Happy2Play 9802 Posted November 22, 2019 Posted November 22, 2019 (edited) Understood, thanks. It seems the only way I can get "current" metadata images from TVDB (meaning any of the 3 sets at the bottom of a series page, like this one for example: https://thetvdb.com/series/its-always-sunny-in-philadelphia) is to manually download them and add them to each show myself. Doing a "Replace all Metadata" with "Replace existing images" checked seems to just pull back the same old series image, that isn't one of the 3 on the TVDB series page. I'm curious if anyone else is having this same issue in specific? There are only 3 displayed but when you click "view all" there are like 24. But their voting/favorites system is somewhat broke right now also. I can only assume you are getting the first image they returned. This appears for every image in their api (that I have seen). There are a few topics on their forum on this. "ratingsInfo": { "average": 0, "count": 0 Edited November 22, 2019 by Happy2Play
Happy2Play 9802 Posted November 22, 2019 Posted November 22, 2019 Zip file issues is being re-ticketed. https://forums.thetvdb.com/viewtopic.php?p=164266#p164266 Still no update on Series Updates https://thetvdb.com/api/Updates.php?type=all&time=1573742729 https://forums.thetvdb.com/viewtopic.php?f=122&t=60373&sid=a4a3f3a241088ba22e419b80b10d5c74
mike689 0 Posted November 22, 2019 Posted November 22, 2019 (edited) There are only 3 displayed but when you click "view all" there are like 24. But their voting/favorites system is somewhat broke right now also. I can only assume you are getting the first image they returned. This appears for every image in their api (that I have seen). There are a few topics on their forum on this. "ratingsInfo": { "average": 0, "count": 0 Yep that sounds right and is what I'm thinking as well. In the past typically it would grab the most recent (or perhaps most voted, I guess) image(s) for metadata download and right now it is probably just picking the first one out of the list of all of them, likely being the oldest. So i guess hopefully my issue will likely just "fix itself" whenever they get their API/voting system sorted? Edited November 22, 2019 by mike689
Happy2Play 9802 Posted November 22, 2019 Posted November 22, 2019 Updates have been ticketed by admin. https://forums.thetvdb.com/viewtopic.php?p=164291#p164291
Zodler 18 Posted November 23, 2019 Posted November 23, 2019 I have not read all posts. Just to be sure, at the moment I don't get no episode info metadata and no episode image from tvdb. Is this correct?
Happy2Play 9802 Posted November 23, 2019 Posted November 23, 2019 I have not read all posts. Just to be sure, at the moment I don't get no episode info metadata and no episode image from tvdb. Is this correct? Only issue should be seasons images, and library scan series updates. You many need to go over a specific example.
Zodler 18 Posted November 23, 2019 Posted November 23, 2019 Only issue should be seasons images, and library scan series updates. You many need to go over a specific example. Oh, so I must have a problem then. It is not a specific example. It's everything. All new episodes I add to any series, don't get episode info or episode image. My TVDB plugin is 1.0.22.0. My Emby Server is the special patch version 4.3.0.25 downloaded from Dropbox. It seems there is a newer version, But it is not saying there is a new update. I should do it manually?
Happy2Play 9802 Posted November 23, 2019 Posted November 23, 2019 Oh, so I must have a problem then. It is not a specific example. It's everything. All new episodes I add to any series, don't get episode info or episode image. My TVDB plugin is 1.0.22.0. My Emby Server is the special patch version 4.3.0.25 downloaded from Dropbox. It seems there is a newer version, But it is not saying there is a new update. I should do it manually? Have you tried Refreshing Metadata for a Series Search for Missing metadata?
Zodler 18 Posted November 23, 2019 Posted November 23, 2019 (edited) No I did not. I will do some tests with dummy libraries later. ...But now I'm thinking, I'm one of those who lost his library with the new version and had to do a full re-scan. When I did the rescan, did it get all the information from the web or locally from the old library? If it got everything again from the web, I don't understand how all the old episodes have the metadata but not the new ones that I add currently. Edited November 23, 2019 by Zodler
Happy2Play 9802 Posted November 23, 2019 Posted November 23, 2019 (edited) No I did not. I will do some tests with dummy libraries later. ...But now I'm thinking, I'm one of those who lost his library with the new version and had to do a full re-scan. When I did the rescan, did it get all the information from the web or locally from the old library? If it got everything again from the web, I don't understand how all the old episodes have the metadata but not the new ones that I add currently. It depends on where your metadata is stored? If with media then is should be read, with if database only then more then likely the web and possibly broke metadata depending on what was actually returned from TVDB at the time. Edited November 23, 2019 by Happy2Play
ponch 2 Posted November 24, 2019 Posted November 24, 2019 (edited) For anyone who cares, here's the TVDB forum post regarding the missing season posters. Finally someone from TVDB has commented on the post, so hopefully this will be sorted soon! (Note this issue is not listed in the list of issues they are working on) https://forums.thetvdb.com/viewtopic.php?f=122&t=60291 Edit: spelling Edited November 24, 2019 by ponch
Bazzu85 22 Posted November 25, 2019 Posted November 25, 2019 question: scraping metadata for the episode with italian title and english plot does not return the plot, only the title.. If I remember right before the v3 update the metadata was scraped first in selected language, then in default english language to complete..
Bazzu85 22 Posted November 25, 2019 Posted November 25, 2019 question: scraping metadata for the episode with italian title and english plot does not return the plot, only the title.. If I remember right before the v3 update the metadata was scraped first in selected language, then in default english language to complete.. here's an example.. can be done a workaround in emby tvdb plugin? or is something related the api?
Nostromo86 17 Posted November 25, 2019 Posted November 25, 2019 (edited) Hi, I just add one piece and I have the same problem as last week. there is still a problem with tvdb? i have emby 4.3.0.26 Thanks Edited November 25, 2019 by Nicestream 1
davedick 19 Posted November 25, 2019 Posted November 25, 2019 Can someone give some clarification on the impacts of Emby when it comes to the current issues with the TVDB API ? For example, if someone did a clean install and setup TV library, what data from TVDB would they be seeing, compared to what they wouldn't be seeing? The same for when a new show is added to an existing TV library. I see there are updates to the TVDB plug in and mention of having to manually update each TV show in the metadata section, but was still confused on when the manual updating needed to take place, etc. Thanks
Happy2Play 9802 Posted November 26, 2019 Posted November 26, 2019 Can someone give some clarification on the impacts of Emby when it comes to the current issues with the TVDB API ? For example, if someone did a clean install and setup TV library, what data from TVDB would they be seeing, compared to what they wouldn't be seeing? The same for when a new show is added to an existing TV library. I see there are updates to the TVDB plug in and mention of having to manually update each TV show in the metadata section, but was still confused on when the manual updating needed to take place, etc. Thanks Yes the TVDB plugin has been update to work with issues at TVDB. But there are outstanding issues like being able to update series daily with the library scan, season images have issues, and several language and metadata issues. There is still a lot that need done on TVDB's side still. So I don't see 100% functionality for quite awhile.
ponch 2 Posted November 27, 2019 Posted November 27, 2019 For anyone who cares, here's the TVDB forum post regarding the missing season posters. Finally someone from TVDB has commented on the post, so hopefully this will be sorted soon! (Note this issue is not listed in the list of issues they are working on) https://forums.thetvdb.com/viewtopic.php?f=122&t=60291 Edit: spelling According to TVDB this has been resolved. I can now see season posters on the TVDB website but the TVDB plugin doesn't seen to be retrieving them (Auto or Manual). Here's what the url apparently looks like now: https://artworks.thetvdb.com/banners/seasons/5dcb313b92755_t.jpg Is this something that needs to be updated on the Emby side of things now? Or is there anther issue affecting Season posters?
Bazzu85 22 Posted November 27, 2019 Posted November 27, 2019 (edited) According to TVDB this has been resolved. I can now see season posters on the TVDB website but the TVDB plugin doesn't seen to be retrieving them (Auto or Manual). Here's what the url apparently looks like now: https://artworks.thetvdb.com/banners/seasons/5dcb313b92755_t.jpg Is this something that needs to be updated on the Emby side of things now? Or is there anther issue affecting Season posters? yes, according to tvdb forum the issue is resolved but emby is not pulling the artworks anymore... going to edit image and searching for season poster doesn't return anything.. here's the log: 2019-11-27 10:41:47.042 Info HttpServer: HTTP Response 200 to 151.62.130.129. Time: 3ms. http://151.62.130.129:8096/emby/Sync/Items/Ready?TargetId=AgGe0Ok5I1qeImqmQc3nVJPLXhsl2X1ZJWkSIhtiRzQ 2019-11-27 10:41:47.280 Info HttpServer: HTTP POST http://151.62.130.129:8096/emby/Sync/Data. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Edge/18.18362 2019-11-27 10:41:47.282 Info HttpServer: HTTP Response 200 to 151.62.130.129. Time: 2ms. http://151.62.130.129:8096/emby/Sync/Data 2019-11-27 10:41:49.813 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/158920/RemoteImages?type=Primary&startIndex=0&limit=6&IncludeAllLanguages=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36 2019-11-27 10:41:49.847 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/361753/all/it.zip 2019-11-27 10:41:50.256 Info HttpServer: HTTP Response 200 to ::1. Time: 443ms. http://localhost:8096/emby/Items/158920/RemoteImages?type=Primary&startIndex=0&limit=6&IncludeAllLanguages=false 2019-11-27 10:41:51.515 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36 2019-11-27 10:41:51.535 Info HttpServer: HTTP Response 200 to ::1. Time: 20ms. http://localhost:8096/emby/System/Logs/embyserver.txt 2019-11-27 10:41:51.904 Info HttpServer: HTTP GET http://localhost:8096/favicon.ico. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36 2019-11-27 10:41:51.906 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/favicon.ico 2019-11-27 10:42:50.768 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/158920/RemoteImages?type=Primary&startIndex=0&limit=6&IncludeAllLanguages=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36 2019-11-27 10:42:50.781 Info HttpServer: HTTP Response 200 to ::1. Time: 14ms. http://localhost:8096/emby/Items/158920/RemoteImages?type=Primary&startIndex=0&limit=6&IncludeAllLanguages=true 2019-11-27 10:42:53.377 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36 I don't see any image pull...why? here's a screen searching for season posters: here's a screen searching for episode image: thx Edited November 27, 2019 by Bazzu85
rathmore 0 Posted November 27, 2019 Posted November 27, 2019 (edited) "going to edit image and searching for season poster doesn't return anything.." Yes, i can confirm it is not working Also; when i identify a movie / serie it is not pulling the main image Edited November 27, 2019 by rathmore
Happy2Play 9802 Posted November 27, 2019 Posted November 27, 2019 I believe it is still a metadata issue as there is no season information being returned in the banners.xml from the zip files. As some of cached metadata still contain season info and when new zip is pulled that information is not returned. Querying their new api the information is returned.
Bazzu85 22 Posted November 27, 2019 Posted November 27, 2019 I believe it is still a metadata issue as there is no season information being returned in the banners.xml from the zip files. As some of cached metadata still contain season info and when new zip is pulled that information is not returned. Querying their new api the information is returned. So if the tvdb api returns the infos.. What's the solution? Is an emby cache problem? Something else?
Happy2Play 9802 Posted November 27, 2019 Posted November 27, 2019 (edited) So if the tvdb api returns the infos.. What's the solution? Is an emby cache problem? Something else? Something else Opened a new topic on TVDB about the issue in the zip Banners.xml versus the link Banners.xml. But there are several topics where they have mentioned an actual cache issue with information that is being returned. https://forums.thetvdb.com/viewtopic.php?f=122&t=60547&sid=f3d2a31183d3e4898ee05015ccd4177a The link Banners.xml contains season info where the zip Banners.xml does not. Edited November 27, 2019 by Happy2Play
Bazzu85 22 Posted November 27, 2019 Posted November 27, 2019 (edited) Something else Opened a new topic on TVDB about the issue in the zip Banners.xml versus the link Banners.xml. But there are several topics where they have mentioned an actual cache issue with information that is being returned. https://forums.thetvdb.com/viewtopic.php?f=122&t=60547&sid=f3d2a31183d3e4898ee05015ccd4177a The link Banners.xml contains season info where the zip Banners.xml does not. thx! what about the mixed metadata for the episodes? if for example I have only the title translated in italian emby show me only the title, not the plot in english as before.. the question is 'cause I don't know how different metadata language are scraped.. in the it.xml I should expect the mixed language information? (italian title, english plot) thx again! Edited November 27, 2019 by Bazzu85
Happy2Play 9802 Posted November 27, 2019 Posted November 27, 2019 thx! what about the mixed metadata for the episodes? if for example I have only the title translated in italian emby show me only the title, not the plot in english as before.. the question is 'cause I don't know how different metadata language are scraped.. in the it.xml I should expect the mixed language information? (italian title, english plot) thx again! If you are pulling a it.xml then you have download language set to italian. Now if information is not available @@Luke would have to explain the language fallback scenario.
Bazzu85 22 Posted November 27, 2019 Posted November 27, 2019 If you are pulling a it.xml then you have download language set to italian. Now if information is not available @@Luke would have to explain the language fallback scenario. additionally I see here: https://forums.thetvdb.com/viewtopic.php?f=122&t=60239 in the resolved problems: v1 API series record returns English content when non-English was requested — Released 11/21this means that if I request italian content I only receive this? waiting for @@Luke to read our conversation.. thx
