claptnei 3 Posted April 29, 2021 Posted April 29, 2021 I have duplicates for all the shows I have watched for some time now. I am using Emby next-gen as Kodi 19 only works with it. Getting tedious to clean up Trakt history now.
TeamB 2440 Posted April 29, 2021 Posted April 29, 2021 Do we know if this happening for all kodi plugins (EmbyCon, Emby next gen and Kodi Media Import) or is it just Emby next gen?
Luke 42239 Posted April 29, 2021 Posted April 29, 2021 Just now, TeamB said: Do we know if this happening for all kodi plugins (EmbyCon, Emby next gen and Kodi Media Import) or is it just Emby next gen? I thought it was just Emby for Kodi. @quickmic has looked at it previously.
TeamB 2440 Posted April 29, 2021 Posted April 29, 2021 13 minutes ago, Luke said: I thought it was just Emby for Kodi. @quickmic has looked at it previously. Ok cool, i have not seen any reports directly referencing EmbyCon so assume just Emby next gen.
quickmic 1709 Posted May 1, 2021 Posted May 1, 2021 It's still on the review list... For the moment, blame next-gen and not Emby server. Most likely it's a next-gen issue I keep you updated...
quickmic 1709 Posted May 2, 2021 Posted May 2, 2021 Are movies and episodes affected by the issue, or just episodes?
markdj 49 Posted May 2, 2021 Posted May 2, 2021 Just now, quickmic said: Are movies and episodes affected by the issue, or just episodes? For me it is both. 1
claptnei 3 Posted May 2, 2021 Posted May 2, 2021 1 minute ago, quickmic said: Are movies and episodes affected by the issue, or just episodes? Both for me too 1
quickmic 1709 Posted May 2, 2021 Posted May 2, 2021 I can reproduce the issue and will fix it in next version.
markdj 49 Posted May 23, 2021 Posted May 23, 2021 Any update for this? When can we see the fix for this?
BaukeZwart 94 Posted May 23, 2021 Posted May 23, 2021 6 minutes ago, markdj said: Any update for this? When can we see the fix for this? It's already fixed since a few builds ago.
markdj 49 Posted May 23, 2021 Posted May 23, 2021 I'm running the latest beta but still having the issue. Latest stable one in the repo is also quite old. Searching for updates doesn't do anything.
quickmic 1709 Posted May 23, 2021 Posted May 23, 2021 23 minutes ago, markdj said: I'm running the latest beta but still having the issue. Latest stable one in the repo is also quite old. Searching for updates doesn't do anything. @BaukeZwart is right, but I'll check again. Probably I missed an edge case.
BaukeZwart 94 Posted May 23, 2021 Posted May 23, 2021 1 hour ago, markdj said: I'm running the latest beta but still having the issue. Latest stable one in the repo is also quite old. Searching for updates doesn't do anything. Last beta was quite buggy for me, last experimental is solid
markdj 49 Posted May 24, 2021 Posted May 24, 2021 12 hours ago, quickmic said: @BaukeZwart is right, but I'll check again. Probably I missed an edge case. I checked again, but it really is the latest beta. So I guess something’s still indeed wrong or missing there
quickmic 1709 Posted May 24, 2021 Posted May 24, 2021 Please perform a test with experimental version. https://kodi.emby.media/Public testing/plugin.video.emby-next-gen-5.3.0-build 28 (ex1).zip
markdj 49 Posted May 25, 2021 Posted May 25, 2021 On 5/24/2021 at 10:57 AM, quickmic said: Please perform a test with experimental version. https://kodi.emby.media/Public testing/plugin.video.emby-next-gen-5.3.0-build 28 (ex1).zip Tried it but the problem still exists. Thanks for the effort though.
Suusepuus 6 Posted May 27, 2021 Posted May 27, 2021 (edited) I also have this problem with emby-next-gen 5.3.0 (latest beta version). Edited May 27, 2021 by Suusepuus
Luke 42239 Posted May 27, 2021 Posted May 27, 2021 2 hours ago, Suusepuus said: I also have this problem with emby-next-gen 5.3.0 (latest beta version). Hi there, please provide the specifics of an example: Thanks.
Suusepuus 6 Posted May 28, 2021 Posted May 28, 2021 (edited) 9 hours ago, Luke said: Hi there, please provide the specifics of an example: Thanks. I have duplicate Trakt-entries for everything I watch in Kodi through Emby-next-gen. Yesterday, I updated to the newest beta (5.3.0), but the problem still persists even though others report that the problem was fixed. This is not the case for my situation. Edited May 28, 2021 by Suusepuus
quickmic 1709 Posted May 28, 2021 Posted May 28, 2021 7 minutes ago, Suusepuus said: I have duplicate Trakt-entries for everything I watch in Kodii through Emby-next-gen. Yesterday, I updated to the newest beta (5.3.0), but the problem still persists even though others report that the problem was fixed. This is not the case for my situation. Have you trakt installed on Kodi? If yes, this could cause the issue please uninstall. If no, can you design a testcase for me? Does it always happen or under special circumstances? Is there a pattern?
Suusepuus 6 Posted May 28, 2021 Posted May 28, 2021 16 minutes ago, quickmic said: Have you trakt installed on Kodi? If yes, this could cause the issue please uninstall. If no, can you design a testcase for me? Does it always happen or under special circumstances? Is there a pattern? I don't have Trakt installed on Kodi. It happens every time I finish watching an episode/movie. After that in Trakt I have one entry on the time I started watching and one entry on the time it finished. I run Emby version 4.6.1.0, Trakt plugin version 3.5.0.0 and Emby-next-gen 5.3.0 on Kodi 19.1 1
markdj 49 Posted May 28, 2021 Posted May 28, 2021 Cross-posting: “Even after removal of Trakt on Kodi the issue still remains. I have sent a Kodi log earlier, I hope you can take a look at it and fix the issue that way.“ 1
quickmic 1709 Posted May 28, 2021 Posted May 28, 2021 (edited) @markdj @Suusepuus Thanks for the log, I don't see any issues there, but you have very very much plugins installed. I still think it's not an issue with the plugin. I performed countless tests, no issue. Only way to prove it, please install a stock Kodi (on a PC or whatever) and just install next-gen plugin. Perform a test and if it's raises the issues again, you can blame next-gen I'll recheck as soon as this is confirmed. If not, you can install all you plugins one after another and see what causes the issue. Edited May 28, 2021 by quickmic
