shackbill 22 Posted November 18, 2019 Posted November 18, 2019 I thought i would just create a new thread since the other one was mainly server issues.. You mentioned the Cover Art problem is related to the Android/Skia Graphics library.. Is it possible to not use the latest library that is causing the problem - revert back to the last know good? If not, is it possible to at least enable the Cover Overlays? That in itself is a pretty nice enhancement. Thanks. 1
Luke 42238 Posted November 18, 2019 Posted November 18, 2019 Hi, it's not possible, no. Sometimes we have to update for other reasons unrelated to coverart. Since it is a plugin the core features will take priority.
ebr 16332 Posted November 18, 2019 Posted November 18, 2019 I believe the problem is only with overlays so disabling those may get you going with the other CA features at least. This is also limited only to some platforms and some situations.
shackbill 22 Posted November 18, 2019 Author Posted November 18, 2019 yea i get that the core is priority 1. Hopefully you guys can come up with something.. its only cosmetic so not a huge deal. thanks.
Luke 42238 Posted December 23, 2019 Posted December 23, 2019 If you'd like to try the latest beta release, that would be helpful. Thanks.
shackbill 22 Posted December 23, 2019 Author Posted December 23, 2019 that did it Thanks Luke! only minor point is that the server version says 4.4.0,3 but i installed 4.4.0.4
