aarbee 6 Posted November 23, 2019 Posted November 23, 2019 Hello, I am having aQnap TVS-673 with 4 Ethernet portsDrraytek routerZyxel managed Switches. What I would like to do, is create a vpn, which gets a different IP address then the normal range.Create a Vlan to the second Ethernetport of the Qnap. And works only for the Emby Application.So nobody should see the login for the Qnap. I know how to create a VPN.I know how to create a Vlan. The question is, can I create a second access to the Qnap which only accesses Emby, and not the Qnap itself? Thanks ahead.
aarbee 6 Posted November 23, 2019 Author Posted November 23, 2019 Luke Thank you.I did look at his posts, but could not find any that could be an answer to my question.But that can be me. Not reading well.
PenkethBoy 2068 Posted November 24, 2019 Posted November 24, 2019 @@aarbee Hi - i dont use a vpn with my qnap as not open to the internet But i would ask on the QNAP forums as more likely to get a qnap answer
aarbee 6 Posted November 24, 2019 Author Posted November 24, 2019 Thanks @@PenkethBoy. I am running into a complete different issue. Portforwarding should be easy.I know I did work with an earlier version.Forwarded 8096 to the Qnap. And looks there is no open port. Yet is my RDP to a virtual machine on the qnap working.So I had decided to install Emby within the Virtual Machine, and changed the port forward in the router. And it promptly works.This looks like a firewall on the Qnap itself. I know I have on the qnap several whitelisted ip addresses. But that was not the case either.I am slowly beginning to think that adding a NUC i5 or i7 with dual lan, and keep the data on the qnap, a better solution
