srolomc 2 Posted December 1, 2019 Posted December 1, 2019 I am currently running into an issue where the thumbnail image extraction task runs for less than a second and does not seem to do anything. Here is the information for my Emby instance: OS: Fedora 31 (using Docker container) Emby Version: 4.3.0.30 I also have have both "Enable thumbnail image creation" and "Save thumbnail images into media folders" checked in each library, and I believe that permissions on the directories are correct. Are there any recommended steps for debugging this besides looking at the log? The log does not show any errors that I can see around the time where thumbnail extraction was initiated (enabled debug logging did not show any more information related to this issue). The latest log where I tried running this is attached to this post. Thanks for the help!
Luke 42246 Posted December 1, 2019 Posted December 1, 2019 Hi there, please discuss an example and see how to report a problem. thanks.
srolomc 2 Posted December 1, 2019 Author Posted December 1, 2019 Thanks Luke, here is what I am trying to do: I wanted to have thumbnails on my Roku for seeking through video, so I selected the thumbnail options in my media libraries: When I try to run the Thumbnail image extraction task, I see: The thumbnail extraction says that it only takes one second. The log (attached to this post) only shows the following: 2019-12-01 15:37:30.753 Info TaskManager: Executing Thumbnail image extraction 2019-12-01 15:37:30.754 Info HttpServer: HTTP Response 204 to 192.168.1.27. Time: 5ms. http://192.168.1.21:8096/emby/ScheduledTasks/Running/1897e90bf232ef53a95bd5f5f523f8cd 2019-12-01 15:37:30.759 Info HttpServer: HTTP GET http://192.168.1.21:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:70.0) Gecko/20100101 Firefox/70.0 2019-12-01 15:37:30.760 Info HttpServer: HTTP Response 200 to 192.168.1.27. Time: 1ms. http://192.168.1.21:8096/emby/ScheduledTasks?isHidden=false 2019-12-01 15:37:31.558 Info TaskManager: Thumbnail image extraction Completed after 0 minute(s) and 0 seconds It appears that nothing is actually running when I try to run the scheduled task (at least from what I can see in the log), so I was just wondering if anyone else has run into this or if there is possibly any extra setup that I need to get this running.
Luke 42246 Posted December 4, 2019 Posted December 4, 2019 I can only guess that you may have had some files that failed to extract thumbnails for. Occasionally this may happen with certain files. @@Happy2Play can you link him to your instructions on how to check the contents of the failure file? Thanks !
Happy2Play 9814 Posted December 4, 2019 Posted December 4, 2019 @@Luke why is the Recorded Movies options different for Thumbnails above? @@srolomc Is there a "thumbnail-failures.txt" in your Emby cache folder? You can see your Emby cache path on the Dashboard.
JaScoMa 34 Posted December 4, 2019 Posted December 4, 2019 Also check the thumbnail-failures.txt file within your cahce folder; /var/lib/emby/cache. I had issues where it wouldn't create the files for movies and found them listed here. Deleting the contents of this file will tell emby to try and re-create images for these failed shows, movies, etc. 1
Luke 42246 Posted December 4, 2019 Posted December 4, 2019 @@Luke why is the Recorded Movies options different for Thumbnails above? @@srolomc Is there a "thumbnail-failures.txt" in your Emby cache folder? You can see your Emby cache path on the Dashboard. He probably didn't use the toggle to show advanced options. 1
miblo69 0 Posted December 5, 2019 Posted December 5, 2019 Hi All, I have the same issue as OP. Looking into the file thumbnail.failures.txt - I can see 54 of files failing. The strange thing is I have around 2400 files to be Thumbnailed, but around 95% of the thumbnails do not show up. Only a green/yellow/orange/red square. I have organized my movies in multiple subdirectories - and I get a feeling only Thumbnails in the root directory are generated. I do have spaces and non-ASCII characters in both directory and file names, whihc have been known to cause issues on other systems (Piwigo comes to mind for Photos. Athough now it's mostly resolved). But I am not seeing any error anywhere to give an indication of *why* the Thumbnailing fails. embyserver.txt gives no additional clues. And strangest of all - I can still stream the movies flawlessly. It's just the Thumbnailing that fails. Let me know what you need and I provide for troubleshooting. Thanks.
Luke 42246 Posted December 5, 2019 Posted December 5, 2019 we'd have to look at some examples of files that aren't getting thumbnails. thanks.
srolomc 2 Posted December 7, 2019 Author Posted December 7, 2019 @@Happy2Play Sorry I haven't been back to the thread in a few days, work has been crazy this week; I do appreciate the quick responses. So I did check for the "thumbnail-failures.txt" file, I do not see one in the cache directory. Any other information I can provide to help debug the issue? Also I think I put it in the original post, but I am using the Docker container for Emby instead of the service. Also, here is the thumbnail info with the Advanced options checked:
Happy2Play 9814 Posted December 8, 2019 Posted December 8, 2019 @@Happy2Play Sorry I haven't been back to the thread in a few days, work has been crazy this week; I do appreciate the quick responses. So I did check for the "thumbnail-failures.txt" file, I do not see one in the cache directory. Any other information I can provide to help debug the issue? Also I think I put it in the original post, but I am using the Docker container for Emby instead of the service. Also, here is the thumbnail info with the Advanced options checked: Have you done a search in your /metadata/library folder for bif files? Have you tried removing a item from your media folder, doing a library scan ensuring it no longer exist in Emby, then re-adding it and doing another library scan to add it. The run the Thumbnail image extraction task? I believe all the logging for the primarily resides in debug logging (server needs to be restarted when this option in enabled or disabled) as "quick-extract-imageseries" logs are only created with debug logging enabled.
srolomc 2 Posted December 8, 2019 Author Posted December 8, 2019 So it looks like for some of my libraries, the bif files are being stored in the metadata/library folder where you suggested that I look, but some of them are being stored in the actual media folders. I did double check the thumbnail settings for each library, and they do appear to be the same. The media in question are new files, so I did not try removing them and re-adding them since they are already new. All in all it does appear that the bif files are created and present for the media in question, but I am not sure why they are being stored in the metadata directory instead of the respective media directories?
Happy2Play 9814 Posted December 8, 2019 Posted December 8, 2019 So it looks like for some of my libraries, the bif files are being stored in the metadata/library folder where you suggested that I look, but some of them are being stored in the actual media folders. I did double check the thumbnail settings for each library, and they do appear to be the same. The media in question are new files, so I did not try removing them and re-adding them since they are already new. All in all it does appear that the bif files are created and present for the media in question, but I am not sure why they are being stored in the metadata directory instead of the respective media directories? All I can really suggest is posting server log when you add a new item and perform the Thumbnail image extraction task. But it sounds like a permissions issue as I am pretty sure almost all tasks will fallback to the /metadata/library folder when Emby can not write to media folders. If bif files exist in /library, you would have to delete them for there to be regenerated in media folders assuming there are no permissions issues. 1
Luke 42246 Posted December 8, 2019 Posted December 8, 2019 Yes that's what will happen if you enable the option but the server is denied write access to the media folder.
Solution srolomc 2 Posted December 8, 2019 Author Solution Posted December 8, 2019 Ok so I think it did end up being a permissions problem, it's good to know that it will fall back to the metadata folder when there are issues like this. I removed one of the thumbnail files in the metadata folder, re-ran the thumbnail task, and it generated and stored the bif file in the expected directory. Thanks for the help guys! 1
