Tony B. 38 Posted November 21, 2019 Posted November 21, 2019 (edited) Using the Fire Stick remotely, I can't scroll past one listing in the guide and it hangs then force closes. I have since enabled debugging and sent several. I presume you need an emby log with this? Edited November 21, 2019 by Tony B.
Tony B. 38 Posted November 22, 2019 Author Posted November 22, 2019 (edited) Give me a few minutes then I will send 5 bug reports from the Fire TV app, after that, send the log on this thread. Edited November 22, 2019 by Tony B.
Tony B. 38 Posted November 22, 2019 Author Posted November 22, 2019 (edited) Reports from the Fire Stick sent (yes it's a non-beta version, but it happens in beta as well) Let me know when you get these logs so I can delete them from the server Oops! https://www.tinozplace.com/embyserver.txt Edited November 22, 2019 by Tony B.
Tony B. 38 Posted November 22, 2019 Author Posted November 22, 2019 (edited) Deleted post Edited November 22, 2019 by Tony B.
ebr 16338 Posted November 22, 2019 Posted November 22, 2019 Reports from the Fire Stick sent (yes it's a non-beta version, but it happens in beta as well) Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time
Tony B. 38 Posted November 22, 2019 Author Posted November 22, 2019 Scrolling in the guide, as the title says. Up or down. If it had to 'load' it hung then FC. Around all day yesterday but, concentrated around 9:20-9:30pm EST Tino-Remote
ebr 16338 Posted November 22, 2019 Posted November 22, 2019 Hi. Is this something new? How slow is the connection you are on? How many channels do you have? It looks like the stick is completely overwhelmed. This is one of the first or second gen ones, correct? Try bringing up the guide and not touching a key for maybe 30 seconds and see what happens.
Tony B. 38 Posted November 22, 2019 Author Posted November 22, 2019 (edited) @@ebr I started to notice on Sunday.110/20 is the connection speedA couple hundred.Second gen. Would you suggest I get the new 4K stick?I'll try that. Edited November 23, 2019 by Luke
Tony B. 38 Posted November 25, 2019 Author Posted November 25, 2019 @@ebr Since you said that the stick was getting bogged down, I went through and disabled a couple things. The backdrop was A HUGE issue (remotely). It caused hanging and FC in the main menu. This also helped a little bit with the guide. It still needs a couple seconds to catch up before I start using the fast forward and rewind button to go pages at a time, however, it's a little better. Since this is a permanent stick I travel with, I will leave this backdrop setting unchecked in settings. It rarely gets connected at home, only when I need to 'check in' on apps like PSVue. Also, I must say that the hangs/FCs have reduced because of that backdrop setting and because I reduced the amount of channels. It does hang for a couple seconds but doesn't FC. However, I have never had these problems before the last updates to the app; Used to have around 1500 channels activated in xTeve
