syadnom 25 Posted November 23, 2019 Posted November 23, 2019 I'm struggling to find a very small embedded device that can transcode with Emby. Probably MPEG2>1080P h.264 from an HD HomeRun would be the target. I was really really hoping the nvidia jetson nano would do it, but apparently no cuda support or ffmpeg support for hardware encoding :/ I see that nvidia shield is supported for server, but how many streams can it handle? Will it transcode MPEG2 Live TV from HD HomeRun? I found a plex post that says 2-3 streams but without much detail and if that includes dec/enc and which sources etc. Anyone tested this specific use case?
syadnom 25 Posted December 2, 2019 Author Posted December 2, 2019 Rpi4 or is that too big? Can you hardware transcode on the Pi4? I thought that it wasn't possible right now...
syadnom 25 Posted December 2, 2019 Author Posted December 2, 2019 note, I just found this thread:https://emby.media/community/index.php?/topic/75841-rpi4-does-it-works-perfectly-with-the-new-gpu/?hl=rpi4 How many transcodes can it handle? 2? I'm worried that the removal of MPEG2 decoding in the Pi4 will not suit my needs.
Luke 42239 Posted December 2, 2019 Posted December 2, 2019 How many transcodes can it handle? 2? That's probably about right.
