annisman 13 Posted November 28, 2019 Author Posted November 28, 2019 I added a j folder and now it's been removed
annisman 13 Posted November 28, 2019 Author Posted November 28, 2019 I am in the library section of emby server, under movies, folders. I feel that it's back because I can see it listed under the folders screen once again
Luke 42217 Posted November 28, 2019 Posted November 28, 2019 Please show screenshots to demonstrate your issue. I'm trying my best to help you, but I can't really offer much assistance to these single statement things that you're tossing out.
annisman 13 Posted November 28, 2019 Author Posted November 28, 2019 There is clearly miscommunication going on between Emby and my library folders
annisman 13 Posted November 28, 2019 Author Posted November 28, 2019 All right I will try to do a better job of explaining
annisman 13 Posted November 28, 2019 Author Posted November 28, 2019 My issues may be solved, I'll wait until I know for sure and report back
Solution annisman 13 Posted November 29, 2019 Author Solution Posted November 29, 2019 All right it looks like my problem has been fixed. I believe that one of my media drives had its drive letter changed, possibly months ago. Emby server library was being pointed to a drive on my computer that no longer existed. However it was only until this last server update that any negative effects started to show from it. Therefore I believed it was an issue with the update, I apologize and everything is working as it should.thank you for your quick responses on Thanksgiving day no less. 1
