Logos302 86 Posted June 12, 2014 Posted June 12, 2014 It seems with the auto-logoff turned on the screen saver doesn't kick in. It's stuck at the login screen.
Solution ebr 16334 Posted June 12, 2014 Solution Posted June 12, 2014 Yeah, the screen saver is not active unless you are logged in. This is a technical limitation at the moment. 1
