cochize1 55 Posted November 28, 2019 Posted November 28, 2019 (edited) Hi, another 2 topics that bother me: 1. Is there a way to change the name of the Emby tab (I only managed to change it but changing Emby to MyDomain in index.html <title> section but this just shows at te very first seconds when accessing the server and right after it goes to login page it changes back to Emby). Can I set it to be permanent? 2. The problem occured in 4.3 update, there is a slim drawer scrollbar showing on the very left of the screen (not sure if it is clear from the picture). Is there a way to get rid of it? Just fyi I am using the code below to change the main scrollbar of my page and in 4.2 it also affected the drawer scrollbar but not after 4.3 update: /*Scrollbar width*/ html ::-webkit-scrollbar { width: .1em; } /*Scrollbar Opacity*/ html ::-webkit-scrollbar-track-piece { background-color: rgba(0,0,0,.1); } ::selection, ::-moz-selection { color: red; background: green; } Edited November 28, 2019 by cochize1 1
DelSol 10 Posted November 29, 2019 Posted November 29, 2019 +1 for the Title change used to be in /system/dashboard-ui/scripts/librarymenu.js but this does not exist in 4.3 1
cochize1 55 Posted November 29, 2019 Author Posted November 29, 2019 The Title bit just helps changing the tab for the first 2-3 seconds before the actual login page loads so +1 is a little too much:) Would like to set it as permanent.
Solution Guest Posted November 29, 2019 Solution Posted November 29, 2019 (edited) Here is the solution. Change the term "Emby" to "Your_Server":1. at 4 locations in the index.html file2. at 1 location in manifest.json file3. at 2 location in appheader.js file You need to clear browsing data and also in Cloudflare, if you use the tool. These actions should be redone with each new EmbyServer update. Edited November 29, 2019 by CarlosLima
DelSol 10 Posted November 29, 2019 Posted November 29, 2019 appheader.js was the one I missed. works fine now.thanks @@CarlosLima
Guest Posted November 29, 2019 Posted November 29, 2019 (edited) SOLVEDTaking advantage of this topic to avoid creating new because it is the same subject. As I browsed through the collections, I noticed that the tab name keeps the default "Emby" when the movie or series page opens. I couldn't figure out where to change. I ask for help. Thank you Edited November 29, 2019 by CarlosLima
Guest Posted November 29, 2019 Posted November 29, 2019 appheader.js was the one I missed. works fine now. thanks @@CarlosLima Up: 3. at 2 location in appheader.js file
cochize1 55 Posted November 29, 2019 Author Posted November 29, 2019 well, worked like a charm, thank you And any ideas on that slim drawer slider showing on the left? Do you even see that?
Happy2Play 9811 Posted November 29, 2019 Posted November 29, 2019 I assume you mean this since drawer width 20 and left -20 leaves the scroller exposed on screen on some themes. div.mainDrawer.scrollY.scrollY-mini {left: -20.1em;} 1
cochize1 55 Posted November 29, 2019 Author Posted November 29, 2019 Worked perfectly, you are one hell of a miracle worker. Can I ask a favor to address my other topic as well, believe it should be fairly easy for you: https://emby.media/community/index.php?/topic/79827-space-between-user-tiles-on-login-page/ Thanks
JGale 10 Posted March 20, 2023 Posted March 20, 2023 Resurrecting an old thread: In appheader.js, where is the second place to edit the title?
Guest Posted March 20, 2023 Posted March 20, 2023 Edit the appheader.js file and rename the Emby text to Your_Server in document.title="Emby" in column 17298 (In version 4790 the file moved to the modules/appheader folder and the syntax no longer exists)
Happy2Play 9811 Posted March 20, 2023 Posted March 20, 2023 5 hours ago, JGale said: Resurrecting an old thread: In appheader.js, where is the second place to edit the title? Files continuously change with every version so old posts will not be completely accurate.
