Happy2Play 9802 Posted November 16, 2019 Posted November 16, 2019 (edited) Looks like minor progress for v1 api returned zips. https://forums.thetvdb.com/viewtopic.php?p=163167&sid=947cc010c119fabaf34570f50ae5c7e8#p163167 Edited November 16, 2019 by Happy2Play 1
frankw 10 Posted November 16, 2019 Posted November 16, 2019 (edited) Looks like minor progress for v1 api returned zips. https://forums.thetvdb.com/viewtopic.php?p=163167&sid=947cc010c119fabaf34570f50ae5c7e8#p163167 Yeah that's what I have 2019-11-16 14:41:34.948 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /bin/ffprobe -i file:"/storage/TV/Chicago Med/S05/Chicago.Med.s05e08.1080p.WEB-DL.AVC.EAC3.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2019-11-16 14:41:35.258 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/295640/all/en.zip 2019-11-16 14:41:35.340 Error App: Error in TheTVDB *** Error Report *** Version: 4.3.0.22 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 5.3.0.23 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll Processor count: 4 Program data path: /config Application directory: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/config/cache/tvdb/295640/en.xml'. File name: '/config/cache/tvdb/295640/en.xml' and frank@media:~/docker/emby/cache/tvdb/295640$ ll total 204K drwxrwxr-x+ 2 frank docker 12K Nov 16 14:41 ./ drwxrwxr-x+ 36 frank docker 4.0K Nov 13 15:34 ../ -rw-rw-r--+ 1 frank docker 2.0K Nov 16 14:41 actors.xml -rw-rw-r--+ 1 frank docker 22K Nov 16 14:41 banners.xml -rw-rw-r--+ 1 frank docker 157K Nov 16 14:41 en.zip.xml Edited November 16, 2019 by frankw
kevlar2010 10 Posted November 16, 2019 Posted November 16, 2019 Well, thanks for the update. I will keep an eye on it.
Spanner 0 Posted November 16, 2019 Posted November 16, 2019 (edited) Hi, @@Spanner As of this morning auto organise has not been working. The episode has a entry on TVDB and the file it is trying to download is availiable. It gives Error: null. It is not just this episode but all in the queue. The emby cache is accessible through windows explorer. Any ideas? 2019-11-16 19:45:36.252 Info App: Sorting file C:\Download\Titans.S02E11.1080p.WEBRip.X264-METCON[rarbg]\Titans.S02E11.1080p.WEBRip.X264-METCON.mkv 2019-11-16 19:45:36.265 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/341663/all/en.zip 2019-11-16 19:45:36.306 Error ProviderManager: Error searching *** Error Report *** Version: 4.2.1.0 Command line: C:\Users\stjbo\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/stjbo/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Program data path: C:\Users\stjbo\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\stjbo\AppData\Roaming\Emby-Server\system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file 'D:\Emby Cache\cache\tvdb\341663\en.xml'. File name: 'D:\Emby Cache\cache\tvdb\341663\en.xml' at System.IO.FileStream.ValidateFileHandle(SafeFileHandle fileHandle) at System.IO.FileStream.CreateFileOpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at Tvdb.TvdbSeriesProvider.ExtractEpisodes(String seriesDataPath, String xmlFile, Nullable`1 lastTvDbUpdateTime) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Microsoft.Win32.SafeHandles.SafeFileHandle ValidateFileHandle(Microsoft.Win32.SafeHandles.SafeFileHandle) 2019-11-16 19:45:36.307 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt1043813&Episode=11&Season=2 2019-11-16 19:45:36.354 Warn App: No provider metadata found for Titans (2018) season 2 episode 11 Edited November 16, 2019 by Luke
Luke 42198 Posted November 17, 2019 Posted November 17, 2019 Yea due to the sheer number of problems reported I'm surprised they're not just going to roll it back again. It's not just one or two things. 1
Happy2Play 9802 Posted November 17, 2019 Posted November 17, 2019 (edited) With the same things that happened last time, I think they are just going to work through it. But with testing it would appear their are having issues ithe there current api returning items not found. New and imported drive on. Edited November 17, 2019 by Happy2Play
chef 3811 Posted November 17, 2019 Posted November 17, 2019 With the same things that happened last time, I think they are just going to work through it. But with testing it would appear their are having issues ithe there current api returning items not found. New and imported drive on. Was it broken for a long time, last time? I realize it's only been a couple days now. Guess we'll have to wait and see.
micdhack 0 Posted November 17, 2019 Posted November 17, 2019 I am getting an error for all files downloaded by autoorganize. Here is the log: 2019-11-16 20:42:47.434 Info App: Sorting file /home/micdhack/backupdisk/DL/Real.Time.With.Bill.Maher.2019.11.15.720p.HDTV.X264-UAV[eztv].mkv 2019-11-16 20:42:47.468 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/72231/all/en.zip 2019-11-16 20:42:47.749 Error ProviderManager: Error searching *** Error Report *** Version: 4.2.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /home/user/emby/ -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb Operating system: Unix 4.19.66.7 64-Bit OS: False 64-Bit Process: False User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /home/user/emby/ Application directory: /opt/emby-server/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/home/user/emby/cache/tvdb/72231/en.xml'. File name: '/home/user/emby/cache/tvdb/72231/en.xml' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Boolean isAsync) at Tvdb.TvdbSeriesProvider.ExtractEpisodes(String seriesDataPath, String xmlFile, Nullable`1 lastTvDbUpdateTime) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2019-11-16 20:42:47.749 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt0350448 2019-11-16 20:42:47.924 Warn App: No provider metadata found for Real Time with Bill Maher season episode I didn't change anything on the server. Anyone has the same experience?
micdhack 0 Posted November 17, 2019 Posted November 17, 2019 Follow up. In that directory where the file is not found this file exists instead: en.zip.xml @@micdhack
koelner21 4 Posted November 17, 2019 Posted November 17, 2019 Hallo, keine Ahnung warum, aber Auto Organize hat die Funktion aufgegeben. Es kommt immer nur noch diese Meldung vom Bild.
b0mb 36 Posted November 17, 2019 Posted November 17, 2019 (edited) Hallo, keine Ahnung warum, aber Auto Organize hat die Funktion aufgegeben. Es kommt immer nur noch diese Meldung vom Bild. So wie ich es im internationalen Bereich gelesen habe, hat wohl thetvdb kürzliche die v3 gestartet und liefert jetzt fehlerhafte daten.... Ich hoffe, dass das bald gefixt ist. Kommt schon einer mittelschweren Katastrophe nah. ^^ Edited November 17, 2019 by b0mb
bearmusic 0 Posted November 17, 2019 Posted November 17, 2019 The auto organize plugin stop working this week and when you try to manually organize the files from the plugin it always return a "NULL" warning. This happens on new movies organization and adding new episodes to already establish series. before this issue started happening, I notice that when I already have a series on the server and I manually want to organize an episode from the plug in, when i choose from the drop down menu the name of the series I will find duplicate names on it, one works, but the other returns a null error, is there any way to cleanup duplicates from this dropdown menu?
Guest Koda Posted November 17, 2019 Posted November 17, 2019 Hi I have install a emby Server. When I identify a series, i see all results but no images: (see Attachment) When I check the developertool of my Browser I see the Images are blocked: http://myEmbyServer:8096/emby/Items/RemoteSearch/Image?imageUrl=https%3A%2F%2Fwww.thetvdb.com%2Fbanners%2F%2Fbanners%2Fposters%2F5cc45a5f823eb.jpg&ProviderName=TheTVDB When I insert this URL in browser i see only a white page with "Forbidden". But I don't understand what's the problem. Thank you for all help. Koda
Bazzu85 22 Posted November 17, 2019 Posted November 17, 2019 Was it broken for a long time, last time? I realize it's only been a couple days now. Guess we'll have to wait and see. For a weekend if I remember right.. I hope they fix ASAP because the new site is well done..
TheGremlin 68 Posted November 17, 2019 Posted November 17, 2019 Hi, I got issues in scraping information for new tv series / seasons. It don't add any information any more. I think it could be related to the update 1-2 days ago, but I couldn't find any other Topic, which has mention similar problems. Do somebody know, if that is related to the updates on tvdb. To the tvdb plugin needs to be updated?
neik 874 Posted November 17, 2019 Posted November 17, 2019 (edited) It's an issue at TheTVDB's end. https://emby.media/community/index.php?/topic/79269-fyi-tvdb-api-issues/?view=getnewpost&fromsearch=1 Edited November 17, 2019 by neik
tomimc 13 Posted November 17, 2019 Posted November 17, 2019 I dont know if there are any problem with thetvbd, fanart, but i can see images or get some metadata from that providers Beta 4.3.0.22 log: 2019-11-17 12:15:20.738 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/361565/all/es.zip 2019-11-17 12:15:20.749 Info HttpClient: GET https://webservice.fanart.tv/v3/tv/361565?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2019-11-17 12:15:20.943 Error ProviderManager: TvdbSeriesImageProvider failed in GetImageInfos for type Series *** Error Report *** Version: 4.3.0.22 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 5.0.18.1 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/lib/emby/cache/tvdb/361565/es.xml'. File name: '/var/lib/emby/cache/tvdb/361565/es.xml' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Boolean isAsync) at Tvdb.TvdbSeriesProvider.ExtractEpisodes(String seriesDataPath, String xmlFile, Nullable`1 lastTvDbUpdateTime) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesImageProvider.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken, IRemoteImageProvider provider, Int32 providerIndex) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2019-11-17 12:15:40.749 Error HttpClient: Connection to https://webservice.fanart.tv/v3/tv/361565?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 timed out 2019-11-17 12:15:40.754 Error ProviderManager: FanartSeriesProvider failed in GetImageInfos for type Series *** Error Report *** Version: 4.3.0.22 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 5.0.18.1 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to https://webservice.fanart.tv/v3/tv/361565?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 timed out ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException: Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token) at System.Net.Security.SslStreamInternal.<FillBufferAsync>g__InternalFillBufferAsync|38_0[TReadAdapter](TReadAdapter adap, ValueTask`1 task, Int32 min, Int32 initial) at System.Net.Security.SslStreamInternal.ReadAsyncInternal[TReadAdapter](TReadAdapter adapter, Memory`1 buffer) at System.Net.Http.HttpConnection.FillAsync() at System.Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync(Boolean foldedHeadersAllowed) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithNtConnectionAuthAsync(HttpConnection connection, HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpClient.FinishSendAsyncBuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Fanart.FanartSeriesProvider.DownloadSeriesJson(String tvdbId, CancellationToken cancellationToken) at Fanart.FanartSeriesProvider.EnsureSeriesJson(String tvdbId, CancellationToken cancellationToken) at Fanart.FanartSeriesProvider.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken, IRemoteImageProvider provider, Int32 providerIndex) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithNtConnectionAuthAsync(HttpConnection connection, HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpClient.FinishSendAsyncBuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) InnerException: System.IO.IOException: Unable to read data from the transport connection: Operation canceled. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token) at System.Net.Security.SslStreamInternal.<FillBufferAsync>g__InternalFillBufferAsync|38_0[TReadAdapter](TReadAdapter adap, ValueTask`1 task, Int32 min, Int32 initial) at System.Net.Security.SslStreamInternal.ReadAsyncInternal[TReadAdapter](TReadAdapter adapter, Memory`1 buffer) at System.Net.Http.HttpConnection.FillAsync() at System.Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync(Boolean foldedHeadersAllowed) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken) InnerException: System.Net.Sockets.SocketException: Operation canceled Source: TargetSite:
Happy2Play 9802 Posted November 17, 2019 Posted November 17, 2019 The first issue is TVDB is still dead, waiting on them to resolve the issues they created with their update. https://emby.media/community/index.php?/topic/79269-fyi-tvdb-api-issues/ As for FanArt.tv it is hard to say as they are always up and down. 1
TheGremlin 68 Posted November 17, 2019 Posted November 17, 2019 Thanks for the info. I think I wait and drin some tea in the meantime
Happy2Play 9802 Posted November 17, 2019 Posted November 17, 2019 Honestly I don't think TVDB will be right for awhile. Have a look at there forum. https://forums.thetvdb.com/
MSacre 1 Posted November 17, 2019 Posted November 17, 2019 If I'm reading the TVDB forum correctly, this is not a matter of waiting for a fix but adapting to fundamental changes to the database scructure made by the TVDB people.
koelner21 4 Posted November 17, 2019 Posted November 17, 2019 Mittelschwer??? Das ist untertrieben... aber wofür ist eigentlich der Info Kasten in der App, wenn nicht für solche eine Info? @@koelner21
Bazzu85 22 Posted November 17, 2019 Posted November 17, 2019 If I'm reading the TVDB forum correctly, this is not a matter of waiting for a fix but adapting to fundamental changes to the database scructure made by the TVDB people. where are you reading this? I read something about ssl problems with clients.. but they wanted to migrate the api to work as before.. but something went wronh..
