all4dom 101 Posted November 25, 2019 Posted November 25, 2019 I'm looking to build a gaming pc for my son. If the desktop case has front usb 3.0 ports & the motherboard has a usb 3.1 header, can that be plugged into the 3.0? Thanks Dom
all4dom 101 Posted November 25, 2019 Author Posted November 25, 2019 Another question, can I use my old ssd hd with win 10 and put it in this new.build?
mastrmind11 722 Posted November 25, 2019 Posted November 25, 2019 Another question, can I use my old ssd hd with win 10 and put it in this new.build? you mean with win10 pre-installed? doubt it, the new machine will require different drivers.
all4dom 101 Posted November 26, 2019 Author Posted November 26, 2019 I came across a few topics saying that I can deactivate the windows key, wipe out the hard drive and inahould.be able to install windows on the new machine. It says this can be done one time only.
Guest asrequested Posted November 26, 2019 Posted November 26, 2019 Don't worry about the license, you'll be fine. And if you do have an issue, you just call Microsoft and they'll reset it. I've never had to do that, and I've reinstalled multiple times.
all4dom 101 Posted November 26, 2019 Author Posted November 26, 2019 From what I read, I dont thg think it should be a problem. I'll know once I start the build. Just waiting for black friday.
Guest asrequested Posted November 26, 2019 Posted November 26, 2019 And you can always buy a license on eBay for $5 1
Spaceboy 2573 Posted November 28, 2019 Posted November 28, 2019 And you can always buy a license on eBay for $5second hand licences ftw
