hifiaudio2 48 Posted November 18, 2019 Posted November 18, 2019 Auto organize has been working terrifically until the past (week or so?). Now it does not identify content of two different shows that it previously has known and has folders for. When I try to manually select the series and tell it to find content, I get "error Null" @@hifiaudio2
Happy2Play 9802 Posted November 18, 2019 Posted November 18, 2019 (edited) We are waiting on TVDB to fix this. Edited November 18, 2019 by Happy2Play 2
lifespeed 42 Posted November 18, 2019 Posted November 18, 2019 Tonight I saw Emby change the folder name for recordings from TVShow (2019) to TVShow. This has happened before, probably last time the year was added instead of removed from the folder name. Is it the fault of the guide data from SchedulesDirect, or is this an Emby quirk that could be improved? All I can think to do now is move the old shows into the new recorded TV folder Emby created. Which works, but this does seem to happen pretty often, and the manual fiddling seems unnecessary. 1
lifespeed 42 Posted November 18, 2019 Posted November 18, 2019 The guide data doesn't contain the series year. we try to get it from tvdb, but that's not happening right now due to this: https://emby.media/community/index.php?/topic/79269-fyi-tvdb-api-issues/ Thanks for the explanation.
yfeldman 0 Posted November 18, 2019 Posted November 18, 2019 Sometime during the last couple of days my Auto Organize plug in has stopped working. I have restarted Emby. Removed and reinstalled the AO plugin. Removed every other plugin (didn't have Anime, but I figured maybe there was something else). Nothing has helped. If I select clear and then try to organize, there is nothing on the screen. I have to reload in order to see that nothing has happened. If I manually insert every file into it's appropriate directory, all is good. Thanks!
darkassassin07 672 Posted November 18, 2019 Posted November 18, 2019 https://emby.media/community/index.php?/topic/79269-fyi-tvdb-api-issues/?view=getnewpost Tvdb is broken atm. Auto organize is dependent on it. Nothing to do but wait for tvdb to get sorted out. 3
hamun8 0 Posted November 18, 2019 Posted November 18, 2019 @@hamun8 Hi I am suddenly having strange problems with emby. First auto organize said it could not find metadata. I restarted Emby and my synology, but nothing helped. I then deleted, the plugin and when i try to download it again, it just keeps loading. Now i restarted my NAS again, i saw following in dashboard alerts: Check for application updates failed Check for plugin updates failed I have attached the log. I hope someone have an idea to what it is? Error Log.txt
Dedone 17 Posted November 18, 2019 Posted November 18, 2019 @@Dedone same here for me version 4.2.1.0 on Synology DS218+ log: Resource temporarily unavailable at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult(String organzation, String repository, Version minVersion, PackageVersionClass updateLevel, String assetFilename, String packageName, String targetFilename, TimeSpan cacheLength, CancellationToken cancellationToken) at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
yotoprules 0 Posted November 18, 2019 Posted November 18, 2019 Is this why episode names and description aren't automatically added?
neik 874 Posted November 18, 2019 Posted November 18, 2019 (edited) Yes, as the plugin can't get the information from TVDB. ;-) Give it some days, it will hopefully get fixed anytime soon. Edited November 18, 2019 by neik 1
hamun8 0 Posted November 18, 2019 Posted November 18, 2019 But why can't I download the plug-in again? This only shows problems with the meta info
Luke 42198 Posted November 18, 2019 Posted November 18, 2019 But why can't I download the plug-in again? This only shows problems with the meta info The log says name resolution failure. Make sure you don't have anything blocking access to our mb3admin.com domain, such as security software, firewall, or VPN .
moviefan 187 Posted November 18, 2019 Posted November 18, 2019 I have changed mine and it is working again, there are 3 sections that you have to move it to the top of the list Series metadata downloaders Season metadata downloaders Episode metadata downloaders edit: I'm running 4.3.0.22 beta if that makes any difference Can anyone else confirm that Auto Organize works for them in the beta version? I just went through the process up upgrading to Beta. Messed up my whole Emby server pretty badly along with way (totally my fault) but now that I am on Beta and have disabled all the TVDB settings for the TV library, Auto Organize is still not working. Very disappointing.
vdatanet 1619 Posted November 18, 2019 Posted November 18, 2019 Can anyone else confirm that Auto Organize works for them in the beta version? I just went through the process up upgrading to Beta. Messed up my whole Emby server pretty badly along with way (totally my fault) but now that I am on Beta and have disabled all the TVDB settings for the TV library, Auto Organize is still not working. Very disappointing. Auto organize works with beta, but you have to disable thetvdb scraper to add episodes to a TV Show. If you need to create a new TV Show, you have to create the folder a run a library scan.
moviefan 187 Posted November 18, 2019 Posted November 18, 2019 Does this look right? Not working still.
vdatanet 1619 Posted November 18, 2019 Posted November 18, 2019 Does this look right? Not working still. It works for me. Are you trying to add episodes to an existing TV Show? Or you are adding episodes to a new TV Show?
moviefan 187 Posted November 18, 2019 Posted November 18, 2019 It works for me. Are you trying to add episodes to an existing TV Show? Or you are adding episodes to a new TV Show? Both things fail for me. It's still working on the initial library scan after i Fd up everything so maybe that is the issue. But it sees the series if I try to manually select the location with the browse icon and I still get the result "Null" when trying it.
vdatanet 1619 Posted November 18, 2019 Posted November 18, 2019 Both things fail for me. It's still working on the initial library scan after i Fd up everything so maybe that is the issue. But it sees the series if I try to manually select the location with the browse icon and I still get the result "Null" when trying it. Can you post your server log?
frankw 10 Posted November 18, 2019 Posted November 18, 2019 Can you post your server log? What does this have to do with this thread about TVDB API?
vdatanet 1619 Posted November 18, 2019 Posted November 18, 2019 (edited) I just try to answer questions and help. It's related to Auto Organize plugin: https://emby.media/community/index.php?/topic/79307-auto-organize-plugin-use-additional-scrappers-when-thetvdb-fails/ Server Beta can run Auto Organize even thetvdb fails. So there's a connection with this thread. Edited November 18, 2019 by vdatanet 1
vdatanet 1619 Posted November 18, 2019 Posted November 18, 2019 Does this look right? Not working still. Tested again and it really works:
moviefan 187 Posted November 18, 2019 Posted November 18, 2019 It just worked on one of the series sitting there so I am hoping it is just a matter of completing the media scan at this point. I'll post some logs if it isnt' resolved. Thanks for your help.
AllesMeins 27 Posted November 18, 2019 Posted November 18, 2019 @@AllesMeins Today I noticed that the Auto-Organize feature no longer works. All episodes just stay inside the import-folder and are marked red in the activity log. It seems the problem is with a cache-file that cannot be found ("System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/media/Storage_Intern/emby/cache/tvdb/70522/en.xml'."). Inside that folder is a file named "en.zip.xml", so that might be the problem. The complete error entry for a given episode is as follows 2019-11-18 23:10:11.233 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt2149175&Episode=11&Season=1 2019-11-18 23:10:11.326 Warn App: No provider metadata found for The Americans (2013) season 1 episode 11 2019-11-18 23:10:11.327 Info App: Sorting file /media/2ada94ab-cbcc-41ec-b19b-bfc46c5dc611/Media/Serien_Import/The Americans s01e10.mkv 2019-11-18 23:10:11.342 Debug App: Extracted information from /media/2ada94ab-cbcc-41ec-b19b-bfc46c5dc611/Media/Serien_Import/The Americans s01e10.mkv. Series name The Americans, Season 1, Episode 10 2019-11-18 23:10:11.350 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/261690/all/en.zip 2019-11-18 23:10:12.111 Error ProviderManager: Error searching *** Error Report *** Version: 4.2.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /media/Storage_Intern/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.19.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Program data path: /media/Storage_Intern/emby Application directory: /opt/emby-server/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/media/Storage_Intern/emby/cache/tvdb/261690/en.xml'. File name: '/media/Storage_Intern/emby/cache/tvdb/261690/en.xml' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at Tvdb.TvdbSeriesProvider.ExtractEpisodes(String seriesDataPath, String xmlFile, Nullable`1 lastTvDbUpdateTime) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2019-11-18 23:10:12.274 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt2149175&Episode=10&Season=1 2019-11-18 23:10:12.370 Warn App: No provider metadata found for The Americans (2013) season 1 episode 10 Startup-Info/Emby Version 2019-11-18 23:05:15.246 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2019-11-18 23:05:15.866 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /media/Storage_Intern/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.19.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Program data path: /media/Storage_Intern/emby Application directory: /opt/emby-server/system 2019-11-18 23:05:15.975 Info App: Application version: 4.2.1.0 2019-11-18 23:05:15.980 Info App: Loading assemblies 2019-11-18 23:05:16.555 Info App: File /media/Storage_Intern/emby/plugins/Emby.Server.CinemaMode.dll has version 1.0.26.0 2019-11-18 23:05:16.556 Info App: File /opt/emby-server/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.22.0 2019-11-18 23:05:16.977 Info App: File /media/Storage_Intern/emby/plugins/OpenSubtitles.dll has version 1.0.18.0 2019-11-18 23:05:16.979 Info App: File /opt/emby-server/system/plugins/OpenSubtitles.dll has version 1.0.18.0 2019-11-18 23:05:17.423 Info App: File /media/Storage_Intern/emby/plugins/StudioImages.dll has version 1.0.1.0 2019-11-18 23:05:17.424 Info App: File /opt/emby-server/system/plugins/StudioImages.dll has version 1.0.1.0 2019-11-18 23:05:18.069 Info App: File /media/Storage_Intern/emby/plugins/OMDb.dll has version 1.0.7.0 2019-11-18 23:05:18.070 Info App: File /opt/emby-server/system/plugins/OMDb.dll has version 1.0.6.0 2019-11-18 23:05:18.652 Info App: File /media/Storage_Intern/emby/plugins/Emby.Dlna.dll has version 1.0.24.0 2019-11-18 23:05:18.654 Info App: File /opt/emby-server/system/plugins/Emby.Dlna.dll has version 1.0.23.0 2019-11-18 23:05:19.193 Info App: File /media/Storage_Intern/emby/plugins/Tvdb.dll has version 1.0.19.0 2019-11-18 23:05:19.194 Info App: File /opt/emby-server/system/plugins/Tvdb.dll has version 1.0.17.0 2019-11-18 23:05:19.603 Info App: File /media/Storage_Intern/emby/plugins/DvdMounter.dll has version 1.0.0.0 2019-11-18 23:05:19.605 Info App: File /opt/emby-server/system/plugins/DvdMounter.dll has version 1.0.0.0 2019-11-18 23:05:20.064 Info App: File /media/Storage_Intern/emby/plugins/Fanart.dll has version 1.0.3.0 2019-11-18 23:05:20.065 Info App: File /opt/emby-server/system/plugins/Fanart.dll has version 1.0.3.0 2019-11-18 23:05:20.425 Info App: File /media/Storage_Intern/emby/plugins/NfoMetadata.dll has version 1.0.19.0 2019-11-18 23:05:20.427 Info App: File /opt/emby-server/system/plugins/NfoMetadata.dll has version 1.0.18.0 2019-11-18 23:05:20.858 Info App: File /media/Storage_Intern/emby/plugins/MovieDb.dll has version 1.2.6.0 2019-11-18 23:05:20.860 Info App: File /opt/emby-server/system/plugins/MovieDb.dll has version 1.1.9.0 2019-11-18 23:05:21.232 Info App: File /media/Storage_Intern/emby/plugins/Emby.PortMapper.dll has version 1.0.2.0 2019-11-18 23:05:21.233 Info App: File /opt/emby-server/system/plugins/Emby.PortMapper.dll has version 1.0.2.0 2019-11-18 23:05:22.211 Info App: Loading StudioImages, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/StudioImages.dll 2019-11-18 23:05:22.211 Info App: Loading OpenSubtitles, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/OpenSubtitles.dll 2019-11-18 23:05:22.211 Info App: Loading AutoBoxSets, Version=1.2.3.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/AutoBoxSets.dll 2019-11-18 23:05:22.211 Info App: Loading MediaBrowser.Plugins.Trailers, Version=1.2.8.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Mediabrowser.Plugins.Trailers.dll 2019-11-18 23:05:22.211 Info App: Loading NfoMetadata, Version=1.0.19.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/NfoMetadata.dll 2019-11-18 23:05:22.211 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/DvdMounter.dll 2019-11-18 23:05:22.211 Info App: Loading MovieDb, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/MovieDb.dll 2019-11-18 23:05:22.211 Info App: Loading Emby.Server.CinemaMode, Version=1.0.26.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Emby.Server.CinemaMode.dll 2019-11-18 23:05:22.211 Info App: Loading Emby.PortMapper, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Emby.PortMapper.dll 2019-11-18 23:05:22.211 Info App: Loading Emby.Kodi.SyncQueue, Version=2.1.4.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Emby.Kodi.SyncQueue.dll 2019-11-18 23:05:22.212 Info App: Loading OMDb, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/OMDb.dll 2019-11-18 23:05:22.212 Info App: Loading Emby.AutoOrganize, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Emby.AutoOrganize.dll 2019-11-18 23:05:22.212 Info App: Loading Tvdb, Version=1.0.19.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Tvdb.dll 2019-11-18 23:05:22.212 Info App: Loading Emby.Dlna, Version=1.0.24.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Emby.Dlna.dll 2019-11-18 23:05:22.212 Info App: Loading Fanart, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /media/Storage_Intern/emby/plugins/Fanart.dll 2019-11-18 23:05:22.212 Info App: Loading MediaBrowser.Api, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading MediaBrowser.WebDashboard, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading MediaBrowser.Model, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading MediaBrowser.Common, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading MediaBrowser.Controller, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading MediaBrowser.Providers, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Photos, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Server.Implementations, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.LiveTV, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.ActivityLog, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Server.MediaEncoding, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading MediaBrowser.LocalMetadata, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Notifications, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Codecs.Dxva, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Codecs, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Server.Connect, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading Emby.Server.Sync, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.212 Info App: Loading EmbyServer, Version=4.2.1.0, Culture=neutral, PublicKeyToken=null 2019-11-18 23:05:22.570 Info SqliteUserRepository: Sqlite version: 3.29.0 2019-11-18 23:05:22.572 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2019-11-18 23:05:29.878 Info SqliteUserRepository: Default journal_mode for /media/Storage_Intern/emby/data/users.db is wal 2019-11-18 23:05:30.228 Info AuthenticationRepository: Default journal_mode for /media/Storage_Intern/emby/data/authentication.db is wal 2019-11-18 23:05:30.665 Info ActivityRepository: Default journal_mode for /media/Storage_Intern/emby/data/activitylog.db is wal 2019-11-18 23:05:31.027 Info SqliteDisplayPreferencesRepository: Default journal_mode for /media/Storage_Intern/emby/data/displaypreferences.db is wal Any idea what is going on here?
Happy2Play 9802 Posted November 18, 2019 Posted November 18, 2019 Yes this is do to the other dozen topic about TVDB broke their api in their upgrade and Emby has to wait just like the majority of all media managers for them to fix all the bugs in their update. https://emby.media/community/index.php?/topic/79269-tvdb-api-issues/
AvengersFan 10 Posted November 18, 2019 Posted November 18, 2019 So just to confirm, this is only for beta 4.3 correct? Cheers Mark
