johnvick 1 Posted December 1, 2019 Posted December 1, 2019 Hi I'm using v 4.3.0.30 but this problem started before this version. The home screen has become populated with half-watched episodes in the continue watching section. It used to be possible to get rid of these by clicking / unclicking the watched status tick but this does not get rid of them any more. If I play the episode and slide the bar to the end it disappears from the continue watching section, but another half-watched episode replaces it. Any way to fix? John
chef 3811 Posted December 1, 2019 Posted December 1, 2019 John, New half-watched items should populate the continue watching section. So that seems to be working as expected. Clicking the check mark doesn't remove the item from the list? This is the web app?
Happy2Play 9814 Posted December 1, 2019 Posted December 1, 2019 (edited) Do you use the Trakt Plugin? https://emby.media/community/index.php?/topic/79679-trakt-having-random-watch-progress/ Edited December 1, 2019 by Happy2Play
johnvick 1 Posted December 1, 2019 Author Posted December 1, 2019 I refreshed the metadata as suggested in another post and now if I mark a show as watched is goes from the continue watching section. The new half-watched shows that appear are all stuff that has been watched and marked as watched so they shouldn't be there at all? Yes I use Trakt plugin and the Kodi plugin. I see from the link above this is a common problem - Trying out TraktRater. Thanks for the tips hopefully this will sort it out.
