Bazzu85 22 Posted November 19, 2019 Posted November 19, 2019 (edited) as addressed here: https://forums.thetvdb.com/viewtopic.php?f=122&t=60239&sid=0bfa8ea45dbcedcfabf7ce424df0ca89 do you see our zip problem ticket? Edited November 19, 2019 by Bazzu85
Luke 42198 Posted November 19, 2019 Posted November 19, 2019 as addressed here: https://forums.thetvdb.com/viewtopic.php?f=122&t=60239&sid=0bfa8ea45dbcedcfabf7ce424df0ca89 do you see our zip problem ticket? No I don't see it, but they did acknowledge it in another topic.
Bazzu85 22 Posted November 19, 2019 Posted November 19, 2019 No I don't see it, but they did acknowledge it in another topic. ok, the problem is the priority of the task.. I think it as to be on the first places.. hope the dev are working on it..
Luke 42198 Posted November 19, 2019 Posted November 19, 2019 We'll mention it in that thread to remind them.
stefan.ringel 0 Posted November 19, 2019 Posted November 19, 2019 Here's a patch to the tvdb plugin that works around the .zip.xml thing. Use at your own risk though because we don't know yet if the data coming back can be fully trusted at this point. Don't work! **** 2019-11-19 16:40:28.324 Info Main: Application path: /volume1/@appstore/EmbyServer/releases/4.2.1.0/EmbyServer.dll 2019-11-19 16:40:30.431 Info Main: Emby Command line: /volume1/@appstore/EmbyServer/releases/4.2.1.0/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.2.1.0 2019-11-19 16:40:30.612 Info App: Application version: 4.2.1.0 2019-11-19 16:40:30.621 Info App: Loading assemblies 2019-11-19 16:40:30.968 Info App: File /var/packages/EmbyServer/target/var/plugins/Tvdb.dll has version 1.0.19.0 2019-11-19 16:40:30.968 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/Tvdb.dll has version 1.0.19.0 2019-11-19 16:40:30.969 Info App: File /var/packages/EmbyServer/target/var/plugins/AudioDb.dll has version 1.0.6.0 2019-11-19 16:40:30.969 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/AudioDb.dll has version 1.0.6.0 2019-11-19 16:40:30.969 Info App: File /var/packages/EmbyServer/target/var/plugins/NfoMetadata.dll has version 1.0.19.0 2019-11-19 16:40:30.969 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/NfoMetadata.dll has version 1.0.18.0 2019-11-19 16:40:30.969 Info App: File /var/packages/EmbyServer/target/var/plugins/Emby.Server.CinemaMode.dll has version 1.0.26.0 2019-11-19 16:40:30.969 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/Emby.Server.CinemaMode.dll has version 1.0.22.0 2019-11-19 16:40:30.976 Info App: File /var/packages/EmbyServer/target/var/plugins/StudioImages.dll has version 1.0.1.0 2019-11-19 16:40:30.976 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/StudioImages.dll has version 1.0.1.0 2019-11-19 16:40:30.976 Info App: File /var/packages/EmbyServer/target/var/plugins/OpenSubtitles.dll has version 1.0.18.0 2019-11-19 16:40:30.976 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/OpenSubtitles.dll has version 1.0.18.0 2019-11-19 16:40:30.976 Info App: File /var/packages/EmbyServer/target/var/plugins/MovieDb.dll has version 1.2.6.0 2019-11-19 16:40:30.977 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/MovieDb.dll has version 1.1.9.0 2019-11-19 16:40:30.977 Info App: File /var/packages/EmbyServer/target/var/plugins/Emby.Dlna.dll has version 1.0.24.0 2019-11-19 16:40:30.977 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/Emby.Dlna.dll has version 1.0.23.0 2019-11-19 16:40:30.977 Info App: File /var/packages/EmbyServer/target/var/plugins/Fanart.dll has version 1.0.3.0 2019-11-19 16:40:30.977 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/Fanart.dll has version 1.0.3.0 2019-11-19 16:40:30.977 Info App: File /var/packages/EmbyServer/target/var/plugins/OMDb.dll has version 1.0.7.0 2019-11-19 16:40:30.977 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/OMDb.dll has version 1.0.6.0 2019-11-19 16:40:30.978 Info App: File /var/packages/EmbyServer/target/var/plugins/Emby.PortMapper.dll has version 1.0.2.0 2019-11-19 16:40:30.978 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/Emby.PortMapper.dll has version 1.0.2.0 2019-11-19 16:40:30.978 Info App: File /var/packages/EmbyServer/target/var/plugins/MusicBrainz.dll has version 1.0.9.0 2019-11-19 16:40:30.978 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/MusicBrainz.dll has version 1.0.9.0 2019-11-19 16:40:30.978 Info App: File /var/packages/EmbyServer/target/var/plugins/DvdMounter.dll has version 1.0.0.0 2019-11-19 16:40:30.978 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/DvdMounter.dll has version 1.0.0.0 2019-11-19 16:40:30.979 Info App: File /var/packages/EmbyServer/target/var/plugins/IsoMounter.dll has version 1.0.4.0 2019-11-19 16:40:30.979 Info App: File /volume1/@appstore/EmbyServer/releases/4.2.1.0/plugins/IsoMounter.dll has version 1.0.4.0 2019-11-19 16:40:31.031 Info App: Loading AudioDb, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/AudioDb.dll 2019-11-19 16:40:31.031 Info App: Loading Emby.Server.CinemaMode, Version=1.0.26.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/Emby.Server.CinemaMode.dll 2019-11-19 16:40:31.031 Info App: Loading Fanart, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/Fanart.dll 2019-11-19 16:40:31.031 Info App: Loading IsoMounter, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/IsoMounter.dll 2019-11-19 16:40:31.031 Info App: Loading MovieDb, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/MovieDb.dll 2019-11-19 16:40:31.031 Info App: Loading MusicBrainz, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/MusicBrainz.dll 2019-11-19 16:40:31.031 Info App: Loading NfoMetadata, Version=1.0.19.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/NfoMetadata.dll 2019-11-19 16:40:31.034 Info App: Loading OMDb, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/OMDb.dll 2019-11-19 16:40:31.034 Info App: Loading OpenSubtitles, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/OpenSubtitles.dll 2019-11-19 16:40:31.034 Info App: Loading StudioImages, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/StudioImages.dll 2019-11-19 16:40:31.034 Info App: Loading Tvdb, Version=1.0.19.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/Tvdb.dll 2019-11-19 16:40:31.034 Info App: Loading statistics, Version=2.0.13.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/Statistics.dll 2019-11-19 16:40:31.034 Info App: Loading Emby.Kodi.SyncQueue, Version=2.1.4.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/Emby.Kodi.SyncQueue.dll 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.Plugins.StudioCleaner, Version=3.2.1.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/StudioCleaner.dll 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.Plugins.Anime, Version=1.4.3.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/MediaBrowser.Plugins.Anime.dll 2019-11-19 16:40:31.034 Info App: Loading Emby.Dlna, Version=1.0.24.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/Emby.Dlna.dll 2019-11-19 16:40:31.034 Info App: Loading Emby.PortMapper, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/Emby.PortMapper.dll 2019-11-19 16:40:31.034 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/DvdMounter.dll 2019-11-19 16:40:31.034 Info App: Loading EmbyReports, Version=1.0.36.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/EmbyReports.dll 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.Api, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.WebDashboard, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.Model, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.Common, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.Controller, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.034 Info App: Loading MediaBrowser.Providers, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.034 Info App: Loading Emby.Photos, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.034 Info App: Loading Emby.Server.Implementations, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.LiveTV, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.ActivityLog, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.Server.MediaEncoding, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading MediaBrowser.LocalMetadata, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.Notifications, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.Codecs.Dxva, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.Codecs, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.Server.Connect, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading Emby.Server.Sync, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-19 16:40:31.035 Info App: Loading EmbyServer, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null * * 2019-11-19 16:43:19.948 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x01.061.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:19.948 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x01.061.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:19.948 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -i file:"/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x01.061.mp4" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2019-11-19 16:43:19.964 Info MediaEncoder: ProcessRun 'ffprobe' Started. 2019-11-19 16:43:20.014 Info MediaEncoder: ProcessRun 'ffprobe' Process exited with code 0 2019-11-19 16:43:20.119 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/81797/all/de.zip 2019-11-19 16:43:20.239 Error App: Error in TheTVDB *** Error Report *** Version: 4.2.1.0 Command line: /volume1/@appstore/EmbyServer/releases/4.2.1.0/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.2.1.0 System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/packages/EmbyServer/target/var/cache/tvdb/81797/de.xml'. File name: '/var/packages/EmbyServer/target/var/cache/tvdb/81797/de.xml' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) in /source/coreclr/src/mscorlib/shared/Interop/Unix/Interop.IOErrors.cs:line 23 at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) in /source/coreclr/src/mscorlib/shared/Microsoft/Win32/SafeHandles/SafeFileHandle.Unix.cs:line 78 at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) in /source/coreclr/src/mscorlib/shared/System/IO/FileStream.cs:line 230 at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at Tvdb.TvdbSeriesProvider.ExtractEpisodes(String seriesDataPath, String xmlFile, Nullable`1 lastTvDbUpdateTime) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetMetadata(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[interop+ErrorInfo,Interop+ErrorInfo]) 2019-11-19 16:43:20.240 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x01.061.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:20.240 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x01.061.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:20.241 Info MediaEncoder: ProcessRun 'extract-image' Execute: /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ss 00:02:04.728 -f mp4 -i file:"/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x01.061.mp4" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/packages/EmbyServer/target/var/cache/temp/fe8c3c72-1df9-4644-8e7b-0e1370564e42.jpg" 2019-11-19 16:43:20.257 Info MediaEncoder: ProcessRun 'extract-image' Started. 2019-11-19 16:43:20.730 Info MediaEncoder: ProcessRun 'extract-image' Process exited with code 0 2019-11-19 16:43:20.776 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x07.067.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:20.776 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x07.067.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:20.776 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -i file:"/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x07.067.mp4" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2019-11-19 16:43:20.791 Info MediaEncoder: ProcessRun 'ffprobe' Started. 2019-11-19 16:43:20.834 Info MediaEncoder: ProcessRun 'ffprobe' Process exited with code 0 2019-11-19 16:43:20.837 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/81797/all/de.zip 2019-11-19 16:43:20.951 Error App: Error in TheTVDB *** Error Report *** Version: 4.2.1.0 Command line: /volume1/@appstore/EmbyServer/releases/4.2.1.0/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.2.1.0 System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/packages/EmbyServer/target/var/cache/tvdb/81797/de.xml'. File name: '/var/packages/EmbyServer/target/var/cache/tvdb/81797/de.xml' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) in /source/coreclr/src/mscorlib/shared/Interop/Unix/Interop.IOErrors.cs:line 23 at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) in /source/coreclr/src/mscorlib/shared/Microsoft/Win32/SafeHandles/SafeFileHandle.Unix.cs:line 78 at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) in /source/coreclr/src/mscorlib/shared/System/IO/FileStream.cs:line 230 at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at Tvdb.TvdbSeriesProvider.ExtractEpisodes(String seriesDataPath, String xmlFile, Nullable`1 lastTvDbUpdateTime) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetMetadata(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[interop+ErrorInfo,Interop+ErrorInfo]) 2019-11-19 16:43:20.952 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x07.067.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:20.952 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x07.067.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:20.953 Info MediaEncoder: ProcessRun 'extract-image' Execute: /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ss 00:01:58.226 -f mp4 -i file:"/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x07.067.mp4" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/packages/EmbyServer/target/var/cache/temp/bb743e74-cd54-4b0f-9bb4-9a8a94c9b050.jpg" 2019-11-19 16:43:20.968 Info MediaEncoder: ProcessRun 'extract-image' Started. 2019-11-19 16:43:21.430 Info MediaEncoder: ProcessRun 'extract-image' Process exited with code 0 2019-11-19 16:43:21.552 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x08.068.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:21.552 Info App: [LinuxMount] Checking we can attempt to mount [/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x08.068.mp4], Extension = [.mp4], Operating System = [Linux], Executables Available = [True]. 2019-11-19 16:43:21.552 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -i file:"/volume3/Media 3/Plex Anime/One Piece/Staffel 5/5x08.068.mp4" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data ****
moviefan 187 Posted November 19, 2019 Posted November 19, 2019 Works okay for me. Now just need to figure out how to get back to stable release without screwing up my deployment again.
Bazzu85 22 Posted November 19, 2019 Posted November 19, 2019 I tried to refresh metadata for The mandalorian and the result in log for me is the FileNotFoundException relating the it.xml file. I don't see anymore zip corrupted as days ago.. so I think the problem is addressed as this: API queries returning missing data for non-English language shows — Researching | related forum thread https://forums.thetvdb.com/viewtopic.php?f=17&p=163153&sid=c53a71bddd6ff34b9a5dc5842856c8db#p163153
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 Will need other non-english language metadata users to confirm, but the few non-english zips that I have pulled appear to work properly. So it may be show specific. Or failed translations.
GiGo 108 Posted November 19, 2019 Posted November 19, 2019 Here's a patch to the tvdb plugin that works around the .zip.xml thing. Use at your own risk though because we don't know yet if the data coming back can be fully trusted at this point. Edit: Tvdb plugin update 1.0.20 released. Thanks Luke but...... can't see a link and would this work with a Synology release?
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 Thanks Luke but...... can't see a link and would this work with a Synology release? Restart your server and it should pull down the plugin update. 1
neik 874 Posted November 19, 2019 Posted November 19, 2019 (edited) @@GiGo, that's because the fix went into the latest update of the TVDB plugin. Happy was faster than me. :-P Feel free to delete. ;-) Edited November 19, 2019 by neik 1
Luke 42198 Posted November 19, 2019 Posted November 19, 2019 Yea the fix looks OK for right now for English users, or at the very least, better than without it. For non-english users you may have to wait until tvdb resolves it on their end.
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 Yea the fix looks OK for right now for English users, or at the very least, better than without it. For non-english users you may have to wait until tvdb resolves it on their end. He luke can you please tell me how to find that file in synology to upload it at ?
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 (edited) He luke can you please tell me how to find that file in synology to upload it at ? Just restart Emby server and it should pull down the plugin update. Edited November 19, 2019 by Happy2Play
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 Hello But i dont know where to put yet that was mine issue i could not find it on synology server
chef 3811 Posted November 19, 2019 Posted November 19, 2019 Working again on windows. Thank you for that. 1
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 With this patch virtual items are being created again, so this fixes the Upcoming items disappearing. For items that are missing a series refresh would be needed to get metadata again and possibly a library scan 1
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 (edited) Hello But i dont know where to put yet that was mine issue i could not find it on synology server The zip was deleted as the plugin got updated in the catalog. So all you have to do is restart your server to get the update or go to the plugin catalog and re-install the new update. But if you want to do it manually, you have to SSH to Program data path: /var/packages/EmbyServer/target/var/plugins. Edited November 19, 2019 by Happy2Play
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 The zip was deleted as the plugin got updated in the catalog. So all you have to do is restart your server to get the update or go to the plugin catalog and re-install the new update. But if you want to do it manually, you have to SSH to Program data path: /var/packages/EmbyServer/target/var/plugins. Oh k thank you i misunderstood it but now when i restarted it said that needed it to restart again for the update too be done
cochize1 55 Posted November 19, 2019 Posted November 19, 2019 Can confirm that the patch works on Synology Emby 4.2.1.0, all TV series populated correctly and the Upcoming episodes are shown. Does it mean we can expect the new stable 4.3 release now? 1
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 Can confirm that the patch works on Synology Emby 4.2.1.0, all TV series populated correctly and the Upcoming episodes are shown. Does it mean we can expect the new stable 4.3 release now? I would wait a few more days to allow things to stabilize.
GiGo 108 Posted November 19, 2019 Posted November 19, 2019 an confirm that the patch works on Synology Emby 4.2.1.0, all TV series populated correctly and the Upcoming episodes are shown. Does it mean we can expect the new stable 4.3 release now? I can confirm this too. Yea the fix looks OK for right now for English users, or at the very least, better than without it. For non-english users you may have to wait until tvdb resolves it on their end. Great work, great service from the Emby team! Restart your server and it should pull down the plugin update. Just done it, works great! Cheers.
cochize1 55 Posted November 19, 2019 Posted November 19, 2019 (edited) Hmm... Just checked and the fix doesn't seem to work on my Cartoon library: not showing missing or upcoming episodes for South Park, Simpsons and Family Guy. Anyone having this issue? Edit: also re-checked more TV Series episodes and still there are some missing, i.e. Watchmen or Silicon Valley although Mandalorian populated correctly... strange Edited November 19, 2019 by cochize1
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 (edited) Hmm... Just checked and the fix doesn't seem to work on my Cartoon library: not showing missing or upcoming episodes for South Park, Simpsons and Family Guy. Anyone having this issue? Edit: also re-checked more TV Series episodes and still there are some missing, i.e. Watchmen or Silicon Valley although Mandalorian populated correctly... strange Did you Refresh the metadata for those series and do a library scan? I have Upcoming entries for Simpsons and Family Guy. Edited November 19, 2019 by Happy2Play
Luke 42198 Posted November 19, 2019 Posted November 19, 2019 Yea manual refreshes will be required for that information because the tvdb updates api is still not working. Normally it would just be automatic as part of the regular library scan. That's a minor thing though compared to basic metadata retrieval, so we'll just have to wait for them to resolve that.
