Bigmack3000 108 Posted November 22, 2019 Posted November 22, 2019 On my Shield it seems there's no recognition of anything past the 1st part of the film? And no where to select the other parts. Any ideas why this is?
ebr 16338 Posted November 22, 2019 Posted November 22, 2019 Hi. It will play the parts back to back and should show the additional parts as well. However, this is something that is very rarely tested. I highly suggest just combining the parts into a single file.
Bigmack3000 108 Posted November 22, 2019 Author Posted November 22, 2019 I'll test if it plays the 2nd part at the end of the 1st, but it definitely isn't showing the additional parts.
Deathsquirrel 745 Posted November 25, 2019 Posted November 25, 2019 I'll test if it plays the 2nd part at the end of the 1st, but it definitely isn't showing the additional parts. It shouldn't show them as separate files. It should just play them back to back. That said, you should combine the videos using something like MKVmerge.
