wazany 0 Posted November 30, 2019 Posted November 30, 2019 (edited) Bonjour, j'utilise emby via un docker depuis quelques semaines il n'arrive plus a mettre a jour les metadata ni meme ce connecter via emby connect.Par contre l'acces a distance fonctionne parfaitement. Du coup je ne sais pas trop quoi faire :/. Error App: Error in TheMovieDb *** Error Report *** Version: 4.2.1.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.9.0.6 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll Processor count: 6 Program data path: /config Application directory: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://api.themoviedb.org/3/tv/67178/season/1/episode/9?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=en&include_image_language=en,null timed out ---> System.OperationCanceledException: The operation was canceled. at System.Net.Http.HttpClient.HandleFinishSendAsyncError(Exception e, CancellationTokenSource cts) at System.Net.Http.HttpClient.FinishSendAsyncBuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MovieDb.MovieDbProvider.GetMovieDbResponse(HttpRequestOptions options) at MovieDb.MovieDbProviderBase.FetchMainResult(String urlPattern, String id, Int32 seasonNumber, Int32 episodeNumber, String language, String country, CancellationToken cancellationToken) at MovieDb.MovieDbProviderBase.DownloadEpisodeInfo(String id, Int32 seasonNumber, Int32 episodeNumber, String preferredMetadataLanguage, String preferredMetadataCountry, CancellationToken cancellationToken) at MovieDb.MovieDbProviderBase.GetEpisodeInfo(String seriesTmdbId, Int32 season, Int32 episodeNumber, String preferredMetadataLanguage, String preferredMetadataCountry, CancellationToken cancellationToken) at MovieDb.MovieDbEpisodeProvider.GetMetadata(EpisodeInfo info, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.OperationCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void HandleFinishSendAsyncError(System.Exception, System.Threading.CancellationTokenSource) at System.Net.Http.HttpClient.HandleFinishSendAsyncError(Exception e, CancellationTokenSource cts) at System.Net.Http.HttpClient.FinishSendAsyncBuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) Edited November 30, 2019 by wazany
Luke 42240 Posted November 30, 2019 Posted November 30, 2019 Bonjour, veuillez joindre le journal complet du serveur Emby. Merci.
wazany 0 Posted November 30, 2019 Author Posted November 30, 2019 (edited) Et voila lorsque j'ouvre la console (f12) j'ai ces messages d'erreur GET ...ndd/Items/79382/Images/Thumb?maxWidth=258&tag=57e6d95301baca20ac56263bf2062ea9&quality=90 500 (Internal Server Error) embyserver.txt Edited November 30, 2019 by wazany
Luke 42240 Posted November 30, 2019 Posted November 30, 2019 Toutes les communications sortantes établies par le serveur échouent vers tous les domaines. Un élément bloquant les connexions, tel qu'un logiciel de sécurité, un pare-feu ou un VPN, doit être bloqué.
wazany 0 Posted December 3, 2019 Author Posted December 3, 2019 Je pense avoir idendtifié le probleme. Ca serais du au manque d'espace sur ma vm j'ai fait de la place c'est reparti merci
