ponch 2 Posted January 15, 2020 Posted January 15, 2020 Can you go over an example, I haven't come across any issues yet. Unless this is a language issue, but need examples. I've attached an example with multiple seasons in it in my previous post. Happy to attach some of the others if it helps Thanks for looking in to it
Luke 42200 Posted January 15, 2020 Posted January 15, 2020 The tvdb plugin 1.0.25 update is up with the workaround for season posters. 2
fluxan 0 Posted January 15, 2020 Posted January 15, 2020 The tvdb plugin 1.0.25 update is up with the workaround for season posters. @@Luke I can confirm that after updating from the catalogue and running a full metadata refresh (including ticking the box to replace existing images) on my TV Shows, all season posters are now showing up perfectly. Thanks to you and the team. :-)
ponch 2 Posted January 15, 2020 Posted January 15, 2020 The tvdb plugin 1.0.25 update is up with the workaround for season posters. @@Luke @@Happy2Play 1.0.25.0 seems pretty sweet. I checked a series I was having issues with (Specifically the one I attached above) and although the XML claims there are season posters, they do not display on their own site. In fact I tried to retrieve the entire series again it lost the series poster which was on their site! I'm guessing they are still migrating media in to their collection or whatever. (I hope they haven't lost much in the change over process). I'm just glad my media collection looks great again! I love Emby and have been using it since it was called MediaBrowser, the Emby team has done a top notch job! Anyway thanks and lets hope TVDB fix the last issues quickly
sertik 0 Posted January 16, 2020 Posted January 16, 2020 (edited) Its look like Themoviedb has a lot of seasons posters, but it isnt available in tv shows also fanart Edited January 16, 2020 by sertik
Luke 42200 Posted January 16, 2020 Posted January 16, 2020 Its look like Themoviedb has a lot of seasons posters, but it isnt available in tv shows also fanart Emby Server supports both MovieDb and Fanart for both series and season posters. Make sure the image fetchers are enabled in your library settings.
Happy2Play 9802 Posted January 18, 2020 Posted January 18, 2020 (edited) @@Luke It doesn't appear Absolute order is working. I only tested on Firefly, it maintains the Aired order. Or are there other dependencies for Absolute order, like naming? Edited January 18, 2020 by Happy2Play
Luke 42200 Posted January 18, 2020 Posted January 18, 2020 @@Luke It doesn't appear Absolute order is working. I only tested on Firefly, it maintains the Aired order. Or are there other dependencies for Absolute order, like naming? Should Firefly order be different with absolute? Usually with that series it's Dvd order that you'd be using, if you're not using Aired.
Happy2Play 9802 Posted January 19, 2020 Posted January 19, 2020 Should Firefly order be different with absolute? Usually with that series it's Dvd order that you'd be using, if you're not using Aired. Just testing the info returned from TVDB. It should be the same as DVD in this test case. One shows one more episode then the other on TVDB. So if Absolute order is suppose to read "<absolute_number>", then it currently does not work in this example.
Luke 42200 Posted January 19, 2020 Posted January 19, 2020 Just testing the info returned from TVDB. It should be the same as DVD in this test case. One shows one more episode then the other on TVDB. So if Absolute order is suppose to read "", then it currently does not work in this example. You've have to remove the season number from each episode in order for absolute numbering to work, although we should be able to improve that for single season shows like this. 1
ponch 2 Posted January 20, 2020 Posted January 20, 2020 Just a quick update... The Season posters that were still missing now seems to be fixed. (1.0.26.0) Thanks!
Zodler 18 Posted January 21, 2020 Posted January 21, 2020 Trying to add Curb Your Enthusiasm and it is not recognized, are there new issues? Even when I manually match it, the episode names are not fetched.
Luke 42200 Posted January 21, 2020 Posted January 21, 2020 @@Zodler we're happy to help. Please see how to report a problem: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/?view=getnewpost Thanks!
blade005 185 Posted January 24, 2020 Posted January 24, 2020 Emby Server supports both MovieDb and Fanart for both series and season posters. Make sure the image fetchers are enabled in your library settings. @@Luke As TVDB has transitioned to their new API and layout I see that they have added two entries in their image section. PANEL (i.e. Thumb/Landscape) and ICON (i.e. Logo). Two items that we only had Fanart for. Any consideration to adding these to the Image Fetch parameters?
Happy2Play 9802 Posted January 26, 2020 Posted January 26, 2020 TVDB Survey In an effort to continue improving the site, we'd love to get your feedback. Our survey should take 5-10 minutes to complete and will help us understand where to focus our future efforts. This is very important for internal prioritization, so PLEASE everyone do this if you can spare the time. https://www.surveymonkey.com/r/tvdb-users
Bazzu85 22 Posted January 27, 2020 Posted January 27, 2020 Hi, I'm noticing (again) that the non-english translation are half retrieved.. if you have italian title and english plot, plot is never retrieved.. I thought the problem was resolved last month but now I have the same issue again.. so is tvdb or last plugin version?
Happy2Play 9802 Posted January 28, 2020 Posted January 28, 2020 (edited) @@Luke As TVDB has transitioned to their new API and layout I see that they have added two entries in their image section. PANEL (i.e. Thumb/Landscape) and ICON (i.e. Logo). Two items that we only had Fanart for. Any consideration to adding these to the Image Fetch parameters? Yes those can be added. Thanks. How are these Icons suppose to be used? I see a couple could be logos. Will these 1x1 images be a issue? Using Star Trek: Picard as an example Icons https://www.thetvdb.com/series/star-trek-picard/artwork/icons Edited January 28, 2020 by Happy2Play
sertik 0 Posted January 28, 2020 Posted January 28, 2020 (edited) Unable to identify Simpsons it gave me Demashita! Powerpuff Girls Z might be id mistmatch attempted with imdb,tvdb,themoviedb Edited January 28, 2020 by sertik
Luke 42200 Posted January 28, 2020 Posted January 28, 2020 Unable to identify Simpsons it gave me Demashita! Powerpuff Girls Z might be id mistmatch @@sertik please see how to report a problem. Thanks.
sertik 0 Posted January 28, 2020 Posted January 28, 2020 @@sertik please see how to report a problem. Thanks. it aint related to tvdb api issues?
Luke 42200 Posted January 28, 2020 Posted January 28, 2020 it aint related to tvdb api issues? We don't know yet.
Happy2Play 9802 Posted January 29, 2020 Posted January 29, 2020 FYI Hi there! There are some delays currently with the v1 updates that should be fixed soon as we're working on a larger scale issue that will fix many of the current issues in v1. As far as the differences in language, it likely updated on aus because that wasn't already cached, so it just loaded live and then cached the result. Since English was likely accessed prior, it needed to wait for the cache to expire to show the updates. https://forums.thetvdb.com/viewtopic.php?f=122&t=62107
Happy2Play 9802 Posted February 26, 2020 Posted February 26, 2020 Image Resolution issue ticketed and on backlog of issues. https://forums.thetvdb.com/viewtopic.php?f=122&t=62465 1
