easez88 16 Posted November 17, 2019 Posted November 17, 2019 Hello I have a movie in dvd format that is split in two discs. I'm not sure what the folder structure should be so Emby does not see it as two films but one. From the wiki I gather that I can do something like: Movie/movie-dvd1.mkv movie-dvd2.mkv I also see that I can do: Movie/VIDEO_TS/My question is, how do I combine these two naming conventions so Emby shows the movie once with two discs instead of duplicating the movie? Currently I have it setup as: Movie/Movie-dvd1/VIDEO_TS/ Movie-dvd2/VIDEO_TS/
Happy2Play 9806 Posted November 17, 2019 Posted November 17, 2019 Pretty sure all you can do is manually group then via multiselect options. 1
Luke 42217 Posted November 17, 2019 Posted November 17, 2019 Right we don't support multidisc folder rips. For the best experience I would suggest converting them to mkv and then joining the files.
easez88 16 Posted November 17, 2019 Author Posted November 17, 2019 Grouping is good enough for now. Thanks for the help.
