davedick 19 Posted November 19, 2019 Posted November 19, 2019 Using Emby Theater on Xbox one. On a Logitech Harmony remote, was able to use the play, pause, skip, review buttons, but now none of them are working. Did something change or is there a setting to look at? I can use the up/down arrows to bring up the on screen play/pause which still works
FrostByte 5453 Posted November 19, 2019 Posted November 19, 2019 No. All those buttons work on my media remote like the one below without bringing up the OSD. App v273
Solution davedick 19 Posted November 19, 2019 Author Solution Posted November 19, 2019 I went back and tried another Xbox, which worked. I unplugged the Xbox in question. Remote is working again 2
