lightsout 156 Posted February 20, 2020 Posted February 20, 2020 Come on guys. Stop the flaming and personal ad hominem attacks. It is unbecoming of the Emby Community to act in such a manner, especially in MY THREAD! Sent from my SM-G960U1 using Tapatalk For real was about to say the same thing. The google thing is a loophole and not certain. No need to berate someone that didn't understand or doesn't want to use it.
Spaceboy 2573 Posted February 20, 2020 Posted February 20, 2020 you guys.... let me know if you want any more straws to clutch at. you should read up on the downsides to backblaze before jumping to say anything that you think can contradict me. and as for the "beration", perhaps if you know nothing about the topic at hand and you want advice, its probably best not to repeatedly tell the adviser, that is already doing what you want to do, that they are wrong
SHSPVR 125 Posted February 20, 2020 Posted February 20, 2020 you guys.... let me know if you want any more straws to clutch at. you should read up on the downsides to backblaze before jumping to say anything that you think can contradict me. and as for the "beration", perhaps if you know nothing about the topic at hand and you want advice, its probably best not to repeatedly tell the adviser, that is already doing what you want to do, that they are wrong Do tell what are the downsides to backblaze
Spaceboy 2573 Posted February 20, 2020 Posted February 20, 2020 Do tell what are the downsides to backblaze try reading for yourself. I don’t need the hassle of explaining to people who think they already know
Guest asrequested Posted February 20, 2020 Posted February 20, 2020 try reading for yourself. I don’t need the hassle of explaining to people who think they already know You should be kicked out of these forums. All you do is run your mouth, insult people, and when you're asked to explain suggestions/comments you make, you just give attitude.
PenkethBoy 2068 Posted February 20, 2020 Posted February 20, 2020 wow lots of people who have not been on the internet before have turned up today for some reason 2
SHSPVR 125 Posted February 20, 2020 Posted February 20, 2020 (edited) try reading for yourself. I don’t need the hassle of explaining to people who think they already know But I want your ver of this if have used it. I have read a few review even listen to Linus Sebastian at Linus Tech Tips and must of what was petty good. The must con I read so far are 1 "Backblaze simple functions limit it as just a simple computer backup service" I though that was the whole point 2 "Subscription is limited to one computer per account only" Big deal 3 "If you are using a private password and you forgot it, the data in your subscription is permanently locked without any chance for retrieval" Lean keep offline backup copy password datebase I do 4 "Previous versions of your file only last up to 30 days before it is erased" I not sure why this a big deal 5 "Mobile applications cannot be used to sync files with your account" There an easy solution here copy the stuff over to that computer problem solved I personal would used them if it wasn't for my ISP darn data cap so I have make 2nd copy backup on other older drives, In fact I in process of build a new server box plus add 8 new drive over course of this year one at time at lease the plan but thing can happing all take one thing to go wrong. Edited February 20, 2020 by SHSPVR 1
Sammy 791 Posted February 20, 2020 Author Posted February 20, 2020 @@SHSPVR Thanks for taking the high road. Sent from my SM-G960U1 using Tapatalk
lightsout 156 Posted February 21, 2020 Posted February 21, 2020 I have also heard people be wary of backblaze. This was over at r/datahoarder 1
Spaceboy 2573 Posted February 21, 2020 Posted February 21, 2020 You should be kicked out of these forums. All you do is run your mouth, insult people, and when you're asked to explain suggestions/comments you make, you just give attitude. ah well, it looks like i'm not the only one that doesnt give a shiny poop what you think anyway, you've bored me sufficiently for this encounter. bye!
