, Luke said: Dlna? This topic is about the android app. What about playing inside the android app? attached photo here are from android app. have I create new topics for the other players and problem with Persian subtitles? web player (problem is same as android app, posted before), DLNA (as said), barely readable font (request to change the font) Edited December 7, 2020 by MrSmile
MrSmile 0 Posted December 7, 2020 Author Posted December 7, 2020 this screen took from a normal player. with an easily readable font (a usual font we are using in Persian subtitles)
MrSmile 0 Posted December 7, 2020 Author Posted December 7, 2020 6 hours ago, Luke said: Dlna? This topic is about the android app. What about playing inside the android app? and here it is what I'm talking about the barely readable Persian font in Emby Media player:
Luke 42244 Posted December 15, 2020 Posted December 15, 2020 Hi, have you tried with Emby for Android 3.1.69? How does that compare?
MrSmile 0 Posted December 15, 2020 Author Posted December 15, 2020 (edited) 11 hours ago, Luke said: Hi, have you tried with Emby for Android 3.1.69? How does that compare? as you can see here. can I ask for a feature to have an advanced subtitle options like add or changing fonts? where can I ask it? and also about DLNA font problem too (it's like old android version with too many boxes text) Edited December 16, 2020 by MrSmile
Luke 42244 Posted December 25, 2020 Posted December 25, 2020 Hi, yes we can expand on subtitle options in future updates. thanks for the feedback.
