vfrjim 1 Posted November 15, 2019 Posted November 15, 2019 Running a Pixel 3, running Android 10 and when playing back music via Emby, it does not keep the phone unlocked and backlight on, is this a feature or a bug? Kinda problem when driving and listening to music. I saw no settings that I can change.Thanks! PS THANK YOU very much for a awesome server, I was a Plex, LONG TIME user and your app absolutely blows plex away, again, THANKS!
Luke 42243 Posted November 16, 2019 Posted November 16, 2019 Hi, thanks for the feedback ! To answer your question, no, we only do that during video playback, but i guess I can understand the use case you're asking for. Did the competitor's app require a setting to enable this? Or was it automatic with Android Auto ?
vfrjim 1 Posted November 16, 2019 Author Posted November 16, 2019 First of all, not using android auto, just connected via bluetooth to my radio in my car and yes, all my audio apps (Spotify, SiriusXM) allow the override of the lock screen via settings in the menu. I had to use an additional app to keep the backlight on when using plex but since my phone was recently updated to Android 10, that app will not function and BTW, the main reason that I left Plex was that they would not Direct Play a FLAC file, it would transcode it to ~550kbps which was not acceptable to me and they would not reply in fixing it and your app allowed me to direct play high-bitrate FLAC files, so I became a lifetime Emby user and abandoned my lifetime plex pass. Thanks for reading this.
Luke 42243 Posted November 16, 2019 Posted November 16, 2019 Ok thanks for the info. So then yes we can do that as well. We're not going to enable this by default, but we can add an option for this for music playback.
vfrjim 1 Posted November 16, 2019 Author Posted November 16, 2019 That's great. Can't wait for the feature (will make driving safer). Thanks!
kenpoole 0 Posted August 24, 2021 Posted August 24, 2021 Has there been any progress on this? I am trying to use an android tablet for playing my music from home when at work - and the screen keeps dimming. Android 9, emby app 3.2.05
Luke 42243 Posted August 25, 2021 Posted August 25, 2021 9 hours ago, kenpoole said: Has there been any progress on this? I am trying to use an android tablet for playing my music from home when at work - and the screen keeps dimming. Android 9, emby app 3.2.05 This type of option is something we can look into. Thanks for the feedback.
