sdann87 0 Posted November 19, 2019 Posted November 19, 2019 Hi, I have loaded Emby onto my Asustor NAS and I have it mostly up and running. I have 2 libraries that I want Emby to use, one for Movies and one for TV shows. I have the library file for the TV Shows working correctly and everything is working well however when I try and get the movie library set up (using the same pathways etc) the scan function advises that it is queuing the scan but never actually does the scan. Emby shows that I have a library file called Movies but I have no content in the file. Can someone please advise?
Luke 42237 Posted November 21, 2019 Posted November 21, 2019 Hi there, what do you mean by same pathways? How did you setup the library in emby library setup?
sdann87 0 Posted November 21, 2019 Author Posted November 21, 2019 Hi Luke, Sorry, I was not very clear. I mean that I basically did the same thing as I did when setting up my TV Shows library. I went to the add library option and defined the type of library as movies, added the file path by navigating to where my movie folder is stored on my NAS being: volume1/Movies and then left the rest of the options as default and saved the library.
Luke 42237 Posted November 21, 2019 Posted November 21, 2019 what does your movies folder structure look like?
sdann87 0 Posted November 21, 2019 Author Posted November 21, 2019 I have the main folder defined as Movies and then in that folder I have my movies. There is a mix of folders with the movie names and then the movie file, with the movies' title as the file name, and some without a folder so just files with the movie title as the file name.
Luke 42237 Posted November 21, 2019 Posted November 21, 2019 Nine times out of ten this is a permissions problem, meaning Emby Server doesn't have access to the folder. Please run a library scan, then attach the emby server log. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
sdann87 0 Posted November 21, 2019 Author Posted November 21, 2019 (edited) Hi I hope I got the correct info for you in the attached. emby log.txt Edited November 21, 2019 by sdann87
Luke 42237 Posted November 21, 2019 Posted November 21, 2019 Did you run a library scan during the time of this log?
sdann87 0 Posted November 21, 2019 Author Posted November 21, 2019 I am not sure, I think so. Attached are 2 more logs. One taken during a scan and the other just after.During Scan.txtAfter Scan.txt
Luke 42237 Posted November 21, 2019 Posted November 21, 2019 As a test, when you use the directory browser during library setup to add folders, does it display the sub-folders of your movie library?
sdann87 0 Posted November 22, 2019 Author Posted November 22, 2019 Yes, I can see the sub folders under the movies folder.
Luke 42237 Posted December 4, 2019 Posted December 4, 2019 @@sdann87, ok, one more test please. In the server dashboard please, go to Live TV -> Add TV Source, then select m3u. The file picker here will actually show both files and directories. If you use this, does the picker show the video files?
Luke 42237 Posted December 24, 2019 Posted December 24, 2019 hi, since 4.3.1.0 media sync doesn´t work Hi there @@Luene can you please describe the issue that you're having? Please see how to report a problem. Thanks !
