cncb 25 Posted December 1, 2019 Posted December 1, 2019 I'm pretty sure for my movie media stubs the app used to display a red "Offline" banner icon on the corner of the grid poster. I think it also displayed the duration of the movie in the details but both are missing in the current version of the app.
ebr 16338 Posted December 1, 2019 Posted December 1, 2019 The duration is unknown unless you enter it in the metadata manager (which you may not even be able to do anymore). How do these items look in the web app?
cncb 25 Posted December 2, 2019 Author Posted December 2, 2019 There is no identification for stubs in the web app either. Only missing duration and message to insert the disc when you try to play it. I don't see a duration field in the metadata manager.
Luke 42246 Posted December 2, 2019 Posted December 2, 2019 I don't believe we've ever had a way to supply a duration for stubs.
cncb 25 Posted December 3, 2019 Author Posted December 3, 2019 OK, I can just put the duration somewhere in the description. But I am pretty sure there used to be a red banner on the thumbnails identifying stubs in grid views.
ebr 16338 Posted December 3, 2019 Posted December 3, 2019 Yes, we did have that but it has been gone (system wide) for a few versions now.
cncb 25 Posted December 3, 2019 Author Posted December 3, 2019 I guess that means it is not coming back?
Luke 42246 Posted December 3, 2019 Posted December 3, 2019 It's something that can be reviewed in future updates, it's just that this feature has such a small audience that we're not able to allocate a whole lot of time towards it.
cncb 25 Posted December 4, 2019 Author Posted December 4, 2019 I understand, but why make the effort to remove it in the first place?
ebr 16338 Posted December 4, 2019 Posted December 4, 2019 In cases like this, it isn't usually where we went to some effort to remove something. It is that we didn't spend the extra effort required to be sure it still worked in conjunction with other improvements/changes that were happening. Thanks.
cncb 25 Posted December 11, 2019 Author Posted December 11, 2019 Would you consider displaying the generic "Tags" somehow? Maybe in the details at the top when the movie is selected? I would want to use this to identify movies I have that are streaming-only (Vudu) as well as 3D disks that I have to put in. Thanks.
ebr 16338 Posted December 12, 2019 Posted December 12, 2019 We will be adding Tags, yes. I believe he was asking for some sort of automatic tag for a stub item.
cncb 25 Posted December 12, 2019 Author Posted December 12, 2019 I believe he was asking for some sort of automatic tag for a stub item. No, I was just asking for the display of the Tags I add manually.
ebr 16338 Posted December 13, 2019 Posted December 13, 2019 No, I was just asking for the display of the Tags I add manually. Okay, sorry, yes that will be coming.
