markdj 49 Posted March 3, 2021 Posted March 3, 2021 Sorry for the resurrection but I’m experiencing the same problem. Gets added when I start it and when it ends. Log included, hope it contains enough information. embyserver.txt
Luke 42239 Posted March 3, 2021 Posted March 3, 2021 55 minutes ago, markdj said: Sorry for the resurrection but I’m experiencing the same problem. Gets added when I start it and when it ends. Log included, hope it contains enough information. embyserver.txt 4.26 MB · 0 downloads Hi, please provide discussion of an example. Thanks.
markdj 49 Posted March 3, 2021 Posted March 3, 2021 Sure, today I watched Modest Heroes and the wife watched an episode of Crash Landing On You, but Trakt shows the time I started watching and the time it ends. See the screenshot.
markdj 49 Posted March 3, 2021 Posted March 3, 2021 Also, I get these a lot: Quote Post failed at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.RefreshUserAuth(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SetRequestHeaders(HttpRequestOptions options, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.GetFromTrakt(String url, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendGetAllWatchedMoviesRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncMovies(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncUserLibrary(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) 1
simonlange1971 3 Posted March 3, 2021 Posted March 3, 2021 45 minutes ago, markdj said: Also, I get these a lot: I got EXACTLY the same problem. Also manual sync process (library -> tract) does not work as well. Since there are no enlightening error messages i guess its a bug. Well how hard could it be? You enter the right auth pin for each user and it should work. But it doesnt.
markdj 49 Posted March 4, 2021 Posted March 4, 2021 13 hours ago, simonlange1971 said: I got EXACTLY the same problem. Also manual sync process (library -> tract) does not work as well. Since there are no enlightening error messages i guess its a bug. Well how hard could it be? You enter the right auth pin for each user and it should work. But it doesnt. Well shouldn't be too much of an issue you would think. I've been experiencing the error for a full day now, every hour. Can't get it fixed.
markdj 49 Posted March 5, 2021 Posted March 5, 2021 No it happens when playing in Kodi through Emby next-gen, on a Nvidia Shield.
Luke 42239 Posted March 5, 2021 Posted March 5, 2021 22 minutes ago, markdj said: No it happens when playing in Kodi through Emby next-gen, on a Nvidia Shield. Does the server dashboard activity viewer say you stopped playing twice?
markdj 49 Posted March 5, 2021 Posted March 5, 2021 (edited) No, it shows only when it starts and when it ends (once). Edited March 5, 2021 by markdj
markdj 49 Posted March 7, 2021 Posted March 7, 2021 This plug-in is so, so buggy. It neither tracks on my 2 devices anymore. I'm better off using it through Kodi itself.
Luke 42239 Posted March 10, 2021 Posted March 10, 2021 2 hours ago, markdj said: Any updates for this? And just to confirm, it does not happen with any other app besides Emby for Kodi?
markdj 49 Posted March 10, 2021 Posted March 10, 2021 (edited) 1 hour ago, Luke said: And just to confirm, it does not happen with any other app besides Emby for Kodi? Correct. When the wife watches a show on the iPad it tracks regularly/once. When watching through Kodi it tracks when it begins and ends. Edited March 10, 2021 by markdj
markdj 49 Posted March 11, 2021 Posted March 11, 2021 When I mark it through the browser it tracks it normally. Shall I upload a new log file? I really would like to see this solved.
Luke 42239 Posted March 11, 2021 Posted March 11, 2021 3 minutes ago, markdj said: When I mark it through the browser it tracks it normally. Shall I upload a new log file? I really would like to see this solved. Yes please, thanks.
markdj 49 Posted March 11, 2021 Posted March 11, 2021 44 minutes ago, Luke said: Yes please, thanks. Here you go. embyserver 2.txt
quickmic 1709 Posted March 14, 2021 Posted March 14, 2021 On 3/5/2021 at 6:47 PM, markdj said: No it happens when playing in Kodi through Emby next-gen, on a Nvidia Shield. This was an issue in 4.1.x but was fixed by 4.1.22. I'll check if there is a problem with next gen. Does it also happen on movies? The issue in 4.x only affected TV-Shows. -> sync episode progress (first tag) then sync season (and recursive all season episodes) (second tag).
markdj 49 Posted March 14, 2021 Posted March 14, 2021 10 minutes ago, quickmic said: This was an issue in 4.1.x but was fixed by 4.1.22. I'll check if there is a problem with next gen. Does it also happen on movies? The issue in 4.x only affected TV-Shows. -> sync episode progress (first tag) then sync season (and recursive all season episodes) (second tag). It does also happen with movies, yes. 1
quickmic 1709 Posted March 19, 2021 Posted March 19, 2021 No not yet. It's on the todo list, but very busy with higher priority issues . I'll have a look into this matter in the next days.
jimbobjones 13 Posted April 18, 2021 Posted April 18, 2021 (edited) I upgraded to Emby next-gen about a week ago, and I just noticed in Trakt that I have duplicates for all the shows I have watched since then. Will follow this thread, but likely switch to the kodi trakt addon in the mean time. Edited April 18, 2021 by jimbobjones
