vfrjim 1 Posted November 19, 2019 Posted November 19, 2019 The show is "In Search Of" and it shows the old original information from the 1970's but is the current one that started in 2018, the TVDB# is 349422 and IMDB # is 8005322. I used the IDENTIFY option and searched but got no results. Any ideas on how to fix it? Thanks
Solution Luke 42217 Posted November 19, 2019 Solution Posted November 19, 2019 You got no results because of this: https://emby.media/community/index.php?/topic/79269-tvdb-api-issues/ 1
vfrjim 1 Posted November 19, 2019 Author Posted November 19, 2019 Ah, ok. Funny thing is that I originally set up my Library 2 weeks ago and it was correct then. I rebuilt my library yesterday and got the wrong results. Thanks for the info.
Luke 42217 Posted November 19, 2019 Posted November 19, 2019 Yes hopefully they will resolve their issues soon.
