Toetje583 0 Posted November 19, 2019 Posted November 19, 2019 (edited) Hello,I'm creating my own EPG data using WebGrab+Plus, the XML loads fine however in chrome and on android it looks strange for certain channels, while in Emby Theater all looks fine all the time.See attachments!Someone experienced the same perhaps, i'm coming over from plex and on Plex it worked great but it had other issues so wanted to give emby a shot.Best Regards,Toetje Edited November 19, 2019 by Toetje583
Luke 42244 Posted November 19, 2019 Posted November 19, 2019 Hi, have you looked at the guide data xml? is it filled with programs that might only be a minute or two long?
Luke 42244 Posted November 19, 2019 Posted November 19, 2019 That being said, if it looks correct in Emby Theater then that is a good sign that it will be resolved on the other devices after their next app update.
Toetje583 0 Posted November 19, 2019 Author Posted November 19, 2019 That being said, if it looks correct in Emby Theater then that is a good sign that it will be resolved on the other devices after their next app update. Just to be sure, i'm rebuilding the XML takes a while then I will check it again, for some channels the epg was missing in chrome while it was working just fine in theater will see where things go.
