seanbuff 1353 Posted December 12, 2019 Posted December 12, 2019 Sorry let me clarify -- the successful one, yes, is a brand new show - did not exist prior. The 2 that failed, are existing shows.
seanbuff 1353 Posted December 12, 2019 Posted December 12, 2019 So what does the above mean @@Luke -- do you have any thoughts?Let me know if you need more info from my side, thanks
Luke 42216 Posted December 13, 2019 Posted December 13, 2019 Was it for a new season you didn't already have?
seanbuff 1353 Posted December 13, 2019 Posted December 13, 2019 For the failed ones, no - they are existing shows and existing seasons.i.e. Episode 10 and 13 respectively.
latinumking 7 Posted January 1, 2020 Author Posted January 1, 2020 I found out somehting really intersting yesterday. First of all, I still have the issue that new content is not shown under new content. But yesterday, I took an old DVD series that I have and used makemkv in order to get the software version out of it. I put the files according the naming convention in the folders "name of series" and "season 1". I noted that I am still not getting the new content on display on "latest series / latest episodes"... However, I noted the following: The series is shown if I manually search series. BUT the episodes are not shown in emby, it looks as only the series is identified, I cannot play anything. If I have a look in the episode 1 sub-directory, all episodes have been identified, the nfo file has been added. So it looks like the series does not appear with the latest updates. If I do start a manual update of the series library, everything just looks and works fine. Anybody got an idea? Thank you, Lati
Luke 42216 Posted January 1, 2020 Posted January 1, 2020 I found out somehting really intersting yesterday. First of all, I still have the issue that new content is not shown under new content. But yesterday, I took an old DVD series that I have and used makemkv in order to get the software version out of it. I put the files according the naming convention in the folders "name of series" and "season 1". I noted that I am still not getting the new content on display on "latest series / latest episodes"... However, I noted the following: The series is shown if I manually search series. BUT the episodes are not shown in emby, it looks as only the series is identified, I cannot play anything. If I have a look in the episode 1 sub-directory, all episodes have been identified, the nfo file has been added. So it looks like the series does not appear with the latest updates. If I do start a manual update of the series library, everything just looks and works fine. Anybody got an idea? Thank you, Lati Sounds like it hadn't yet completed the process of importing the new content into the server. Try giving it a few more minutes. Thanks.
