Sammy 791 Posted November 30, 2019 Author Posted November 30, 2019 More like $50.. what do you think @ ? Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted November 30, 2019 Posted November 30, 2019 Sure, go for it. You won't notice any difference. 1
Sammy 791 Posted November 30, 2019 Author Posted November 30, 2019 Ordered. Now the fun starts! Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted December 1, 2019 Author Posted December 1, 2019 Okay.. technical question. I had 4 HDD's in DrivePool. The OS SSD is toast. How to recover? Can I just install DrivePool on the new m.2 and rebuild from there?
Guest asrequested Posted December 1, 2019 Posted December 1, 2019 Just install the software, it'll recognize the pool parts and recreate the pool. 1
Sammy 791 Posted December 2, 2019 Author Posted December 2, 2019 (edited) Will this card work without flashing the f/w? https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F401949047895 Sent from my SM-G960U1 using Tapatalk Edited December 2, 2019 by Sammy
Guest asrequested Posted December 2, 2019 Posted December 2, 2019 It says it's an HBA, so it should be ok, but you may want to message the seller and confirm it's in IT mode.
Sammy 791 Posted December 2, 2019 Author Posted December 2, 2019 Good suggestion.. I may not get a card just yet as I only have 4 HDD's to install right now in this case. The rest of my drives were an assortment of SSD's of various makes and sizes that I used for the boot drive and then others for Emby Data, Transcoding, Recordings and then finally Archives of MCEBuddy conversions. Now, with 1TB on the m.2 card I don't need all of these any longer. I will need to hook them up momentarily to get the data and recordings off them then I'm done with them. Eventually I will be able to add more drives to my case.
Sammy 791 Posted December 2, 2019 Author Posted December 2, 2019 BTW, @ what is IT Mode? I'm new to this. Thanks.
Guest asrequested Posted December 2, 2019 Posted December 2, 2019 It's basically disabling the RAID function. Here's a link https://forums.servethehome.com/index.php?threads/what-is-it-mode.328/
Sammy 791 Posted December 2, 2019 Author Posted December 2, 2019 It's basically disabling the RAID function. Here's a link https://forums.servethehome.com/index.php?threads/what-is-it-mode.328/ Basically we're talking about the seller flashing the f/w.. Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted December 2, 2019 Posted December 2, 2019 In a lot of cases, yes. But there are some listed as new that are in IT mode. I have three of them. I may buy a few more.
Sammy 791 Posted December 2, 2019 Author Posted December 2, 2019 It says it's an HBA, so it should be ok, but you may want to message the seller and confirm it's in IT mode. Seller says, "Not sure but it can easily be changed." Sounds like a pass to me.
Guest asrequested Posted December 2, 2019 Posted December 2, 2019 (edited) Seller says, "Not sure but it can easily be changed." Sounds like a pass to me. Have them flash it instead of you. Then it's their fault if they break it Edited December 2, 2019 by Doofus
Sammy 791 Posted December 3, 2019 Author Posted December 3, 2019 Have them flash it instead of you. Then it's their fault if they break it They said no. Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted December 3, 2019 Posted December 3, 2019 They said no. Sent from my SM-G960U1 using Tapatalk Figures.
Sammy 791 Posted December 4, 2019 Author Posted December 4, 2019 (edited) So how to flash the BIOS on the MoBo for 3000 series Ryzen 7? Do I boot to BIOS then can access the USB from there to flash it? Sent from my SM-G960U1 using Tapatalk Edited December 4, 2019 by Sammy
Guest asrequested Posted December 4, 2019 Posted December 4, 2019 Upgrading the motherboard BIOS is easy. You can either put the new one on a thumb drive and boot to the utility, or use the @BIOS app that Gigabyte provides. That's what I use. Then you can just do it in Windows. 1
Sammy 791 Posted December 4, 2019 Author Posted December 4, 2019 So even though the CPU is not "compatible" with the MoBo out of the box Windows still works? Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted December 4, 2019 Posted December 4, 2019 (edited) I think it will still work, but in your case updating before you install Windows is probably best, to prevent any possible installation glitches. It's always fun and games with new tech Just look in the manual, it'll tell you how to do it. Edited December 4, 2019 by Doofus 1
Sammy 791 Posted December 6, 2019 Author Posted December 6, 2019 Won't boot to BIOS. DRAM LED on the MoBo is illuminated red. UGH. Suggestions? Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted December 6, 2019 Posted December 6, 2019 Did you update the BIOS? Or will it not let you do that?
Sammy 791 Posted December 6, 2019 Author Posted December 6, 2019 Did you update the BIOS? Or will it not let you do that?I am not able to even boot to BIOS. I'll try reseating the RAM and then one by one if it doesn't work. The RAM part number is on the gigabyte AVL. Sent from my SM-G960U1 using Tapatalk
