asimov-solensan 0 Posted November 23, 2019 Posted November 23, 2019 Hello, Tried emby some time ago but had many network problems and gave up. Now giving another opportunity but I think it lacks this feature or I don't know how it is used. My problem is that I want to hear movies on its original language, but in the web player or android application the only option I get is changing the default option. Can't find an answer in the forum and I understand simply that changing the audio track "on demand" as you do in a desktop player (with local files I mean) is simply not possible. Is this correct?
Solution seanbuff 1354 Posted November 23, 2019 Solution Posted November 23, 2019 If your media file contains multiple audio (language) tracks, you can absolutely select your desired audio track on-the-fly. Which client are you using? 1
asimov-solensan 0 Posted November 23, 2019 Author Posted November 23, 2019 Oh crap. How stupid! I was messing with all options and indeed there is a dedicated button to change audio track on the web player. Emby absolutely fits my use case.
