flakie99 0 Posted November 22, 2019 Posted November 22, 2019 Was just looking at getting emby connect running so I can try to get Alexa working and noticed there was a message to restart emby because of an update. Before this I had just changed the port number in advanced to 443 for secure connections (in case this has some bearing) as alexa could not see the server. I restarted emby now emby will not run. Tries to run for about 30 seconds and then reports as stopped. Any ideas on how to fix this? What logs might be useful? I have attached the latest start-stop-status log. Cheers. start-stop-status_20191122.log
Luke 42242 Posted November 23, 2019 Posted November 23, 2019 Hi, what version do you have installed now?
flakie99 0 Posted November 23, 2019 Author Posted November 23, 2019 Not sure. I rebooted again and got a message that the disk space was full and I could not login. Also cannot ssl in as it states the password is wrong (its not). Looking at the synology forum it seems it is probably the system partition that got filled some how. Tried a soft reset and that never worked (same error) so am currently factory resetting it and will restore from last nights backup.
flakie99 0 Posted November 23, 2019 Author Posted November 23, 2019 Thanks. Backup and running now. Not sure what the issue was. Its on version 4.2.1.0 but states there is a version 4.3.0.26 available for download. This does not show up in the DSM Package Center though, at least not yet.
