MSacre 1 Posted November 19, 2019 Posted November 19, 2019 TVDB updated consolidated list. https://forums.thetvdb.com/viewtopic.php?f=122&p=163719&sid=11ecdfd4d74439ccb5052bab801ddcad#p163719 Awaiting a follow up on our zip/xml issue. My AutoOrganize is still broken. What issue is covering the problem? This one? API is delivering a zip file discrepancy for Kodi user [TVDB] Possible Special Character Issue — Released 11/18 | related forum thread ?
GiGo 108 Posted November 19, 2019 Posted November 19, 2019 TVDB.com has broken their API's it is nothing to do with Emby and the Auto Organize plugin TVDB.com will sort it out - eventually! I don't understand why they don't just switch the API back to v2 and do more testing on v3!
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 They had most of these issue the last time they did this. I have a feeling they would prefer everyone else to change, but there are a lot of programs out there that are no longer being developed. The had to re-enable SSL 3 do legacy software out there. As for Auto Organizer it is dependant on metadata from provider to be able to move media. Currently the metadata that is coming back from TVDB has changed and they have said they are going to fix it. But in the end we may have to put a patch in place for the issue. But at the same time it has been reported on their site that this data may be old data also. As reported about the Auto Organizer it would appear other providers work in the beta server branch. When something is dependant on one site you can see how it will affect everything.
Michael.D.Pine 4 Posted November 19, 2019 Posted November 19, 2019 Sorry, just want to confirm is this related the the following error I am seeing in my logs ? 2019-11-19 01:58:57.357 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/71762/all/en.zip2019-11-19 01:58:57.796 Error App: Error in TheTVDB *** Error Report *** Version: 4.2.1.0 Command line: C:\Users\HomeTheatre\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/HomeTheatre/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Program data path: C:\Users\HomeTheatre\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\HomeTheatre\AppData\Roaming\Emby-Server\system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file 'C:\Users\HomeTheatre\AppData\Roaming\Emby-Server\programdata\cache\tvdb\71762\en.xml'. File name: 'C:\Users\HomeTheatre\AppData\Roaming\Emby-Server\programdata\cache\tvdb\71762\en.xml' at System.IO.FileStream.ValidateFileHandle(SafeFileHandle fileHandle) at System.IO.FileStream.CreateFileOpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at Tvdb.TvdbSeriesProvider.ExtractEpisodes(String seriesDataPath, String xmlFile, Nullable`1 lastTvDbUpdateTime) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.GetMetadata(SeriesInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Microsoft.Win32.SafeHandles.SafeFileHandle ValidateFileHandle(Microsoft.Win32.SafeHandles.SafeFileHandle)
Happy2Play 9802 Posted November 19, 2019 Posted November 19, 2019 Yep waiting on TVDB. https://forums.thetvdb.com/viewtopic.php?p=163518#p163518
GiGo 108 Posted November 19, 2019 Posted November 19, 2019 As reported about the Auto Organizer it would appear other providers work in the beta server branch. My server is running on my Synology and Emby are not accepting Beta users :/ annoying for me at the min but I'm sure TVDB will sort it out soon.
Michael.D.Pine 4 Posted November 19, 2019 Posted November 19, 2019 Yep waiting on TVDB. https://forums.thetvdb.com/viewtopic.php?p=163518#p163518 THanks
Flappafluppa 0 Posted November 19, 2019 Posted November 19, 2019 Hi there. Movie identification is working fine, however TV series identification simply returns no results, even with IMDB codes that worked a before (seems this problem is about 1 week or two old). Is there something up with this, shall I just wait for a fix or is this a deeper issue? I am not even getting any new episode descriptions or anything like it used to do. Simpy showing the file name (my library is named as emby requires).
echoxxzz 22 Posted November 19, 2019 Posted November 19, 2019 (edited) Exact same behavior here. Problem started 2 days ago for me. I can pull down art work from fanart but nothing from tvdb including metadata. Edited November 19, 2019 by echoxxzz
techieboy 1 Posted November 19, 2019 Posted November 19, 2019 I guess it's related to the pinned topic at the top of the forum https://emby.media/community/index.php?/topic/79269-tvdb-api-issues/?p=806574 1
pueex 0 Posted November 19, 2019 Posted November 19, 2019 Hi.I tried to identify several series using imdb tag and failed, the server gives me empty result page.Went ahead and checked the logs. seems like the requests to tvdb are ok AND returns the file, also the files are saved i nthe cache directory as they should.I did notice that the logs are displaying exception : `System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/config/cache/tvdb/tt4047038/en.xml'`it is indeed true. the zip file from the tvdb: `https://www.thetvdb.com/api/B89CE93890E9419B/series/312505/all/en.zip`does not contains 'en.xml' but 'en.zip.xml' could be a bug in tvdb or could be they decided to change it. looks more like a bug if you ask me, but, can you reffer me to the place in the code that searches this file ? i think of building from source. Also if you have an idea where can i file a bug report for tvdb let me know and i will. thanks.
Flappafluppa 0 Posted November 19, 2019 Posted November 19, 2019 I guess it's related to the pinned topic at the top of the forum https://emby.media/community/index.php?/topic/79269-tvdb-api-issues/?p=806574 Thanks for the heads up! Good to know its a problem and it might get fixed soon. The worry is always that one has messed something up ones self.. Phew!
Flappafluppa 0 Posted November 19, 2019 Posted November 19, 2019 Glad to know it's not just me, but sad that we are having issues due to this! Patience fellow Embyians !
mccune68 1 Posted November 19, 2019 Posted November 19, 2019 It's a known issue with the TVDB API: https://emby.media/community/index.php?/topic/79269-tvdb-api-issues/
pueex 0 Posted November 19, 2019 Posted November 19, 2019 @@pueex thanks, didnt know that. but does that mean we need t wait for a fix? easier patching emby i think... no?
Solution Luke 42198 Posted November 19, 2019 Solution Posted November 19, 2019 (edited) Here's a patch to the tvdb plugin that works around the .zip.xml thing. Use at your own risk though because we don't know yet if the data coming back can be fully trusted at this point. Edit: Tvdb plugin update 1.0.20 released. See post 385 Edited January 15, 2020 by Happy2Play 11
StLDreiling 16 Posted November 19, 2019 Posted November 19, 2019 Here's a patch to the tvdb plugin that works around the .zip.xml thing. Use at your own risk though because we don't know yet if the data coming back can be fully trusted at this point. AutoOrganize grabbed all my shows! Thanks much, @@Luke! Heeding your warning, changed provider priority until you guys sound the all clear on theTVDB.
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 AutoOrganize grabbed all my shows! Thanks much, @@Luke! Heeding your warning, changed provider priority until you guys sound the all clear on theTVDB. Can you please share how to use the file i use emby on synology
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 Here's a patch to the tvdb plugin that works around the .zip.xml thing. Use at your own risk though because we don't know yet if the data coming back can be fully trusted at this point. Can you please share how to use the file
frankw 10 Posted November 19, 2019 Posted November 19, 2019 Can you please share how to use the file Overwrite the existing dll in plugins directory.
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 He on the synology drive the go to embysvr file correct ?
psybertech 33 Posted November 19, 2019 Posted November 19, 2019 Here's a patch to the tvdb plugin that works around the .zip.xml thing. Use at your own risk though because we don't know yet if the data coming back can be fully trusted at this point. Thanks for the DLL @@Luke. Working great so far. I'm still keeping a list of shows from the start of all of this until its all officially over... just in case. Anyway... thanks again. j
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 I am little new to emby dont know where i can find it i use it synology file
Gofran 6 Posted November 19, 2019 Posted November 19, 2019 Overwrite the existing dll in plugins directory.I am little new to emby dont know where i can find it i use it synology file
