Cosmetic Issue with Menu
kingy444
No big issue, figured i would point it out since i i noticed it
The Top left hand corner has the Name of the Section you are currently in next to the menu button.
When in the MetaData Manager you can click the title of the item you are viewing which will in turn return you to the item you are editing in the library.
When you click this link the name in the top left hand corner does not change to the items Collection Name but instead stays as MetaData Manager
