Remote access help please
Hi.
i'm      using a virgin media hub 3 trying to set up port forwarding,what do i enter in the blanks,i know my ip address part
thanks
Edited by rags21
Local IP192.168.0.
IP address is invalid.
Local start port
Local end port
External start port
External end port
ProtocolPlease chooseTCPUDPBoth
Please choose
EnabledPlease chooseOffOn
Please choose
This IS the port triggeri
Port triggering
The Port Triggering area allows you to enable dynamic port forwarding for certain services/applications. The Hub 3.0 monitors outgoing traffic on the ports specified in the Trigger Range. When it detects activity on these ports, it remembers the IP address of the device sending the data and routes incoming traffic on ports in the Target Range to that IP address on your network.
Trigger start port
Trigger end port
Target start port
Target end port
Please choose
Please choose
ng page
dhcp page
DHCPv4 server
This sections allows you to configure how the Hub 3.0 assigns IPv4 addresses. It is configured to be a DHCP (Dynamic Host Configuration Protocol) server by default. This provides the TCP/IP configuration for all connected devices.
 Enabled
 Disabled
Starting local address192.168..
Number of CPEs 244
Lease time86400
seconds
Edited by rags21
Watched the video on that page he as just a start and end  mine looks likr this .......
Local IP192.168.0.
Local start port
Local end port
External start port
External end port
Please choose
Please choose
what goes in to the externalt start and end port?
Edited by rags21
