Spaceboy 2573 Posted November 29, 2019 Posted November 29, 2019 5 USD or 5 GBP? We have 20mbps no cap but need headroom for external Emby clients. Is it schedulable? Sent from my SM-G960U1 using Tapatalk pretty much the same these days but its in USD
Spaceboy 2573 Posted November 29, 2019 Posted November 29, 2019 Is it SATA? Sent from my SM-G960U1 using Tapatalk see above for all the bits i use
Spaceboy 2573 Posted November 29, 2019 Posted November 29, 2019 rclone - yes completely schedulable. it runs from a .bat file set off by a windows scheduled task so i guess you can set it to run when you want and for how long. i have 3 sync tasks running. one runs at 6am every day to copy my most recent backups from all my home pc's and the other 2 run 24/7 kicked off by the user logging on, so literally all the time. you can also limit the bandwidth the sync is allowed, but tbh i have them running at 100% and i have never noticed any issues with watching emby media remotely
Jdiesel 1435 Posted November 29, 2019 Posted November 29, 2019 I personally find that unRAID is a nice balance when it comes to protection from drive failure for low risk data like media. It uses a single parity drive (can add a second for added security), which must be equal to or larger than the remaining drives in the array, which can be used to recovery any failed drive in your array. The data stored on the array is pooled across the drives however you choose and a drive can be removed and accessed independently from the array. It is extremely simple to add new drives too. You don't get the performance benefits as you would with a conventional RAID because write speeds are dependent on the parity drive, however you can add an SSD as a cache drive which can mitigate the issue of slow write speeds. As an added bonus, running dockers and VMs is about as easy as it gets and the catalog of ready to use dockers is comprehensive. About 4 months ago I had an old WD Green 3TB fail on me. I ordered a new 8TB replacement drive and swapped it out a few days later with zero interruptions to my server and zero data loss during the window when the 3TB was down. I didn't even have to power down my machine get the 8TB running in my existing array. I was super impressed with the whole process. 1
Sammy 791 Posted November 29, 2019 Author Posted November 29, 2019 the drive https://www.amazon.co.uk/gp/product/B07GBGHH39/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 the pcie card https://www.amazon.co.uk/gp/product/B079553PJ5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 a heat sink https://www.amazon.co.uk/gp/product/B07PXGGCSY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 dead easy This one looks good? https://www.amazon.com/Intel-660p-Solid-State-Drive/dp/B07GCCPD28 The board @ linked has m.2. Do I need the pcie card? AFAIK, I will need a controller card no matter what. The m.2 takes away 3 SATA busses.. Sent from my SM-G960U1 using Tapatalk
Spaceboy 2573 Posted November 29, 2019 Posted November 29, 2019 This one looks good? https://www.amazon.com/Intel-660p-Solid-State-Drive/dp/B07GCCPD28 The board @ linked has m.2. Do I need the pcie card? AFAIK, I will need a controller card no matter what. The m.2 takes away 3 SATA busses.. Sent from my SM-G960U1 using Tapatalk if your board has an m2 plug then you should be good to go without the pcie card i linked. you may still want some sort of heat sink / cooler not an expert here so i'm not quite sure what you mean but in my set up i have 1 controller card that supports 16 disks and another 4 plugged into sata ports on the motherboard. thats the full 20 full size drives that my case can handle. for me the controller card is plugged into one pcie x16 slot, the m2 in a second and the optane disk in a third. i don't remember whats in the 4th right now, i think my tv tuner card. no issues with conflict. but i'm not an expert, i just know it works
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 I've got a few of these, among others. https://www.amazon.com/gp/product/B07GZ29CSZ/ref=ox_sc_saved_title_8?smid=A3ISMVC1FTQD6C&psc=1
Sammy 791 Posted November 29, 2019 Author Posted November 29, 2019 I've got a few of these, among others. https://www.amazon.com/gp/product/B07GZ29CSZ/ref=ox_sc_saved_title_8?smid=A3ISMVC1FTQD6C&psc=1 It's a bit more $ than the intel m.2? Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted November 29, 2019 Author Posted November 29, 2019 if your board has an m2 plug then you should be good to go without the pcie card i linked. you may still want some sort of heat sink / cooler not an expert here so i'm not quite sure what you mean but in my set up i have 1 controller card that supports 16 disks and another 4 plugged into sata ports on the motherboard. thats the full 20 full size drives that my case can handle. for me the controller card is plugged into one pcie x16 slot, the m2 in a second and the optane disk in a third. i don't remember whats in the 4th right now, i think my tv tuner card. no issues with conflict. but i'm not an expert, i just know it works The m.2 slot on the MoBo takes up 3 SATA Ports on the MoBo AFAIK. An adapter card is necessary I think. Heat sink is cheap insurance so yes. Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 It's a bit more $ than the intel m.2? Sent from my SM-G960U1 using Tapatalk That's because it's NVMe (Non Volatile Memory) and has a wider read/write bandwidth. Not needed, I suppose, but nice to have
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 The m.2 slot on the MoBo takes up 3 SATA Ports on the MoBo AFAIK. An adapter card is necessary I think. If you get a x2 or x4, you only lose two SATA ports. But if you're referring to the LSI controller, I'd suggest you get one.
arrbee99 1836 Posted November 29, 2019 Posted November 29, 2019 Wondering how / if that table applies to mobo's in general. Is it for every mobo, just for AMD boards, particular generations of mobo, just for the mobo you linked too...
Jdiesel 1435 Posted November 29, 2019 Posted November 29, 2019 I don't think there is any hard rule with motherboards and m.2 drives. My MSI motherboad is similar to the table above but I believe some can use a m.2 and all sata ports. Likely depends on the chipset/chipsets used.
Sammy 791 Posted November 29, 2019 Author Posted November 29, 2019 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F143338073375 What about this card? Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F143338073375 What about this card? Sent from my SM-G960U1 using Tapatalk That should work. 1
Sammy 791 Posted November 29, 2019 Author Posted November 29, 2019 Or should I just get a MoBo with more SATA III Ports? Sent from my SM-G960U1 using Tapatalk
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 Wondering how / if that table applies to mobo's in general. Is it for every mobo, just for AMD boards, particular generations of mobo, just for the mobo you linked too... It depends on the available PCIe lanes, specifically how many. My Threadripper board has 64, and 3 M.2 slots, with 8 SATA ports. There are enough lanes to support everything.
arrbee99 1836 Posted November 29, 2019 Posted November 29, 2019 I don't think there is any hard rule with motherboards and m.2 drives. My MSI motherboad is similar to the table above but I believe some can use a m.2 and all sata ports. Likely depends on the chipset/chipsets used. Can't spot anything in the info for my board (yet) so I'll just have to keep plugging stuff in and see what happens...
Jdiesel 1435 Posted November 29, 2019 Posted November 29, 2019 Can't spot anything in the info for my board (yet) so I'll just have to keep plugging stuff in and see what happens... Download the manual, it should state it in there
arrbee99 1836 Posted November 29, 2019 Posted November 29, 2019 It depends on the available PCIe lanes, specifically how many. My Threadripper board has 64, and 3 M.2 slots, with 8 SATA ports. There are enough lanes to support everything. Its an x570 board, think that makes it 16 lanes. Will try a bit of googling and hope I actually understand what I find...
arrbee99 1836 Posted November 29, 2019 Posted November 29, 2019 Download the manual, it should state it in there Can't spot anything. Lots of stuff about how to install an m.2, nothing in connection with sata or lanes (yet).
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 Its an x570 board, think that makes it 16 lanes. Will try a bit of googling and hope I actually understand what I find... Apparently that chipset has 40 lanes https://www.techpowerup.com/255008/amd-x570-chipset-to-feature-40-pcie-4-0-lanes
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 But a later article is separating SATA ports from PCIe lanes. https://www.techpowerup.com/256480/amd-x570-puts-out-up-to-twelve-sata-6g-ports-and-sixteen-pcie-gen-4-lanes
arrbee99 1836 Posted November 29, 2019 Posted November 29, 2019 Apparently that chipset has 40 lanes https://www.techpowerup.com/255008/amd-x570-chipset-to-feature-40-pcie-4-0-lanes Thanks, I shall have a read. Saw that article come up under google, just hadn't worked my way to it yet. Just trying to make breakfast as well, guess multitasking really is a female of the species type thing, or maybe its just me.
Guest asrequested Posted November 29, 2019 Posted November 29, 2019 Thanks, I shall have a read. Saw that article come up under google, just hadn't worked my way to it yet. Just trying to make breakfast as well, guess multitasking really is a female of the species type thing, or maybe its just me. The second link is more informative 1
