rags21 0 Posted November 24, 2019 Author Posted November 24, 2019 Must be getting old lol right i have now added him and he got the invite email,so does he put the whole remote access name in starting with the http or just the numbers inc the :8096
rags21 0 Posted November 24, 2019 Author Posted November 24, 2019 He logged on to his emby connect and he was greeted with a new server to add west which is me,but then it said connection failure
Luke 42238 Posted November 24, 2019 Posted November 24, 2019 He logged on to his emby connect and he was greeted with a new server to add west which is me,but then it said connection failure I would suggest checking out our Connection Troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. thanks.
rags21 0 Posted November 24, 2019 Author Posted November 24, 2019 I tried that canyouseeme atthe bottom of that page and got Error: I could not see your service on 80. on port (8096) iv'e took rest of the remote access out Reason: Connection timed out
Luke 42238 Posted November 24, 2019 Posted November 24, 2019 Please go through the rest of the document. Thanks.
rags21 0 Posted November 24, 2019 Author Posted November 24, 2019 So i'm thinking it is a port forwarding problem and i don't know my asus router log in password and that is linked to my virgin media superhub which is in bridge mode as it's only way to use a vpn through it,and i wouldn't like to reset the asus as it s settings for the vpn was done by a tech using teamviewer
Luke 42238 Posted November 24, 2019 Posted November 24, 2019 Ok, yes you will need to be able to get into the router configuration.
ebr 16332 Posted November 29, 2019 Posted November 29, 2019 I've do I enter for the host name Hi. The answer is the same as we previously indicated in your other posts. We are not a streaming service. We are a personal media server. You install your own server and point it to your own content (or TV tuner). Thanks. Quick start
