Happy2Play 9797 Posted February 23, 2024 Posted February 23, 2024 2 minutes ago, pinkruntz said: Cant believe its been 4 years and this is still an issue. Do you have a suggestion? But yes there are several topics on this as sourcing material is the issue.
pinkruntz 0 Posted February 23, 2024 Posted February 23, 2024 14 hours ago, Happy2Play said: Do you have a suggestion? But yes there are several topics on this as sourcing material is the issue. https://www.traileraddict.com/trailerapi You can use this and set it to at least default to 720p. Just have users input their own api key.
sydlexius 297 Posted February 23, 2024 Posted February 23, 2024 1 hour ago, pinkruntz said: https://www.traileraddict.com/trailerapi You can use this and set it to at least default to 720p. Just have users input their own api key. I couldn't find a way to register for an API Key without having to sign up using a Facebook account. Is that the only type of account they support?
memc 22 Posted February 24, 2024 Posted February 24, 2024 Cant Emby source trailers from IMDB or TMDB? Works well for PreShow Experience (CinemaVision fork) in Kodi. Quality can be set to either 480p, 720p or 1080p
Luke 42150 Posted February 24, 2024 Posted February 24, 2024 1 minute ago, memc said: Cant Emby source trailers from IMDB or TMDB? Works well for PreShow Experience (CinemaVision fork) in Kodi. Quality can be set to either 480p, 720p or 1080p When we download metadata for a movie from MovieDb, we do capture the trailer urls that it provides. Usually those just point to youtube.
Happy2Play 9797 Posted February 24, 2024 Posted February 24, 2024 5 minutes ago, memc said: Cant Emby source trailers from IMDB or TMDB? Works well for PreShow Experience (CinemaVision fork) in Kodi. Quality can be set to either 480p, 720p or 1080p IMDB no as they want a pretty penny to utilize any information of theirs (legally). TMDB does not have trailers. But do have links to YouTube trailers that users assign to media. But the issue overall here is more toward upcoming/future movies ie the Trailer plugin. 1
memc 22 Posted February 24, 2024 Posted February 24, 2024 30 minutes ago, Happy2Play said: IMDB no as they want a pretty penny to utilize any information of theirs (legally). Looking at the Kodi log, the PreShow Experience addon appears to scrape from IMDB, so I understand your reasoning.
Junglejim 385 Posted February 24, 2024 Posted February 24, 2024 (edited) 1 hour ago, Happy2Play said: IMDB no as they want a pretty penny to utilize any information of theirs (legally). TMDB does not have trailers. But do have links to YouTube trailers that users assign to media. But the issue overall here is more toward upcoming/future movies ie the Trailer plugin. Yep, older movies usually have a nice quality trailer via youtube. The same can't be said for new/upcoming releases to theaters/digital unfortunately. Edited February 24, 2024 by Junglejim
InsaneJester 0 Posted March 1, 2024 Posted March 1, 2024 Been using Trailers and Vantage point for a while. The trailers have been mostly 720p. But last two months I can't even seem to get 480p its been like 240 or so. Why isn't there a way to choose between quality or an auto setting? Still don't see why we haven't gotten the 4k or 4k HDR or even Dolby Vision trailers yet. But right now I would love to just get back to 720p or better.
Happy2Play 9797 Posted March 1, 2024 Posted March 1, 2024 1 minute ago, InsaneJester said: Been using Trailers and Vantage point for a while. The trailers have been mostly 720p. But last two months I can't even seem to get 480p its been like 240 or so. Why isn't there a way to choose between quality or an auto setting? Still don't see why we haven't gotten the 4k or 4k HDR or even Dolby Vision trailers yet. But right now I would love to just get back to 720p or better. Is there a source that is giving them away? Until the devs can work out a deal with a provider or come across a good source we get what we get. But yes the current option has the lowest quality yet.
novax 0 Posted December 1, 2024 Posted December 1, 2024 I just bought Premiere a couple of days ago partly due to the trailers option, and thinking there would be robust & high quality plugins. Unfortunately, the Trailers plug-in is proving otherwise, as I'm getting low quality 480p/pixelated youtube trailers. It is discouraging this thread/issue is 4+ years old now. The issue doesn't seem to have been fixed in the latest iteration of the plugin. Am I missing something in settings or what is the expected date for a fix? TIA.
Luke 42150 Posted April 29, 2025 Posted April 29, 2025 For those on the beta server, once you've updated to 4.9.0.51, and gotten the trailer plugin update, with the following days after that you'll start to more trailers and higher quality trailers. It is all youtube now. Please note, Emby apps are going to require compatibility updates, so i wouldn't switch to beta solely for this just yet. But if you already happen to run the beta, then please leave feedback in the testing area of the community. Thanks. 1 1
