701h 12 Posted November 22, 2019 Posted November 22, 2019 HI Luke Where is the channel mapping data stored? presumably in the library.db file somewhere? I'm in Aus, so my TV guide data is from a couple of sources, and I need to map/unmap channels as needed, which is a PIA currently. can you please tell me where is mapping data is stored, and how I can edit it without having to remove the guide and re-adding it. ta Rich
Luke 42243 Posted November 22, 2019 Posted November 22, 2019 programdata/config/livetv.xml. But at some point soon it will be moving into the database.
701h 12 Posted November 22, 2019 Author Posted November 22, 2019 awesome, thanks Luke, just what I need.
Luke 42243 Posted May 11, 2021 Posted May 11, 2021 Improved channel management coming in Emby Server 4.6:
701h 12 Posted May 30, 2021 Author Posted May 30, 2021 Hi Luke, This is beautiful. Thanks so much for all your work. 1
